How to lower icon coilovers
Discussion in 'Suspension' started by Payaso 9394, Jun 13, 2017.
  1. Jun 13, 2017 at 9:54 PM
    Payaso 9394
    Payaso 9394 [OP] New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    Hi guys I was going for a 4 inch lift but I feel my front is to high my back has 1.5 shackles from toytec still waiting on 1.5 leaf pack my fronts running maxtrac 3.5 spindles with icon 2.5 coilover but it seem to high in the front does anyone know what height icons come in maybe that might be my issue years a pic IMG_20170613_205212_748.jpg
  2. Jun 14, 2017 at 9:14 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    From what I remember, most companies send their coilovers out preloaded to about 2.5" of lift. Crank those puppies down (theoretically up) and you should be good.
  3. Jun 14, 2017 at 11:23 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The 2.5" are adjustable from 0-3.5" of height so you should be able to adjust them to your desired height
  4. Jun 14, 2017 at 11:40 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    You need to buy one of those spanner wrenches to adjust them with. You don't need to jack up the truck to crank the coilovers down. You also might not need to get an alignment done if you're cranking it down about a quarter-inch on the thread.
    Step 1: Loosen the thread locking bolt on the top of the coilover ring with an Allen key but don't remove it.
    Step 2: With the spanner wrench, turn the ring counter-clockwise.
    Step 3: Tighten the locking bolt but just finger tight because you don't want to damage the thread.
    There's an exact number somewhere that I'm forgetting but it's something like: for every full revolution of the coilover ring, you adjust the height about 1/8".
  5. Jun 14, 2017 at 12:16 PM
    So, you're running 6.5" in the front and 1.5" in the rear right now?
  6. Jun 14, 2017 at 6:59 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  7. Jun 14, 2017 at 6:59 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Well 6 and 1.5 but today I got my leaf pack for another 1.5 lift in rrsr
  8. Jun 14, 2017 at 7:51 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    14974949706991079012095.jpg more questions these go on top of the bottom leaf right and where they supposed to come with bolts the guy from atlas springs said use the bolts from the truck but it doesn't have any for that
  9. Jun 14, 2017 at 8:17 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  10. Jun 14, 2017 at 8:18 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  11. Jun 14, 2017 at 8:41 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Is that the Icon leaf pack?
  12. Jun 14, 2017 at 8:42 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Atlas but it similar does it go at the bottom of the stock leaf pack?
  13. Jun 14, 2017 at 8:45 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I got the Icon pack and it has 3 leaves that replaced the top 2. It also came with new u-bolts.
    The bottom leaf is an overload leaf and it remains.
  14. Jun 14, 2017 at 8:46 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Was it the prt #51200?
  15. Jun 14, 2017 at 8:46 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Did you have to remove the stock clamps?
  16. Jun 14, 2017 at 8:49 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I had the springs completely off the truck, the truck was up on a lift
  17. Jun 14, 2017 at 8:51 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    You don't have a picture of how u have it now it be really helpful if u did I'm trying to get it done today n I'm stuck
  18. Jun 14, 2017 at 8:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Won't be home until Friday.
    Sorry
  19. Jun 14, 2017 at 8:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    What exactly is the problem?
  20. Jun 14, 2017 at 9:00 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Trying to figure how it goes and if I'm missing bolts
  21. Jun 14, 2017 at 9:02 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There's definitely a front and rear plus you need bolts. They should have been included
  22. Jun 14, 2017 at 9:13 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Yeah that's what I'm trying to figure out but I can't get it to fit I striped the volt
  23. Jun 14, 2017 at 9:17 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    What's the front
  24. Jun 14, 2017 at 9:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Forward, toward the drivers seat, rear is toward the hitch
  25. Jun 14, 2017 at 9:55 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    I get that but what's the front off the leaf pack
  26. Jun 14, 2017 at 9:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The Icon pack was marked
  27. Jun 14, 2017 at 11:03 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Dang mine isn't I'll try asking them I'll go tommorw n ask for the bolts missing and ask
  28. Jun 14, 2017 at 11:04 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Thanks bro I really appreciate it I'm loosing my mind
  29. Jun 15, 2017 at 7:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Did you get this worked out? Wish I could have been able to be more help.
  30. Jun 15, 2017 at 8:33 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Sent it to get put together tomorrow I get it n install n I'm done I hope just would need alignment and new bigger tires 3057018 or 3512.5r18
