How to Contain Oil When Draining
Discussion in 'General Tundra Discussion' started by lehminh, Oct 9, 2016.
  1. Oct 9, 2016 at 11:44 AM
    lehminh
    lehminh [OP] New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Just did my first oil change. Due to the drain plug at an angle, the oil splashed off my pan and onto the passenger side tire. I did not jack up the truck, just slid under it. Maybe I need to pu the pan all the way up next to the drain? What method to u guys use when drawing the oil to reduce splashing?
  2. Oct 9, 2016 at 11:47 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Put some blocks under the pan. Works for me. I have a flat dolly I put together that way I can just roll the pan out. No muss no fuss
  3. Oct 9, 2016 at 11:49 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Is it @csuviper that has the bad ass hose attachment thing? Didn't I see that in your build thread once? If I am remembering correctly when I change my oil next I'm doing that.
  4. Oct 9, 2016 at 12:16 PM
    Mike Tread lightly.
    south carolina
    Fumoto only way to go, use a union (don't remember the size) and piece of rubber hose to transfer to container of your choice. But the messy part is still the oil filter..
  5. Oct 9, 2016 at 12:46 PM
    TNTundra08
    Blake
    2008 DC 4x4
    mine always hits the cross member and splatters all over me, my driveway, my wheels, and brakes. Id you, or at least for me, do the oil filter with that plug nozzle thing it's perfectly fine and empty when i take it off.
  6. Oct 9, 2016 at 1:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Fumoto drain valve on Amazon it is
    TNTundra08[QUOTED] likes this.
  7. Oct 9, 2016 at 1:39 PM
    lehminh
    Oil filter is not a problem as you can use a 1qt or soda bottle with the drain adapter to collect the oil.
  8. Oct 9, 2016 at 1:56 PM
    lehminh
    Which PN of fumoto?
  9. Oct 9, 2016 at 9:34 PM
    lehminh
    Thanks, that looks like F-103N. I wish I knew about this so I would've installed it on my 1st oil change. Now I gotta plan to put some kind of shield to deflect the oil downward toward the pan on my next change. I'll get one for my Prius as well.
  10. Oct 10, 2016 at 5:58 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Literally just watched the dealership do the first oil change. I normally don't like this, but 25k of oil changes and tire rotations can't be scoffed. The tech there used a piece of aluminum, v shaped and about 1 foot long, like a gutter. Neat's a treat. Simple. Clean. No need to remove the little drain plug thing from the filter either. Oil just ran down the gutter and into the collection pan. Sometimes the simple fixes are the best He also had a nice spray bottle of brake cleaner that cleaned the little messes up nicely. Needless to say, I learned something.
  11. Oct 10, 2016 at 5:59 AM
    Krohsis
    Krohsis New Member
    2016 Toyota Tundra SR5 CrewMax, 5.7L, Red
    I love the Fumoto, had one on the semi tractor we towed our 40 fifth wheel. It took 11 GALLONS of oil, so being able to turn off the flow at oil changes was handy. So, does anyone know how far the threaded end of the Fumoto sticks into the pan? That will reduce the amount of oil that will drain out. Just curious. Also, are you guys that are running a Fumoto using a hose clamp to prevent a rock, etc. from opening the valve on the road?
    NewImprovedRon likes this.
