How the hell does a mouse get in the cab?
Discussion in 'General Tundra Discussion' started by Ericsopa, Aug 16, 2016.
  1. Aug 16, 2016 at 5:44 PM
    Ericsopa
    Ericsopa [OP] Old man and the sea
    Anybody have any idea where to start looking to keep mice out of the inside of my CM? The door seals are all intact, the filter for the HVAC hasn't been chewed through. I don't know how the sucker gets in. But he tore up a bunch of kleenex from a box under the seat, looking to make a nest, I presume. And not really sure there's any way to prevent it from getting in. But I'm open to suggestions. Right now I've just put out 8 traps all over the garage. Mostly by the doors.
  2. Aug 16, 2016 at 5:47 PM
    Not this way:[​IMG] This way: [​IMG]
    ColoradoTJ likes this.
  3. Aug 16, 2016 at 5:47 PM
    Mike Tread lightly.
    south carolina
    Check all the rubber boots/ drain holes, under the cab, back side of the cab and in engine compartment...
    They like to chew on the rubber at times I guess it's soft..
  4. Aug 16, 2016 at 6:08 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I had one get in a Corolla I had, couldn't figure out where it got in. The thing died somewhere in the dash, never found it. Stunk for a while, no fun.
  5. Aug 16, 2016 at 6:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Those suckers are very small and can fit in amazingly small places. Don't do poison or you will end up with a dead one in the dash like Mototundta. Traps for getting rid of them is correct. Not sure how to prevent them getting in the truck.
  6. Aug 16, 2016 at 6:18 PM
    Mike Tread lightly.
    south carolina
    I have a 24 pound Himalayan you can borrow...
  7. Aug 16, 2016 at 6:55 PM
    Ericsopa
    Yeah.....I need a good mouser, for sure. I live in the country.... little gray field mice everywhere.
  8. Aug 16, 2016 at 7:16 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I had a cat that liked to use his carrier as a litterbox. Pee only, fortunately. We had a towel in there and kept the door open so the cat would get used to it. We noticed the smell from the carrier about the same time we heard some scratching from the attic. I took the urine soaked towel out of the carrier and threw it in the attic. The scratching stopped and hasn't returned (knock on wood). You can find fox urine at most feed stores and some hardware stores. If you don't have a cat that will pee on command, a little fox urine on a rag under the truck might chase the critters away.
  9. Aug 16, 2016 at 7:38 PM
    Okie
    Okie I'd rather be fishing!
    Patrick
    Tecumseh, Oklahoma
    2016 Black Tundra Crewmax
    Ok this sounds weird to city folk;) but seriously pee around your vehicles, boats and campers. My grandpa has practiced the method for decades and his son and me-all the while we've never had a critter get in. Proceed with caution if you live in town.
  10. Aug 16, 2016 at 8:28 PM
    Ericsopa
    All righty.....thanks folks. Lots of thing to try here. Garage is a separate metal outbuilding.....impossible to keep the little varmints out, but I try to keep 'em under control, and out of the vehicles.
  11. Aug 16, 2016 at 8:30 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    He kids you not. This also works to keep foxes away from the chickens.
  12. Aug 16, 2016 at 9:14 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    "Mice can easily find their way indoors. An adult mouse can squeeze through a gap smaller than ½ inch and young mice can gain entrance to buildings through even smaller openings."
    Found this on a website
    NewImprovedRon likes this.
  13. Aug 17, 2016 at 4:17 AM
    FumundaTundra
    FumundaTundra Director of civil unrest
    Wayne
    Central WA.
    2009 5.7 Tundra Double cab
    Many to come.
    Bob likes this.
  14. Aug 17, 2016 at 10:04 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can confirm that caution is advised. Community Service time made sure that I didn't forget.
    Black Wolf and NewImprovedRon like this.
  15. Aug 17, 2016 at 10:57 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Have you checked the outside rear of the cab to see if they've chewed through the oval plastic covers?
  16. Aug 17, 2016 at 11:04 AM
  17. Aug 17, 2016 at 1:38 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    That's a lot of pee to make a full circle around a truck. Nothing a couple beers couldn't fix.
    mdavis and NewImprovedRon like this.
