How many shims with 5100's
Discussion in '2.5 Gen Tundras (2014-2021)' started by Danbizzle2009, Feb 3, 2019.
  1. Feb 3, 2019 at 10:44 PM
    Danbizzle2009
    Danbizzle2009 [OP] New Member
    MAINE
    2016 DC Tundra SR5
    I have a 2016 Tundra 4x4 I'm planning on installing Bilstein 5100's on middle setting (1.5"). How many Coachbuilder .5" shims do I need and do you have a link for them? Thank you.
  2. Feb 3, 2019 at 10:47 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Shims aren't a great idea with billy 5100s. The shocks are much more likely to fold like origami if you go off road. Just my .02
    kenomouth64 likes this.
  3. Feb 4, 2019 at 1:00 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Are you trying to stop the Toyota lean? If so then the smallest on the drivers side only
  4. Feb 4, 2019 at 1:02 AM
    Danbizzle2009
    MAINE
    2016 DC Tundra SR5
    how much is the lean?
  5. Feb 4, 2019 at 2:40 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Depends on the truck. 1/4-1/2”
  6. Feb 4, 2019 at 5:15 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    My truck had almost no lean when I first bought it.
    -Used 2010, mid 60k miles.
    -Came from PO with 3" spacer lift.
    Within a few months I swapped to the Toytec/Eibach coilovers to ditch the spacer lift. After installing, the drivers side lean was close to 3/4", very noticeable. I ordered 2 coach builder shims and installed on the drivers side, perfectly level side-to-side on front and rear axles.
    There is no right answer, it seems to be different for each truck and for each suspension setup. I ended up with the same amount of lift in the front going from spacers to coilovers, but the lean was much worse, not sure how to explain that. Unfortunately it may take a test fit and measure before you decide if you need 1 or 2 shims.
  7. Feb 4, 2019 at 6:32 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Zero for me.
  8. Feb 4, 2019 at 7:23 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Same here. Went from spacers with no lean to icon Coilovers now with lean. Luckily it’s easy to fix with a couple extra turns with the spanner wrench.
    OBXTundra[QUOTED] likes this.
  9. Feb 4, 2019 at 10:12 AM
    Jpagansr
    Jpagansr New Member
    Joel
    2018 tundra Trd Sport
    zero for me as well
