How to make 12 volt charger stay on all the time.
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaredmillerdvm, Apr 14, 2018.
  1. Apr 14, 2018 at 7:21 PM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Anyone figure out how to make the 12 volt charger stay on even when truck is off?
  2. Apr 14, 2018 at 7:40 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Can you explain what you mean? Sorry I'm a little slow. :D
    619Tundra and NewImprovedRon like this.
  3. Apr 14, 2018 at 7:48 PM
    I'm sure you could just change the power wire to a constant hot by doing a search with a test light.
    kcaustin66 and NewImprovedRon like this.
  4. Apr 14, 2018 at 7:57 PM
    nk1794
    San Jose, CA
    bulldog93 likes this.
  5. Apr 15, 2018 at 1:34 AM
    jaredmillerdvm
    Anderson, SC
    @nk1794 my 07 Chevy had one that stayed on all the time and the battery never went dead. I would imagine that it would only drain the battery if you left something plugged in for days at a time without starting the truck. Or maybe they had something like you posted installed from factory. Who knows but it would be nice to have one stay on without having the truck running.
  6. Apr 15, 2018 at 8:22 AM
    nk1794
    San Jose, CA
    OK. I thought you were doing constant charging.....It's easy to do. Get one of these and tap into one of the fuses at the driver's foot well. Obviously you want to look for a fuse that's always on and run the wire to your outlet and swap it out. You will have to do a little cutting and crimping at that end.
    You can use this tester to find and test the fuse that's always on.
  7. Apr 15, 2018 at 9:22 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    My wife's Jeep has a constant on plug and her battery doesn't die. I don't think it would be an issue unless you were constantly using it... Also, pretty cool thing about it is you just move the fuse one oring over to either have it constant on or with ignition.
    bulldog93 and unsub1 like this.
  8. Apr 15, 2018 at 10:18 AM
    eddiesteele
    eddiesteele New Member
    eddie
    Long Beach
    '18 SR5 CM
  9. Apr 15, 2018 at 11:51 AM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    I currently have @TundraTex looking into this, but he has a very busy schedule. I'm sure he'll get back to me very soon on it and I'll post up a DIY for everyone.
  10. Apr 15, 2018 at 1:01 PM
    boostedtrdpro
    Jeremy
    I have a feeling this is going to be an add-a-fuse moment. The relay seems to be stashed in the main body ECU (which i'm not even sure where that's located) and is inaccessible. I've read there is a RED wire coming from the main body ECU that powers all the 12v outlets that can be de-pinned and ran to a constant 12v fused power supply. It may be easier to just find an always hot fused 12v source and tap into it so long as you don't overload that circuit. Then run 12v constant to the outlets. Sure would be nice to find out about the de-pinning of the power outlet wire at the ECU as this would catch ALL the outlets at once.
  11. Apr 16, 2018 at 3:07 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    EDITED: When I originally wrote this post I had only briefly looked at the wiring diagrams. After taking more time to investigate and actually crawl under the dash, there is a pretty easy way to do this. Check out Post 33 for a picture of the driver's side kick panel fuse block and an unused 12 Volt Fuse slot.
    Hope this provides some food for thought. It's now number 37 on my list of things I'll do when I have the time.
    bulldog93, ou77kg, NCinCO and 5 others like this.
  12. Apr 16, 2018 at 2:16 PM
    jaredmillerdvm
    Anderson, SC
    @TundraTex have you seen this? Think it would work for the tundras? I just looked under the hood and couldn’t find a relay for the 12volt chargers? Do you know which relay it would be?
  13. Apr 16, 2018 at 2:19 PM
    boostedtrdpro
    Jeremy
    It's because the relay is integrated in the main body ECU. It is not able to be jumpered and/or soldered like in the Tacos and 4 Runners.
  14. Apr 16, 2018 at 2:26 PM
    n2deep
    n2deep Pavement Princess
    Just run a dedicated wire to the battery -fused of course. Can also run a heavier gauge if needed.
  15. Apr 16, 2018 at 2:49 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    @nk1794, I see another mod with video in your future
    porkitt likes this.
  16. Apr 16, 2018 at 3:12 PM
    nk1794
    San Jose, CA
    You are good! :rofl:
    NewImprovedRon likes this.
  17. Apr 16, 2018 at 3:23 PM
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    ^^^^ Don't know how I missed that, and staying tuned.
    nk1794 likes this.
  18. Apr 16, 2018 at 6:53 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    I did one of my 12v lighter plugs when changing out the stereo, there is a yellow wire in the radio harness that is always hot, simple enough to drop it down to power a plug and just cap the wire that is on with the key. 2017 SR5
  19. Apr 16, 2018 at 8:44 PM
    eddiesteele
    eddie
    Long Beach
    '18 SR5 CM
    for my blackvue dashcam im using THIS to run the dashcam while the truck is off to keep the battery from draining to far down. Im sure adding a second one with a dedicated outlet or even running it strait to the outlets in the center console would work.
  20. Apr 16, 2018 at 11:30 PM
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    Add a fuse to the horn off the fuse panel was how I was able to power a charging USB plug to always stay active.
  21. Apr 17, 2018 at 1:56 PM
    Brimaster
    Brimaster New Member
    2017 Magnetic Gray Metallic DC TRD
    this is one thing I missed when i moved from the xterra to the tundra. All the lighter plugs were active all the time so it was nice when tailgating to be able to connect stuff without having to run the vehicle. I'll keep a watch on this thread so when the time comes I can do this mod.
    nk1794 likes this.
  22. Apr 17, 2018 at 2:32 PM
    nk1794
    San Jose, CA
    Someone should do a DIY video on this. :D
  23. Apr 17, 2018 at 2:44 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I pulled a home run from my under hood fuse block while I was running wires for my light switches. Fuse block through firewall, then "over the river and through the woods" to the drivers side 12 volt. I only did one because I like having one always hot and one switched. I then re-used the abandoned switched wire for my dash camera. Remember to fuse the circuit to match it's original max amps.
    Disclaimer: I am not now nor have I ever been a licensed electrician, automotive or other, but I do play one in barrooms.
    EDDO, Prostar 190 and nk1794 like this.
  24. Apr 17, 2018 at 2:45 PM
    nk1794
    San Jose, CA
    Nice job!
  25. Apr 17, 2018 at 2:55 PM
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    You read my mind :thumbsup:
    That way folks like me have detailed step by step
  26. Apr 17, 2018 at 3:01 PM
    nk1794
    San Jose, CA
    I'll do one for you, Skippy. :D
  27. Apr 17, 2018 at 3:14 PM
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    Tap the yellow wire in the radio, and that way if I EVER get around to my front camera install I can kill 2 birds with one stone :hattip:
  28. Apr 17, 2018 at 3:15 PM
    nk1794
    San Jose, CA
    Looks like it’s going to be a really short video.
  29. Apr 20, 2018 at 6:01 AM
    jaredmillerdvm
    Anderson, SC
    Anybody working on a video or step by step?
  30. Apr 20, 2018 at 6:21 AM
    nk1794
    San Jose, CA
    planning on a video
