How much lift do I need to fit 35's with my set up?
Discussion in 'Suspension' started by WhiteTundra04, Oct 26, 2020.
  1. Oct 26, 2020 at 3:04 PM
    WhiteTundra04
    WhiteTundra04 [OP] New Member
    Cole
    2017 white platinum tundra
    Hey guys, Im 16 and have saved up money in order to lift my tundra, I think i'm going to go with the Old man Emu 612 lift from Toytec. From the research I've done it seems this will get me 2.5 to 3 inches of lift. My current wheel setup is 275-60-20. I understand this alone will probably not enable me to have 35's. Im wondering what my options are to be able to have 35's or if it is too much trouble and should settle for a smaller tire? Thanks in advance!
  2. Oct 26, 2020 at 3:07 PM
    TXTundra2722
    2015 Black Tundra
    Plenty of people in 35s and 3 inch lift. Your room choice and offset is what makes the difference.
    Flyinryank and zcarpenter92 like this.
  3. Oct 26, 2020 at 4:54 PM
    Calebrichardson85
    Calebrichardson85 New Member
    I’m running 35’s on a 3” lift, you’ll have to get a heat gun to heat up the black plastic on the front bumper, then grab a basketball to gently roll the plastic deeper into the front bumper. Like the guy said about offset plays a big factor in 35’s. I have +18 offset wheels and have to remove the front mud flaps and possibly(more than likely) do a body mount chop like myself.
  4. Oct 26, 2020 at 4:58 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Lord to be 16 again....I had a 92 Toyota Pickup at 16....I couldn't keep the girls out of that thing....can't imagine nowadays with a Tundra....just saying:bowdown:
    Calebrichardson85 likes this.
  5. Oct 26, 2020 at 5:00 PM
    Calebrichardson85
    I had an fj cruiser. The back seat folded down came in handy many a times..
  6. Oct 27, 2020 at 12:59 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Like said above, all about wheel offset.
    I am running 2.9” up front with bilstein 6112 on highest settings and a 18x9 +18 offset and 35” ridge grapplers.
    I had to do the body mount chop, and heat the front plastics
  7. Oct 30, 2020 at 6:15 AM
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    I didn't have a toyota at 16, but I did fold the back seat down a few times.
  8. Oct 30, 2020 at 6:18 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    All my teachers usually had their own place.. lol
    Yotaholic likes this.
  9. Oct 30, 2020 at 6:25 AM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    Ha! I was not a player. My only girlfriend in HS was the same age.
  10. Oct 30, 2020 at 7:07 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    35" tires on rims with +25 offset will easily fit with a 3" lift.
    Just trim or remove a little plastic.
  11. Oct 30, 2020 at 8:06 AM
    dMO
    dMO New Member
    David
    2010 Black Tundra
    Toytec 3/1 leveling kit 18x9 VE37 35x12.50 Toyo RT
    I run 35s on a 3/1 leveling kit and my wheels are a 0 offset. I had to do a body mount chop and get aftermarket upper control arms to get it aligned correctly and not to rub anymore. It really comes down to your wheel offset.
  12. Oct 30, 2020 at 8:18 AM
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    As said in previous posts, offset is the key... I have a 6in Readylift, because i have a 22x12.5 wheel at -44 offset. I had to cut out a lot of plastic and body mount to fit.
