How many turns to steering wheel lock?
Discussion in 'Suspension' started by vegas4x4, Nov 6, 2019.
  1. Nov 6, 2019 at 2:09 PM
    vegas4x4
    vegas4x4 [OP] Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Just curious, from dead center, how many turns right/left until full lock?
    My Pro Comp 7” required a weld-in steering-stop tab and i think i need to grind some of it down because my truck has a gawd awful turning radius. Total PITA when trying to park.
  2. Nov 6, 2019 at 2:57 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    That is normal with drop bracket lifts. When you change out the spindles, the turning radius is diminished immensely
    BTBAKER, T-Rex266 and OR18TRD like this.
  3. Nov 6, 2019 at 3:48 PM
    vegas4x4
    Las Vegas
    i understand that. im just curious what stock was. any input will help, i just want to compare.
  4. Nov 6, 2019 at 6:36 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I think 1 and 5/8 of a turn.
  5. Nov 6, 2019 at 7:38 PM
    vegas4x4
    Las Vegas
    Thanks bud!
    Im going to double check later. Been away from my truck all day.
  6. Nov 7, 2019 at 7:27 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Correction it is 1 and 7/8 turn to lock from center. I can only turn 1 and 1/2 because I'm running 295's on stock wheels with no lift.
  7. Nov 7, 2019 at 9:58 AM
    vegas4x4
    Las Vegas
    1 & 7/8!? Damn mines is restricted as hell! Thanks for looking again bro!
    Im getting 1 and 1/2 turning right, and 1 and 5/8 turning left. I already did a small amount of grinding (hence the reason it isnt even). Im gonna go do some more today because i seriously cant stand doing 3 point entries and exits all over the place. Im gonna shoot for 1 & 3/4 turns in both directions
    Rockgate[QUOTED] likes this.
  8. Nov 7, 2019 at 7:50 PM
    vegas4x4
    Las Vegas
    Update. Ground down the steering stop to just under 1 and 3/4 turns in both directions. Parking is A LOT better. We’ll see if i run into any problems down the road by making this modification
    OR18TRD and Rockgate like this.
