How much rear end sag with 1000lb tongue weight?
Discussion in '2.5 Gen Tundras (2014-2021)' started by FredD, Mar 8, 2019.
  1. Mar 8, 2019 at 6:32 AM
    FredD
    FredD [OP] New Member
    2016 Barcelona Red Ltd
    Hi all,
    I'm about to purchase a 10k GVWR 8.5x24' cargo trailer, with a 18" tongue height.
    Probably something like this: https://www.usacargotrailersales.co...irect-save-thousands-in-stock-now-detail.html
    I know you can get adjustable height drop hitches, but I'd rather save the $$ and get a fixed drop hitch. With a tongue weight of 1000 lbs, how much would the rear end of the Tundra sag? I'm trying to calculate the drop hitch size required for this trailer.
    I've got a 2016 Tundra DC Limited 5.7L 4x4.
  2. Mar 8, 2019 at 6:53 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
  3. Mar 8, 2019 at 7:23 AM
  4. Mar 8, 2019 at 7:39 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    If your towing that much the safe and smart thing to do is use a weight distribution hitch. Going the least expensive option isn't always the way to go
  5. Mar 8, 2019 at 7:45 AM
    FredD
    This is going to be a short term trailer use. I'm buying the trailer for a move, then selling it. Don't want to wrap up too much money into this. Also, it looks like WDH cannot be easily used on a v-nose trailer like the one I'm getting.
  6. Mar 8, 2019 at 8:04 AM
    JoshO
    JoshO New Member
    2018 Magentic Gray Tundra
    You are overthinking it. I don't think you need to worry about the sag. The trailer tounge is 18 inches off the ground. Measure to the Receiver hitch of your truck and then subtract 18 inches. That is the drop. Then when loading the trailer you move the weight around to keep it from pressing to far down on the truck or pulling to high up.
  7. Mar 8, 2019 at 9:51 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    What he said!
    What he said.
    You must consider the weight distribution in your trailer because 1000 will go up or down based upon the balance of you load. That 1000 pounds is cantalevered from the center of you axel and acts as a lever.
  8. Mar 8, 2019 at 1:52 PM
    Mwray8909
    Chino Valley
    How far are you going. Where to where?
  9. Mar 8, 2019 at 1:58 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I have a 7x16 v nose trailer I towed from Denver to Jacksonville. I used a WDH on it. With the trailer load, the trailer weighed a little north of 10k. Prior to the WDH my rear end sagged several inches. Once the hitch was on I was able to level it out with less adjustments than I expected. I did need a 2 inch drop hitch to keep it all level. I used the Fastway E2 hitch and loved it. The trailer was rock solid at all times, even with high winds. I highly recommend using it. https://www.fastwaytrailer.com/e2-hitch
    ColoradoTJ and Mwray8909 like this.
  10. Mar 8, 2019 at 2:01 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    NoMoTaco likes this.
  11. Mar 8, 2019 at 3:56 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    A WDH is the only safe way to go on a 24' trailer.
    You could sell the WDH with the trailer or separately after you move.
    18" doesn't really mean much. it will change when loaded.
    What is Empty tongue weight?
    Tongue weight is the 2nd most critical information after total loaded trailer weight.
    Mwray8909 likes this.
  12. Mar 8, 2019 at 4:06 PM
    Mwray8909
    Chino Valley
    This ^^^^^^
  13. Mar 8, 2019 at 4:09 PM
    Mwray8909
    Chino Valley
    If I recall correctly you should have 60-75% of your weight infront of the axle for a safely loaded trailer.
    Improper balance or to much weight to far back makes its 10Xs easier to fishtail and lose control.
    OBXTundra likes this.
  14. Mar 8, 2019 at 4:21 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I had a 24' trailer and hauled it with my 2500 Duramax...that trailer owned the ass end of that truck, WDH and all when loaded. I can't imagine a scenario where 1000lbs of tongue weight with a distro hitch on a Tundra makes any sense.
    You are WAY better to rent a 25' Uhaul truck. Besides, you have more shit than you think and you will need the extra cargo space of your truck;)
    Newm, OBXTundra and 1engineer like this.
  15. Mar 8, 2019 at 5:39 PM
    FredD
    I have no idea how much the trailer will weigh loaded, probably somewhere in the 6 to 8k range.
    I'm moving from MA to WI this summer.
  16. Mar 8, 2019 at 6:44 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I use a 2" drop with 5000 lb boat and it sits level. Not sure what the hitch height is on trailer. I have a lot weight towards rear and over axles. I would guess tongue weight at 8-10%. I would say use a 2" drop and turn it over for a 1" rise. Not sure what ball size is on that trailer. If a 2-5/8 then no problem. If 2" then pay attention to capacity. 2" balls can have different weight ratings.
  17. Mar 9, 2019 at 6:08 AM
    Mwray8909
    Chino Valley
    That's a VERY long trip to not have a weight distribution hitch. A few hundred to make sure you, your family, and the others on the road with you are safe is money well spent.
    kparrow and Steve89gt like this.
  18. Mar 9, 2019 at 6:28 AM
    Adam New Member
    Why don't you rent a full size uhaul and then add the car trailer to the back of it to tow down your tundra? You are going to have a lot of money wrapped up in that trailer. You would still have to sell it when you get there.
  19. Apr 22, 2019 at 8:07 AM
    FredD
    Picked up the trailer in GA last week, and made the 1000 mile trip home. I bought a Curt WD hitch with sway control, but when hauling it empty, I didn't hitch up the weight distribution bars. I didn't connect the sway control either, and it didn't need it. Hauled perfectly straight, without any noticeable sway. I'll definitely use the WD and sway once loaded, though. I ordered the trailer with an extended tongue in order to use the WD features.
    Towing it was fine - 3300lbs empty, but it did feel like towing a barn. 10.5 MPG towing.
    kparrow and Mountun Goat like this.
  20. Apr 22, 2019 at 8:42 AM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    Trailer has alot of space between the axles and the hitch. If you pack the front too heavy you will have excess tongue weight. Put most of the heavy stuff just before the trailer axles and balance the rest between the remaining front area and the rear.
    FredD[OP] likes this.
  21. Apr 22, 2019 at 9:06 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    This. ONLY safe way and you owe it to yourself and everyone else on the road to tow safely. Get a WDH with sway control and call it a day. Sell with the trailer or separate after move. Well worth the $500ish dollars it will cost you
  22. Apr 22, 2019 at 9:23 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Ive had good luck with the Andersen No-Sway hitch. They even upgraded all 3 of my hitches to their new design free of charge and they paid shipping both ways.
    The Andersen uses chains from the frame brackets to a triangle plate on the hitch. The ball and plate rotate with the trailer (so no grease or binding), inside a friction cone that acts as a brake to stop/prevent sway.
    Not enough tension? Tighten the nut on the end of the chain. Easy and quick to remove amd reinstall, and backing up straight or in turns is not an issue.
