How much rear lift from 1 inch block?
Discussion in '1st Gen Tundras (2000-2006)' started by Ricky7, Jan 14, 2021.
  1. Jan 14, 2021 at 10:10 PM
    Ricky7
    Ricky7 [OP] New Member
    I have a 2006 Tundra Double Cab 4x4 that is currently leveled. I want to do a small lift in the rear (no more than 1 inch) and was wondering how much actual lift do you get from a 1 inch block? Should I use 1/2 inch shims instead? Any replies on your experiences with your 1st gen Tundra would be greatly appreciated.
  2. Jan 14, 2021 at 10:18 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I can't stress this enough....don't quote me here but I believe a simple block in the back will be 1:1. The front leveling pucks are generally not 1:1 due to suspension geometry. I wouldn't use the shims, I'd just get a taller block and have just one piece sitting in there. What size block do you currently have?
    Darkness likes this.
  3. Jan 14, 2021 at 10:20 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m no engineer, but if you stand on a 1 inch block you too would be 1 inch taller
    honda50r, Voss, tvpierce and 6 others like this.
  4. Jan 15, 2021 at 4:23 AM
    Professional Hand Model
    Hand Protectors
    But didn’t you sleep at Holiday Inn?:rofl:
  5. Jan 15, 2021 at 5:20 AM
    As mentioned, on the rear, 1 inch block =1 inch of lift.
    Tundyfundy likes this.
  6. Jan 15, 2021 at 7:15 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    One other thing to consider is if your rear shock can accommodate the additional inch when fully extended. If not, there is a potential of topping out, which may lead to the shock breaking at its weakest point. If you don't go wheeling then this is not too much of an issue.
    honda50r, Tundyfundy and Glock 40 like this.
  7. Jan 15, 2021 at 11:49 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Is this one of those trick questions?
  8. Jan 16, 2021 at 8:52 PM
    Ricky7
    I know this may seem like a dumb question but this is the first truck that I've lifted and I didn't find anything in the forums that really answered my question. I put on the Bilstein 5100's on my truck with the front set on the 4th notch. (According to Bilstein it's supposed to be 1.6" but it actually lifted it 2") Which is why I asked this question, I didn't know if I was gonna have the same effect on the rear. Thanks for the replies.
  9. Jan 17, 2021 at 5:38 AM
    Hand Protectors
    You’ve done good Ricky. Stick around and share your work with some pics.
    Just a heads up that some Front Coils on our trucks are the TRD Package and may give differing results in heights. If you have Aftermarket Coils, that changes things as well. Seems like lifts/etc isn’t exact science, but more of an Art on our trucks.
    artsr2002 likes this.
  10. Apr 14, 2021 at 11:33 AM
    Ricky7
    Got it done, just stock tires on it but I’m happy with how it looks.
  11. Apr 14, 2021 at 11:39 AM
    Looks great. Like the rims, don't see those on FGT's much. Welcome aboard!
    Darkness and Ricky7[OP] like this.
  12. Apr 14, 2021 at 11:47 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That does look great
    Ricky7[OP] likes this.
  13. Apr 14, 2021 at 11:49 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Is this a common core math problem, and will it be on the test?
  14. Apr 14, 2021 at 11:57 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    the question on the test will be much more related to how the lift block identifies, not really on how many inches tall it is.
  15. Apr 14, 2021 at 12:02 PM
    Rex Kramer
    Georgia
    True story.
  16. Apr 14, 2021 at 12:15 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Truck looks awesome! Really like the blue.
    Ricky7[OP] and Rex Kramer like this.
  17. Apr 14, 2021 at 12:34 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    As pointed out, it's not a dumb question. Front suspensions are rarely a 1:1 ratio of spacer and lift because of the levers involved. The rear is usually more straightforward but suspension is a mystery to me in general so I'd probably ask the same question.
    Nice truck, OP!
    Darkness, Ricky7[OP] and Hbjeff like this.
