How to add blind spot sensors?
Discussion in 'Lighting' started by 2020 TRD Sport, Mar 3, 2020.
  1. Mar 3, 2020 at 1:22 AM
    2020 TRD Sport
    2020 TRD Sport [OP] New Member
    Bought my 2020 TRD Sport and am looking to add some sort of blind spot monitors! What has worked for you?
  2. Mar 3, 2020 at 1:39 AM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    Didnt yours come with bsm? Check your mirrors. My 2019 sport came with the option
    2020 TRD Sport[OP] likes this.
  3. Mar 3, 2020 at 1:56 AM
    2020 TRD Sport
  4. Mar 3, 2020 at 2:15 AM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Not sure my 2020 limited came with them !
  5. Mar 3, 2020 at 2:31 AM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Huh. I thought it came with all sports. Guess not
  6. Mar 3, 2020 at 4:15 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    By the time you buy the mirrors, add the wiring needed, buy the sensors, program the ecu for functionality....don’t know if it’s worth the trouble. That is if you even have the necessary wiring and plugs in place from the factory.
  7. Mar 4, 2020 at 10:08 PM
    Greywind Tundra
    Greywind Tundra New Member
    Stephen
    San Diego, CA
    2020 Cement Tundra TRD Off-Road CM
    My 2020 TRD off road came with it but only worked when I turned it on through the speedometer menu.....but mine has the little indicator on the mirror that I don’t see in yours.....
  8. Mar 5, 2020 at 3:38 AM
    Burdturger
    Burdturger New Member
    I recall seeing a member had a system installed that involved small cameras on the side mirrors that projected to a new rear view mirror. Sweet set up and probably pricey but a better way to do it aftermarket imo.
  9. Apr 11, 2020 at 3:19 PM
    Zeus1090CSM
    Zeus1090CSM New Member
    2015 4x4 Blue SR5
    I am about to install a side view camera that will turn on with the turn signal. Once they get here I’ll take pics and give a write up on them.
  10. Apr 11, 2020 at 3:41 PM
    2020 TRD Sport
    Wow!!! That’s awesome. I need to stay in the loop on that one
  11. Apr 11, 2020 at 4:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you get it figured out and need the sensors, I’ll have my takeoffs for sale. Also have the bumper corners in Silver Sky.
  12. Apr 11, 2020 at 5:04 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    I turned mine off and turn my head before changing lanes.
  13. Apr 11, 2020 at 5:06 PM
    timsp8
    NY
    Get the tow mirrors with the wide angle mirror on the bottom. It’ll be cheaper than adding bsm mirrors if you don’t have the wiring.
