How Much Can I Haul?
Discussion in 'Towing & Hauling' started by Albinator, Oct 8, 2019.
  1. Oct 8, 2019 at 6:32 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Hey guys,
    I’m getting conflicting information on what my truck is capable of towing. When I look in the manual, it says 10,200 lbs. When I go to Toyota.com/owners and use my VIN it says
    “GVWR = 7200 lbs. Payload = 1590 lbs. Tow Capacity = 8100 lbs.”
    Sorry, I should know but I’m still trying to learn.
  2. Oct 9, 2019 at 9:10 PM
    Albinator
    Utah
    Anyone?
  3. Oct 9, 2019 at 9:21 PM
    Your truck code is inside the drivers door. Match that up to the owners manual. You technically already did with going to the users group and typing in the VIN Number.
    Sounds about right with a CrewMax truck. My 2012 only had a capacity of 1325 lbs, so you are in a way better situation than I was.
  4. Oct 9, 2019 at 9:22 PM
  5. Oct 9, 2019 at 9:24 PM
    AZBoatHauler
    So.Arizona
  6. Oct 9, 2019 at 9:28 PM
    Have the crewmax ratings?
  7. Oct 9, 2019 at 9:33 PM
    tmart
    tmart New Member
    Travis
    There’s some confusion here. Hauling is in the bed, so payload is what matters. 1500 is about the highest you’ll get in a tundra. Towing is pulling a trailer
  8. Oct 9, 2019 at 9:35 PM
    AZBoatHauler
    So.Arizona
  9. Oct 9, 2019 at 9:41 PM
    There's your answer. Thanks @AZBoatHauler for posting those screen shots.
    AZBoatHauler[QUOTED] likes this.
  10. Oct 10, 2019 at 5:42 AM
    Albinator
    Utah
    Thank you. So with that screenshot, it says 10,200 with the *2 being if you have a towing package. My Tundra being the Crew Max 5.7 4x4 with the tow haul button puts it in the towing of 10,200 then, correct? If so, I don’t understand why the Toyota.com/owners says otherwise with stating 8,100 pounds, like it also shows in the screenshot. That’s where I’m getting my confusion.
  11. Oct 10, 2019 at 5:54 AM
    Albinator
    Utah
    So I can haul 1590 in the bed and tow 8100 at the same time? What does GVWR = 7200 mean?
    “GVWR = 7200 lbs. Payload =1590 lbs. Tow Capacity = 8100 lbs.”
  12. Oct 10, 2019 at 6:03 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    No.
    You can't have more than 1590 lbs payload. When you tow, part, if not all, of that payload is eaten up by the tongue weight of the trailer you are towing.
    GVWR = gross vehicle weight rating. Your truck, fully loaded down, can't weight more than that (that doesn't include trailer weight). GCWR = gross combined weight rating - that is the total weight allowed for your truck, fully loaded, plus your trailer.
    ColoradoTJ likes this.
  13. Oct 10, 2019 at 6:32 AM
    Albinator
    Utah
    That just doesn’t make sense when it says 8100 or 10200.
  14. Oct 10, 2019 at 6:35 AM
    Albinator
    Utah
    here’s the stickers on my truck
  15. Oct 10, 2019 at 6:43 AM
    This is why I asked you to look inside the drivers door.
    The capacity of your truck is 1325 lbs.
    With the code and having the tow package, you can legally tow 10100 lbs.
    Here’s the catch. You will run out of capacity long before hitting the 10100 lbs most likely unless your rather light, nobody with you, and only have 10% tongue weight.
    You should feel good about having a pre J2807 rated truck. Your tow rating would have been a lot less.
  16. Oct 10, 2019 at 6:53 AM
    Atomic City Tundra
    Devin
    New Mexico
    As TJ said above, 1325 lbs is the most you can carry (payload). And that is assuming you haven't added any mods to the truck. I have just about the same rating on my truck, but in reality is lower because I added aftermarket components which take up some of that payload. It really isn't that difficult. The advertised numbers are not what your specific truck can do necessarily. Always check your door sticker.
  17. Oct 10, 2019 at 6:56 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Just to add to this for the OP as it is confusing......
    Let's say he weighs 200 lbs. and throws 300 pounds of bricks in the bed. He has just reduced his payload down to 825 pounds. 1325-500 = 825
    Now, let's say he has a camper that he is pulling in addition to him and the bricks. The camper weighs 5000 pounds and has a tongue weight of 525 pounds. He is fine as far as his towing capacity goes since the truck is rated for 10,100 pounds. However the tongue weight is reduced by 525 pounds so now he has 300 pounds left in the truck..... legally.
    So now let's say he has his truck loaded with him, bricks, and towing the camper to the NASCAR Bristol night race in August. He only has 300 pounds left over to work with and he has 3 buddies coming with him to stay in the camper. You better hope your 3 buddies all way under 100 pounds or else you will technically be over your rates payload capacity.
    I hope this makes sense to you Albinator.
    Towing can get confusing. If you have a spray in bed liner, tonneau cover, etc.... these reduce your payload also.
  18. Oct 10, 2019 at 7:00 AM
    knoxville36
    Knoxville, TN
    Now, I am not saying anything illegal or anything at all. Other brands have a much higher payload capacity due to aluminum beds being lighter, etc....
    From my experience with newer Fords and ecoboost engines, I much rather be towing a 5000lb. Travel trailer and a bed full of bricks with my Tundra compared to the Fords I have towed with. Heavier Tundra in my opinion handles the heavier stuff much better. A lot of walking and swaying with the others from my experience even though they are rated for more.
    Albinator[OP] likes this.
  19. Oct 10, 2019 at 7:14 AM
    Mnorris1206
    08 tundra
    Example golf cart 900#s. Tough weight of camper is 460# dry weight of camper 5300# .
  20. Oct 10, 2019 at 7:14 AM
    Mnorris1206
    08 tundra
    I was cutting it so close. On the hauling weight
  21. Oct 10, 2019 at 7:19 AM
    Atomic City Tundra
    Devin
    New Mexico
    I'd venture to say that you were over weight. How much do you weigh? Nerf bars cut into payload. Your flares cut into your payload. Everything you add to your truck that weighs something takes away from your payload.
    Mnorris1206[QUOTED] likes this.
  22. Oct 10, 2019 at 7:22 AM
    Mnorris1206
    08 tundra
    Your probably right for sure. I no longer do this but when I did I literally traveled like 30 minutes away. No highway eather.
    I know I was pushing it for sur .
    Atomic City Tundra likes this.
  23. Oct 10, 2019 at 7:23 AM
    Atomic City Tundra
    Devin
    New Mexico
    Cool long-bed, though.
    Mnorris1206 likes this.
  24. Oct 10, 2019 at 7:23 AM
    Mnorris1206
    08 tundra
    Thanks!
  25. Oct 10, 2019 at 8:04 AM
    Albinator
    Utah
    Speaking of mods and stickers, I’ve only had the truck for 1.5 years and haven’t done any mods nor have found mods on it. The only thing is when it needed tires, I put 275’s on it instead of the stock 255’s. But, there is this sticker on my door, which my mechanic nor Toyota dealership doesn’t get since there is no mods on it. Maybe it once did have mods then was put back to stock?
  26. Oct 10, 2019 at 8:06 AM
    Albinator
    Utah
    Thank you for all of this; helps me understand much better. It is confusing and I do have a 1966 Kit camper that is 2500 lbs so I definitely have no worries there; it’s just nice to know what I can do if/ when needed. I meant to post about the sticker on this thread but did on another
  27. Oct 10, 2019 at 8:17 AM
    Atomic City Tundra
    Devin
    New Mexico
    Hard to tell. Sometimes dealers add nerf bars, aftermarket skids, bedliners, etc.
    In the end, if you really truly want to know how much payload you can handle - go take your truck to a CAT scale and get it weighed with a full tank of fuel and all fluids topped off, and you not sitting in it. This is called the curb weight of the vehicle. Then, to find your true payload, simply subtract the curb weight from the GVWR (7200 lbs). The difference is the true payload capability of your truck.
    Albinator[QUOTED][OP] likes this.
  28. Oct 10, 2019 at 8:46 AM
    Albinator
    Utah
    Duh, I should have known that. Great recommendation, thanks! My truck does have the plastic liner in it I actually took it out to clean all of the hay, mud, gravel, etc. that was under it a couple of weeks ago and it definitely didn’t weight that much; probably not even over 45lbs.
  29. Oct 10, 2019 at 8:51 AM
    Albinator
    Utah
    Thank you. What is and what does it mean/where does it say it’s a J2807 truck? I just didn’t see that on the stickers picture unless I missed it.
  30. Oct 10, 2019 at 9:01 AM
    Atomic City Tundra
    Devin
    New Mexico
    Toyota adopted the J2807 standard for towing in 2011. Your truck's towing capacity was calculated/determined before they adopted the standard.
