How to fit 285/70 R18 on stock?
Discussion in 'Wheels & Tires' started by roy2015, Oct 30, 2019.
  1. Oct 30, 2019 at 8:34 PM
    roy2015
    roy2015 [OP] Waterproof
    Houston
    Super White = Super Fast
    They say it can't be done, but anything is possible. Or maybe convince me to get smaller tires.
    Does anyone have experience doing this? I'd like to use my TRD 18" wheels. I'm not afraid of some trimming and shimming, but don't feel comfortable with cutting and welding like the BMC.
    THANKS!
    Rica25 likes this.
  2. Oct 30, 2019 at 8:57 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    No welding or cutting is required. No wheels spacers are needed. I fit LT285/75R18 on stock wheels and all I did was raise the front by about 1.5".
    tonynw318, plumber802, hitech and 5 others like this.
  3. Oct 30, 2019 at 9:01 PM
    roy2015
    Houston
    That's exactly the look I'm going for! Do you think it would have worked without the 1.5" lift? Or do you think a coachbuilder 1" shim would be enough lift?
    I might just have to put the tires on and then go from there . . . .
  4. Oct 30, 2019 at 9:02 PM
    computeruser6
    Dirk
    Escondido
    I have stock leaf springs and shackles in the rear; no lift is required in the rear. The wheel wells are large enough to fit a 34/35" tire (depending on lift), you'll just have to raise the front slightly.
    Rica25 and roy2015[OP] like this.
  5. Oct 30, 2019 at 10:00 PM
    Kwc2210
    Kwc2210 New Member
    2014 white SR5
    Leveled, bags, 295/70/18
    do you have enough clearance between your UCAs?
    Rica25 likes this.
  6. Oct 30, 2019 at 10:37 PM
    computeruser6
    Dirk
    Escondido
    Yes, as long as they are not wider than 285mm you should be fine. This may also vary depending on the shoulder lugs the manufacturer molded into the tire (Toyo M/T or Nitto Mud Grappler tires stick out more than my A/T tread). I have the SPC arms which stick further out than stock and there has been no interference while cycling the suspension while turning at full lock.
    roy2015[OP] likes this.
  7. Oct 30, 2019 at 11:35 PM
    roy2015
    Houston
    What did you use to raise the front the 1.5"???
    Rica25 likes this.
  8. Oct 31, 2019 at 3:01 PM
    computeruser6
    Dirk
    Escondido
    I used King 2.5 coilovers but much cheaper shocks could also be used.
  9. Nov 1, 2019 at 9:34 PM
    computeruser6
    Dirk
    Escondido
    What are you going to go with?
  10. Nov 4, 2019 at 10:38 AM
    roy2015
    Houston
    not sure what I'm gonna do yet. Every day I have a different idea lol
  11. Nov 8, 2019 at 4:53 PM
    Check out customoffsets.com
  12. Nov 8, 2019 at 4:57 PM
    Tundrajoe
    Tundrajoe New Member
    Joe
    2014 crewmax super white
    Bilstein 5100s cooper at3 xlts, tint, full custom exhaust, methods
    I ran bilstein 5100 on the top setting and I fit a 295 70 18 with no issues
    619Tundra likes this.
  13. Nov 8, 2019 at 4:58 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I'm running 295/70/18 with no lift. Tire can rub skid plate at full lock. Little trimming could possibly fix that. I plan to lift/level but had to put these on due to a road hazards on stock 20's.
    the red likes this.
  14. Nov 8, 2019 at 5:58 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    I see that you have Yokohama A/T Geolandar. How do you like them? On road and off?
  15. Nov 12, 2019 at 7:31 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    @Tundrajoe and @Rockgate , you guys have any pics of your trucks? UCA clearance? Which wheels?
    Inquiring minds need to know!
  16. Nov 12, 2019 at 8:10 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Here ya go. I'd say there's about 1/4" to the control arm. I tried my 1-1/2" wheel spacers but rubbing would be alot worse on the outside of the tires.
    the red, Tundraman1000, Kurdt and 3 others like this.
  17. Nov 13, 2019 at 2:49 AM
    PermaFrostTRD
    Northern NY
    Nice setup. What actual tire are you running ?
  18. Nov 13, 2019 at 3:54 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Thank you. Cooper Discoverer STT Pro.
    CoachJ and PermaFrostTRD like this.
  19. Nov 13, 2019 at 6:41 PM
    Tundrajoe
    Joe
    Was 1/2 inch with cooper at3 295/70/18 now have method with at3 xlt and 1-1/4
  20. Nov 14, 2019 at 7:22 AM
    Mdjamesd
    Mdjamesd New Member
    Thank you guys!
  21. Nov 14, 2019 at 7:28 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I got 5100s all they way around with the front set at top. Running TRD 18" rims with 305/65/18 no rubbing at all.
    PermaFrostTRD and roy2015[OP] like this.
  22. Nov 14, 2019 at 7:44 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    This looks mighty good. I said I'd wait to buy new tires as the truck is brand new as of Saturday, but I'm enjoying the look/size of the tire on the TRD rims. Got the TRD package (suspension upgrade). Think this will work with these tires? Not sure of your setup exactly.
    Also was going to upgrade the UCAs just because I had JBAs on my jeep and loved them. But for the time being is it necessary with your setup? Also how bad of a hit did you take to your MPG and power? Ive never gone up in tire size without regearing but dont know if I want to pay for all that yet.
    Rockgate[QUOTED] likes this.
  23. Nov 14, 2019 at 11:44 AM
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    I'm running 285/70/18 Nitto Ridge Grapplers on the stock TRD OR wheels. I put Bilstein 6112's up front on the 1.9" setting. I had to trim the skid plate just a little as the tires rubbed on full lock but that's it.
    tonynw318, EN2TUNDRA, Crews44 and 3 others like this.
  24. Nov 14, 2019 at 3:24 PM
    PermaFrostTRD
    Northern NY
    Spacers?
  25. Nov 14, 2019 at 3:42 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    My truck is stock height. I have the TRD Sport package. To my knowledge,, our trucks should be the same height. Just cruising I've lost about 2-3 mpg, but I'm still enjoying hearing my BAMuffler. Power loss doesn't feel that much because I don't push the truck hard all the time. Regearing I don't think it's necessary with these tires. They are heavy though.
    Ckatz53[QUOTED] likes this.
  26. Nov 14, 2019 at 4:36 PM
    Jota21
    Jota21 New Member
    just my opinion, but those 18's look sooo much better than the 20's! Still surprised you could fit them on stock trds without any lift/spacers. Think it's just the specific tire design? I'd love to hear from someone with Nitto RGs or any other brand/models.
    Did you notice a significant drop in MPG going to the beefier tire? I'm on the 275/65/18 with the same TRD wheels and even my wife thinks they look a little flimsy. But my current driving is already about 12mpg commuting (15-16 highway) and would hate for that to suffer much more...
  27. Nov 17, 2019 at 4:37 PM
    computeruser6
    Dirk
    Escondido
    They're quiet, durable, and do well off-road except in thick mud. The tread wear is also great. I would highly recommend them unless you need a more aggressive tire.
    Iowa12tundra[QUOTED] likes this.
  28. Nov 28, 2019 at 4:21 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    @Kurdt. Do you have a front and side pic of your Tundra you can post? I noticed you blacked out the front and rear bumper. Did you use Plastidip? What did you do with the grille? I have the same Tundra in Cement
  29. Nov 30, 2019 at 2:57 PM
    Kurdt
    Kurdt New Member
    Austin TX
    here is a front and rear view. I took the bumper caps off and had them powder coated. It costs less than the plastic bumper cap overlays you can buy, and looks better IMO. However it does take more effort and time.
    I did not do anything with the grill itself, but purchased a hood bulge and surround in cement color and replaced those.
    drobb likes this.
  30. Nov 30, 2019 at 3:04 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    Thanks buddy. So just to understand this correctly. You had a chrome bumper caps and you had them poderp coated ? Also, did you buy the hood buldge and the surround with out the grill or did the surround come with the grille? Do you buy the surround and the buldge painted already or did you have to paint it ? If you bought them painted already, does the color match perfectly? Thanks buddy for the help .I'm buying to get rid of the chrome and any input will help
