How tires and suspension raise clearance and height
Discussion in 'Wheels & Tires' started by Hellrazor, Mar 17, 2023.
  1. Mar 17, 2023 at 1:15 PM
    Hellrazor
    Hellrazor [OP] New Member
    Hi all,
    I am getting some conflicting info from some tires and suspension places. Currently have 2018 Sequioa w/ stock suspension, sherpa roof rack and RTT. As of now I can fit into my garage with about 1 inch clearance.
    I am thinking about upgrading to some AT (275/70/18 =33) currently have 275/65/18 = 32 inch. So my understanding is with the new tires I would gain 1 inch in clearance but would that increase my height?
    Second question, thinking about getting Bilsteins 6112 for the front and 5100 for the rear. The minimum lift would be 1 inch.
    So lets say I get the bilsteins and set the lift to 1 inch + the increase in tires 1 inch (32 inch to 33 inch), does my car
    1. Increase the bottom clearance by 2 inches?
    2. How much of my height clearance would I gain?
    Also, has anyone air downed on their tires and notice a drop in height. I am hoping I can get the bilsteins + tires and if needed air down 1 inch to fit into my garage to store my RTT.
    Thanks in advance.
  2. Mar 17, 2023 at 1:17 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Your height will increase by 1/2 the increase in tire size and in direct relation to your increase in lift height.
    A 2” lift with 1” bigger tires = 2.5” overall increase in vehicle height.
    Ponderosa_Pine likes this.
  3. Mar 17, 2023 at 1:17 PM
    Adding an inch of lift, gives you an inch of additional height. Adding an inch of tire only gives you a half inch of additional height.
  4. Mar 17, 2023 at 1:19 PM
    Ground clearance comes from bigger tires. Lift won't change it. You also only gain half the tire size increase. Going from 32" to 33" you will see 1/2 of increased height because you get a half inch on the bottom of the tire and a half an inch on top.
  5. Mar 19, 2023 at 12:21 PM
    Hellrazor
    Thank you so much for helping out appreciate it.
