How to maintain exterior of Fox shocks
Discussion in 'Suspension' started by rocsteady, May 8, 2022.
  1. May 8, 2022 at 10:53 AM
    rocsteady
    rocsteady [OP] New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Any info on how to treat, clean, maintain the shock bodies so the exterior doesn't get corroded like these were on a Raptor i used to own? This was after I bought the truck and cleaned them up. Screenshot_20220508-134821_Photos.jpg
    ATV25 likes this.
  2. May 8, 2022 at 12:32 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I've not tried this personally, but have you thought about trying some naval jelly to clean the rust. Once the rust is clean, or on a new shock body wrapping it with clear protective film.
    ATV25 likes this.
  3. May 9, 2022 at 9:46 AM
    rocsteady
    Dave
    New Jersey
    I had not. I just had the suspension installed in February and it's fine so far but I'd like to keep it that way; so it doesn't get to the point that the ones did in the picture from my old Raptor. Right now the only thing rusty looking is the bolt visible as you look in to see the shock above the tires. This picture is of them when they were new on the Tundra a month ago, the part that's starting to corrode is notable right above the "BDS Suspension" sticker:
    AM-JKLXOlaHgv0J3FwflncGYjLEu1W8e41grr3IL_27d89a96666f0de75b6c82d9e3400ab6f297c0d0.jpg
    ATV25 likes this.
  4. May 13, 2022 at 7:20 PM
    rocsteady
    Dave
    New Jersey
    After wash I hit the surface rust on that spot with a nylon gun brush soaked in wd40 and it seems to be a good fix. Cleaned right up and hopefully left some protection behind. My neighbors think I'm nuts, washing and wiping down the suspension. They're probably right but it will look nice.
    TheBeast and ATV25 like this.
  5. May 13, 2022 at 7:58 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    unable to answer your question, however, i am interested in any feedback you can offer regarding your bds 3".
    did you go with the 3" CO (824F) kit, or the more affordable 3" IFP CO (824FSL) kit?
    im due for shocks and tires and heavily considering the 824FSL kit.
  6. May 14, 2022 at 6:56 AM
    rocsteady
    Dave
    New Jersey
    I went with the 3" IFP CO (824FSL) kit as I rarely see real off road conditions and even when I take a day to go explore a bit, the trails accessible to me are pretty tame. Couldn't justify the extra $$ for the external reservoir setup. So the suspension was as much for a little bit of lift, a little bit of looks and to make sure there'd be no rubbing issues (if I go with a larger tire later on). Truck's whole purpose is to make sure I can get to work in any weather as my employer considers me "essential" (except when it comes to pay or reciprocating the loyalty).
    O-OB135aBTih5W0uVKEeTPur0fe__BsJMKivmMQG_6aa0d2e59addfa1465191bfe217f5725147d13d7.jpg
    AM-JKLWUlMMwwyup-pU-j-dqO_yXsUoYjfdapF9q_a8913331d3dd1411279e4064ad7b1a8ff62b46b5.jpg
  7. May 15, 2022 at 5:36 PM
    shackleford rusty
    TEXAS!
    my uses will be very similar. rarely off road, and when so, it's typically gravel, dirt, sand and pretty flat terrain.
    any complaints?
    thanks for the pics. rig looks great!
  8. May 15, 2022 at 8:39 PM
    rocsteady
    Dave
    New Jersey
    No complaints. Looking forward to hitting some more challenging trails and hoping for lots of snow next winter.
  9. May 15, 2022 at 11:32 PM
    TheBeast The Beach
  10. May 16, 2022 at 5:58 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
