How much trimming to fit 35's with a Coach Builder kit on stock rims with no spacers?
Discussion in 'Wheels & Tires' started by Bigrobdsp, Jan 9, 2019.
  1. Jan 9, 2019 at 12:26 PM
    Bigrobdsp
    Bigrobdsp [OP] New Member
    Robert
    2008 SR5 and 2019 TRD Pro tundra
    TBD
    How much trimming is necessary to fit 35's with a Coach Builder kit on stock rims with NO spacers? I have broken a spacer in the past and wont use one again, but I like the stock rims and I like the look of a 35. I used the search but there is so much info on similar questions that I cant find what I am looking for.
  2. Jan 9, 2019 at 12:27 PM
    Bigrobdsp
    Robert
    TBD
    sorry, on the 2019 TRD pro, not the 08.
  3. Jan 14, 2019 at 7:12 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    My understanding is that the width is the main problem with 35s. What brand did you break? I am about to install Bora spacers and put 35x12.5r18 (stock trd pro rims 2017)
  4. Jan 14, 2019 at 7:17 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    A 35 might hit the UCA without spacers? :notsure: The 2 trustworthy spacers are Bora and Spidertrax. Did you break one of those?
    GodlessPro and joonbug like this.
  5. Jan 14, 2019 at 8:09 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
  6. Jan 15, 2019 at 8:10 AM
    Bigrobdsp
    Robert
    TBD
    I had a rugged ridge (Summit racing brand?) spacer break and nearly had a wheel fall off on the highway with wife and kids in the car. I was able to make it off the road, but had snapped 4 of the 5 spacer lugs (best way I can think to describe the lugs attaching the wheel to the spacer)I had always been told not to use spacers or adapters ever, but read enough on the internet about people using them that i made myself comfortable. im sure there are better brands available, I just dont want to use another spacer. I appreciate all the replies.
    ROB
  7. Jan 15, 2019 at 7:40 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Please keep me posted as I am wanting to do the same. 35s on stock wheels with PRO suspension. Would like to know how much trimming is needed
    AZTundra likes this.
  8. Jan 16, 2019 at 7:04 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Some people have to do a CMC and some say you dont. I ordered a Coach Builders Kit and Im going to have a local shop do a CMC since I dont want to have issues off roading.
  9. Jan 22, 2019 at 12:37 PM
    SK_Tundra
    Stockton Ca
    Are u using wheel spacers on all 4 wheels?
  10. Jan 22, 2019 at 12:48 PM
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    Well I just put down my Die Grinder to eliminate my rubbing issue. I am a bit higher after a 3" lift from @Toytec Lifts but I went with 35x12.5x20 and after removing all the front plastics i still had to grind about an 1/8 off the bottom of front bumper. Would only rub in reverse but now that is fixed. The shop that installed my lift destroyed one of my plastics.. so waiting on the replacements before I attempt to heat and bend them back in place.
  11. Jan 23, 2019 at 7:38 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I ordered 4... I didn't want the stance to be weird.
  12. Jan 24, 2019 at 5:22 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    3” lift with 285/65/20’s at +18 you’re good with just trimming about an inch off the front well piece behind fogs.
  13. Mar 21, 2019 at 1:41 PM
    SK_Tundra
    Stockton Ca
    Any update on this?
  14. Mar 21, 2019 at 1:45 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I installed bora 1.25 spacers and 35x12.5 and there is no rubbing on the frame.
  15. Mar 21, 2019 at 1:47 PM
    SK_Tundra
    Stockton Ca
    Any pics? And what tire are u running?
  16. Mar 21, 2019 at 1:51 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    What are you looking for specifically? 35x12.5r18 BFG K02 I had to remove the mudflaps 52029184_2406774712666695_1279741400547590144_n.jpg
  17. Mar 21, 2019 at 1:55 PM
    SK_Tundra
    Stockton Ca
    Just generally how the 35s look on stock wheels with the spacers. I have a set of 35 nitto trail grapplers sitting in the garage since Christmas. Haven’t found the aftermarket wheels I want yet so I might just throw them on the factory wheels.
  18. Mar 21, 2019 at 2:00 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    SK_Tundra[QUOTED] and rons23 like this.
  19. Mar 21, 2019 at 2:01 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @Bigrobdsp, just to give ya another angle on this. I have 295's which are 11.6 " wide. There's about 3/4" between tire and UCA. You definitely would need to go with aftermarket rims +18 - 25 is a great start. I have Spider Trak 1 1/4" spacers with no issues, but I definitely understand your concern. One of our suspension lift guru's will chime in I'm sure. The 295 is only 0 .4" smaller in diameter, not much, but a 1" narrower than the 35. Good luck
    SK_Tundra likes this.
  20. Mar 22, 2019 at 9:54 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    You would have to drop a Spidertrax spacer from outer space to break it, and even then...
  21. Apr 11, 2019 at 8:05 AM
    LiftMeUp
    LiftMeUp New Member
    What issues you think I may have with same size tire but on stock rims, lifting front 3"?
  22. Apr 11, 2019 at 8:10 AM
    LiftMeUp
    LiftMeUp New Member
    I'm looking at installing a 3" lift on front and want to install 28/65/20s. So width is about 11.2. I was concerned about rubbing the UCAs, anyone think that will be a problem or should be able to clear with that width?
    Also, is there anything else that will need to be done, skid pate, etc?
    I'd rather stay away from spacers if possible.
  23. Jul 12, 2022 at 9:03 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    It’s not the spacer that breaks it’s the lugs. Had a tire fly off on the FJ. G2 brand. Swore them off but about to put a coachbuilder kit on it says “required” with stock wheels. It might keep me from buying the coachbuilder kit all together is this is truly the case.
    i think the spacers are required for coachbuilder kits with no other mods to run 35s. But if you have different UCA, BMC done and trim some plastics i think you don’t need the spacers. Maybe Dave can chime in.
  24. Jul 13, 2022 at 9:53 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    35x1250 will hit the UCA if using stock +60 wheels. Metric 35s. 285/75-18 fit better and will clear the UCA.
    Luke_Skywalker likes this.
  25. Jul 13, 2022 at 5:14 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've never heard anyone recommend G2 spacers. Spider Trax and
  26. Jul 13, 2022 at 7:48 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    You probably never will. I guess a lot of Jeeps run them but F*** that. They literally shredded. What a joke of a company. That being said, ive also never heard anyone say they had issues with their spidertrax or Bora. I was young when those spacers went on, didnt know shit about trucks/cars, and let someone other than myself (Americas Tire) install them. They fucked everything up, and ended up paying me for it.
