How much taller would 20" vs 18" wheels make a Tundra?
Discussion in 'Audio & Video' started by OddJack, Jul 18, 2024.
  1. Jul 18, 2024 at 6:14 PM
    OddJack
    OddJack [OP] New Member
    Dino
    Thinking about swapping 18s to 20s
    How much taller would it be?
  2. Jul 18, 2024 at 6:17 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    0”. It all depends on the tire size. Stock 275/65 18 is essentially same size as a stock 275/55 20.
  3. Jul 18, 2024 at 6:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Here ya go:
    OddJack[OP] likes this.
  4. Jul 18, 2024 at 6:21 PM
    Cthulhu
    Rim diameter does not determine height. Tire diameter does. :thumbsup:
    OddJack[OP], Wynnded and RobertD like this.
  5. Jul 18, 2024 at 6:23 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    As already mentioned, wheel size doesn’t change anything.
    But if you go from 33” tires to 35” tires, your truck will be 1” taller.
    The 35s are 2” taller than 33s, but only one of those inches sits between the axle and the ground. ;)
