How to add bed tie downs with no rail system?
Discussion in 'General Tundra Discussion' started by IowaGuy, Apr 2, 2022.
  1. Apr 2, 2022 at 12:12 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am disappointed that my SR5 doesnt have the bed rail system or any real tie downs in the bed - how can I add some? I really do not want to add the rail system due to the cost and I already have a tonneau cover that fits. It is kinda a strange idea but I thought about adding the Ford bed cleats like the attached picture. The for cleats just drill and tap in but I do not know if the Tundra bed is strong enough to support them. Is there anything similar made for the Tundra?
    FORD_F150_Raptor_Bed_Tie_Down_Bracket_Ronin_Factory_with_cleat_with_Logo_1800x1800.jpg
  2. Apr 2, 2022 at 12:16 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    If I needed additional tie downs but didn’t want to spend the money on the factory rail system, I would add some D-loops to the bed bolts or to the factory rail mounts. The threads that the rails are supposed to mount to are M6 x 1.0. If you get some screws that size at Home Depot for a couple bucks, you can mount any D loops you want for cheap. I wouldn’t go any longer than 20mm or an inch on the screws.
  3. Apr 2, 2022 at 12:17 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I have seen a lot of guys use unistrut, you can get it at a home improvement store and it is just as if not stronger than the bedrail system
    NewImprovedRon likes this.
  4. Apr 2, 2022 at 12:28 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I agree with this.
    A combination of D-loops at the bed bolts and smaller ones along the side using the factory tapped holes for the bed rail.
    That will give you a lot of options.
  5. Apr 2, 2022 at 2:40 PM
    IowaGuy
    In Process
    How many rail mounting holes are there supposed to be? I only have two small holes front and back at the top near the bed cap.
  6. Apr 2, 2022 at 2:44 PM
    Terndrerrr
    Music City
    6UR-FE
    There are 4 or 5 on each side. If you have a bedliner, the ones you can’t see are hidden under it. Get a screwdriver and press onto the bedliner in line with the two holes you can see. You’ll find them easily.
    Get some of those Home Depot screws and some of these fixed D loops, and you’ve got a lot of options for tying things down.
  7. Apr 2, 2022 at 8:35 PM
    2mchfun
    You could do stake pocket anchors as well. Much stronger than the D loop idea.
  8. Apr 2, 2022 at 8:38 PM
    2mchfun
    Your bed cover might be mounted to some of what were the factory rail holes.
  9. Apr 2, 2022 at 10:16 PM
    Terndrerrr
    Music City
    6UR-FE
    That’s a possibility for sure. It would require drilling new holes in the bed.
    I haven’t seen any that utilize those threaded holes. Most bed covers just don’t play nice with the factory rails because the rails sit right at the top of the bedsides, and they’re in the way of the clamps that hold the bed covers down. But where an entire rail won’t play nice with a bed cover, a few D loops mounted with M6x1.0 screws on each side would play nice. Plus it would cost a total of $20 and require no drilling anywhere.
    I used the same screws and factory threaded holes for my homemade shovel and axe mounts under my bed cover.
  10. Apr 2, 2022 at 10:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The factory rail system is less than 200 bucks shipped. One of the few oem parts not aggregiously overpriced
  11. Apr 3, 2022 at 6:58 AM
    2mchfun
    Idk, many stake pocket anchors I used just expanded inside the pocket, no drilling necessary. However, it is necessary to cut the square out of the plastic bed cap. As for the rails, the top of mine are a good inch below the plastic cap. My bed cover velcro surfaced rails sit on top of them and clamp to them too. So, the bed cover is almost flush with the bed cap. Maybe, mine is different from yours since I have Trail edition bed boxes.
    Terndrerrr[QUOTED] likes this.
  12. Apr 3, 2022 at 8:02 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Bakflip will send simple relocation brackets and hardware for lowering the side rails about 2.5".
    Was one of my requirements while shopping for a folding, hard tonneau as I wanted to retain the tie-down system.
    One could easily mimick the kit with steel brackets, M6x1.0 bolts, and some flat washers.
    If I were more focused on trail goodies and less so on convenient hauling ability, I would do a custom unistrut system for mounting recovery equipment on the bedsides.
  13. Apr 3, 2022 at 8:06 AM
    IowaGuy
    In Process
    I have a Tyger soft flip bed cover that uses lever clamps to clamp down under the bed rails to secure it. I also have spray in bed liner and I dont know why they covered up some of the holes but not others.
  14. Apr 3, 2022 at 8:14 AM
    COTundie
    Trey
    Pretty things
    Yeah. The covering of the mounting holes was kind of a dick move.
    I would explore with a small pick, as you should be able to locate the centers and puncture the sprayed liner. Then a de-burring bit would probably be useful open them up the rest of the way without damaging the threads... tho an M6 tap would probably be good to have on hand anyway.
    What bed length are you working with. I've got a DC with 6.5' bed and would be happy to give you approximate locations
  15. Apr 3, 2022 at 8:16 AM
    2mchfun
    IIRC, you bought the truck used, maybe the previous owner(s) wanted to keep some of the holes accessible for some reason such as clamping down a shell or a custom DIY bedrack. Doesn't really matter since the ship has sailed. Like others said super-strut is a great alternative choice for securing loads under cover, but stake pocket anchors would be superior for strapping down something heavy like a motorcycle or similar when the cover is open.
  16. Apr 3, 2022 at 8:28 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    If I were not in a place where salt and brine were sprayed on the roads, I might consider drilling and adding the E-Track tie-down system. I use the single mount slots and O-rings on my trailer for securing the motorcycles and tractor. Rather handy system.
    https://www.etrailer.com/s.aspx?qry=E+track&furl=-pg-E~Track
    2mchfun likes this.
  17. Apr 3, 2022 at 8:34 AM
    COTundie
    Trey
    Pretty things
    E-track is great!
    But the factory system is much more low profile. Makes it easier to mount, takes up less of your bed, and adjusts to infinite positions.
  18. Apr 3, 2022 at 8:49 AM
    IowaGuy
    In Process
    I have the short bed and I occasionally haul an appliance or furniture for friends and what not. I am also wanting a good secure anchor to lock my camping generator into with a cable. Right now I have 2 sets of the smaller hooks in the front and the back at the bottom of the bed. I found these on Amazon and might give them a try after locating the holes.
    Terndrerrr likes this.
  19. Apr 3, 2022 at 9:28 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    I'm not sure about low profile or taking up less room. The t-track system is nice, but really in the wrong place for loads that at less tall than the bed, which, with a Diamondback cover, is all of them. There really needs to be lashing points low on the bed walls and in the bed. I have considered locating a few of the single point track mounts in strategic and structurally sound locations. One possible location:
  20. Apr 3, 2022 at 9:54 AM
    Terndrerrr
    Music City
    6UR-FE
    They really are easy to find. If you just poke a hole with a punch or even with a Phillips screwdriver, you can get those screws to thread easily. I left the holes very small so that the heads of the screws cover them up and form a seal over the hole in the bed liner. Rather than having a big hole cut in the bed liner for rust to start. Here’s the hole almost at the very end of the bed. Mine were hidden under the bed liner, too:
    I decided not to use the relocation brackets to lower my factory rails out of the bed cover’s way. Seems like if you tighten a strap too much, you could bend those bars. Here you can see my bed cover clamps and my homemade axe/shovel mounts. The factory bed rails are in the way of these clamps, but you can easily put some fixed D loops in these threaded holes:
  21. Apr 3, 2022 at 5:18 PM
    COTundie
    Trey
    Pretty things
    Didn't even consider a single. I actually quite like it. Thought you were suggesting a length of the e-track along both bed sides to mimick the factory rails.
    Definitely low profile enough for loading and unloading of objects.
    DZ_[QUOTED] likes this.
  22. Apr 3, 2022 at 5:20 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Bed D Rings. Just need to grind the washer and make a straight edge so it lays flat.
    2mchfun and DZ_ like this.
  23. Apr 3, 2022 at 6:50 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  24. Apr 3, 2022 at 8:01 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^^^^This^^^.....works great
  25. Apr 29, 2022 at 5:24 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Great ideas. In terms of the pocket anchors. I think they are to far off from where you want to get the anchor your stuff. The pocket anchors being at the edge.
    I do think that the bed drings are good but I have a plastic tub so that may not work. But OP it would be good to see what you finally got working. Please post pictures and item list when you are finally done.
    IowaGuy[OP] likes this.
  26. Apr 29, 2022 at 2:24 PM
    IowaGuy
    In Process
    I have kinda procrastinated on this project as I am waiting until I need to haul something so I can cuss when I dont have enough tie downs.
    DZ_ likes this.
  27. Apr 29, 2022 at 3:30 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    That way, you'll truly appreciate it when it's done.
  28. Apr 30, 2022 at 5:51 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    Shallow unistrut is super easy to mount using the factory rail locations.
  29. Apr 30, 2022 at 6:18 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  30. Apr 30, 2022 at 6:26 PM
    Hotwire
    Hotwire New Member
    Montana
