How to fix my cut out stock radio harness
Discussion in '1st Gen Tundras (2000-2006)' started by Bobbysub, Oct 30, 2019.
  1. Oct 30, 2019 at 1:15 PM
    Bobbysub
    Bobbysub [OP] New Member
    Bobby
    05 tundra sr5 limited 2wd
    So I have a 05 tundra sr5 limited an I put in a sound system with an aftermarket radio by cutting my stock harness (bad way to go ik), but it was working fine for months an now it won’t turn on not even power to the amp. I’ve checked fuses I’ve checked all my wires I’ve redone my wires an still nothing what can I do to make it look an work better than before
  2. Oct 30, 2019 at 2:09 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    you check the fuse behind the radio?? some unit have fuse on the unit.
  3. Oct 30, 2019 at 2:43 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    When you say you checked fuses....was it the 20A Radio and 15A ACC ?
  4. Oct 30, 2019 at 2:44 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Got a test light to see if there is power to the wires
  5. Oct 30, 2019 at 6:22 PM
    Bobbysub
    Bobby
    I have checked the fuse behind the unit an it is in good shape as for checking power to the wires I have not done yet I will need to do that ASAP
  6. Oct 30, 2019 at 6:30 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    One time I did this on my ranger. I went to a junk yard and got the stock harness and rewired it
  7. Oct 30, 2019 at 8:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    your best bet is find a wiring diagram and a pin out of connectors and repair the harness. then use the proper adapter harness.
  8. Oct 30, 2019 at 10:21 PM
    Bobbysub
    Bobby
    Thanks a lot fellas
  9. Oct 31, 2019 at 7:40 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    If you have power and it won't come on check your ground. Either that or your radio is junk
  10. Oct 31, 2019 at 9:49 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Was your factory harness the 70-1761 style with two plugs or was it the 70-8113 style with a single plug?
    If it was the latter you may be out of luck unless you held onto the plug. If it was the 70-1761, I know that at one point Metra made a "reverse" harness that was the 71-1761. Of course the wire colors in this harness are all universal radio wire colors and would not match the factory wiring. It would be up to you to decode the factory colors and match them up correspondingly.
    This route will just get you back to the point where you can plug your original radio back in and doesnt troubleshoot the power problem but at least you know the option is out there.
  11. Oct 31, 2019 at 1:13 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Should be pretty easy to find the problem. As others mentioned, take a test light and check the power wire. If you have power there, then it's the radio.
  12. Oct 31, 2019 at 2:25 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    In a 2000-2003 FSM, one of the troubleshooting steps concerns tape player. My question would be if your not able to check voltages with a VOM, turn key to IGN ON, does it accept the tape ?
    I'm sure if that is a dumb question, I'm sure someone will speak up :)
  13. Oct 31, 2019 at 3:10 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    You sure you checked all the fuses? Looks like there could be up to 3 fuses depending upon what audio system you have. Click on the link below with the 2005 Factory Service Manual and look at page 4175 with the Audio Power Source wiring diagram.
    https://drive.google.com/file/d/0B-5MhfqaHsHObmt6RDVhOGtKWjA/view
