How much taller can I go without running into problems?
Discussion in 'Wheels & Tires' started by Gak, May 2, 2016.
  1. May 2, 2016 at 5:44 PM
    Gak
    Gak [OP] New Member
    2016 Tundra SR5 Black Tss
    I'm fixing to have my front leveled, I'm running 285/55/20s now. Don't want to go wider, taller is my vision. So how taller can I go without running into problems?
  2. May 2, 2016 at 7:00 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    With a 3/1 level I'm running 285/65/R20 KO2's. This is a 34.6" tire. No rubbing, no cutting. Taller than that and I think you are going to be cutting body mounts, splash guards, wheel-liner plastic in some combination.
    Its good you're not going wider because you'd then need some spacers or different than stock wheels to avoid rubbing the UCAs.
  3. May 2, 2016 at 9:58 PM
    true 35" tires would fit fine too..with the proper wheel offset.
  4. May 3, 2016 at 7:46 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Couple questions.
    What is your budget for the lift?
    Are you planning larger tires?
    Are you planning to get different wheels?
    You said you don't want to go wider so I assume no new wheels with different offset and wheel spacers are out of the question.
  5. May 3, 2016 at 6:20 PM
    Gak
    Gak [OP] New Member
    My budget for lift and tires, I'm hoping to stay with my 20in wheels, is around $2,000.
  6. May 3, 2016 at 6:25 PM
    Gak
    Gak [OP] New Member
    Are you satisfied with the look? 285/65/20, does it look to skinny, like I said don't want to do any cutting or spacers.
