How to break in a new engine
Discussion in 'General Tundra Discussion' started by Tracker, Jan 22, 2016.
  1. Jan 22, 2016 at 8:18 PM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Lots of different opinions on proper ways to break in a new engine. Let's begin the discussion. I have always heard to do a 5k mile break in consisting of smooth driving at constant fluctuating speeds with no hard driving. I have also heard to not be shy and lay into it in the early stages. What do you guys have to add :popcorn:
  2. Jan 22, 2016 at 8:33 PM
  3. Jan 22, 2016 at 10:14 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Toyota says after 6 months or 5000 miles. I have to think that if it was a problem, they would recomend the first oil change sooner????
    I have 4000 miles and honestly i dont think i am worried about it.
  4. Jan 23, 2016 at 10:11 AM
    I would just drive normally. I wouldn't take it too easy or dog it at first, and stick with Toyota's maintenance schedule. I'd probably check my oil dip stick each week, look over the engine real good for any leaks. Maybe even crawl underneath for a look see too.
  5. Jan 23, 2016 at 1:34 PM
    I tested it on/off for a couple of weeks to become familiar with its and my comfort levels, then backed off a great deal and drive it like I normally would
  6. Jan 23, 2016 at 5:05 PM
    Not 100 % on the correct way to break in your 5.7L, but pretty sure this is not the right way: [​IMG]
  7. Jan 23, 2016 at 5:15 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Stick under 55 for the first 50 miles. Dont accelerate too hard. Drive normal but don't be hard on it. Change the oil and if your really wanting to be protective change differential oil in 500-1000 miles to clear out any metal flakes.
    Bob and Black Wolf like this.
  8. Jan 23, 2016 at 5:31 PM
    I recently had my rear diff gear oil changed at 63K. I have extensive maintenance records on my truck from day #1. 100% sure that rear diff oil was never changed until recent service. There was barely any noticeable metal fragments on magnetized plug and gear oil was still pretty much clear. Not bad for a 9 year old Tundra. That being said, if I had a new Tundra, I would probably change out the gear oil at 1K for a look see. Doesn't cost that much.
