How many miles can I expect to get
Discussion in '2.5 Gen Tundras (2014-2021)' started by shreveporttundra, May 31, 2022.
  1. May 31, 2022 at 7:23 PM
    shreveporttundra
    shreveporttundra [OP] New Member
    Serious question here…I have a 2015 4x4 SR5 Crew that I bought brand new. Every truck that I bought before that (not Toyotas) I would trade at about 70-85,000 miles. Not because I was having problems, but because I did not want to start having problems. I now have 168,000 miles and I never have any worries about any trips that I go on. I cannot say that I would feel the same if I have a ford or Chevrolet. This truck never gives me any problem, it just runs. I have debated trading for something with better gas mileage but the first time some sensor comes on in the new vehicle I buy will piss me off because I just never have problems. REALLY… How many miles can I get on this thing before I should expect to start having some problems. The dealer that I bought it from has serviced it at every 5,000 mile increment since I bought it.
    17inferno likes this.
  2. May 31, 2022 at 7:26 PM
    There are guys here that have over 400K on theirs. You're good....you're just barely broken in.
  3. May 31, 2022 at 7:32 PM
    Sunnier
    Sunny
    San Diego, CA
    Before you start having *any* problems…. ~ 200k if you don’t use it hard. After that, if you keep the maintenance up, should be minor this and that. I think you can count on 300k without major repairs. Obviously, the clear coat sucks on these, so your paint will dull if you’re in a sunny state. Rust could be a problem in a wet (road salt) state… but those aren’t related to inherent durability. You’ve got a lot more good miles ahead!
    WILLINH and shreveporttundra[OP] like this.
  4. Jun 3, 2022 at 5:09 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    240k on my 2014 and I beat on it pretty hard. Keep up with your maintenance and it'll last a long time.
    WILLINH and Sean492 like this.
  5. Jun 3, 2022 at 5:10 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    1,000,000
    WILLINH, Fiesta346 and Black Wolf like this.
  6. Jun 3, 2022 at 5:16 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Even if you have minor issues (expected with something that depreciates in value and life), you'd still be doing great. No one except yourself can decide when to trade it in and spend your own money on a new vehicle. That's your choice.
  7. Jun 3, 2022 at 5:37 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Not same gen but my 02 has 318k and it’s only had ball joints, 02 sensors, timing belt x3 and rear shocks. Would drive it to California today with the family
    clarkritchie and Malinois38 like this.
  8. Jun 3, 2022 at 5:52 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I'm kinda in the same situation as the OP, except mine is a 2nd Gen with197k virtually trouble-free miles.
    I keep taking mine into my local mechanic asking him to start replacing stuff before it brakes; and he just keeps telling me I'm driving the most reliable trouble-free truck on the road and not to worry about it.
    I plan on taking mine on a 4K road trip from Phoenix to Canada this summer and all I'm going to do beforehand is change the oil, clean the air filters and put on new wiper blades.
    Now I'm worried I wasted money on the wiper blades. This is summer. It never rains.
    WILLINH and Ghost Rider like this.
  9. Jun 3, 2022 at 6:04 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Don't worry, it'll undoubtedly rain here when you, @TaquitoBandito and @Azblue come up to rescue @Outbound and take him home to @War Machine.
  10. Jun 3, 2022 at 6:28 AM
    Outbound
    Aaron
    Northern Alberta
  11. Jun 3, 2022 at 7:07 AM
    TaquitoBandito
    Joel (AKA Bif)
    I'm currently saving up for appropriate tires.
  12. Jun 3, 2022 at 7:46 AM
    blanchard7684
    blanchard7684 New Member
    There are credible reported Tundras going 1 million miles in "hot shot" service.
    Research Victor Shepard.
    The number of hysterically high mile toyotas across all models is insane.
    You'll have a few minor issues along the way but the core function of your truck, provided good maintenance, will run an astonishingly long time. Toyota trucks last longer than you care to own them.
    On 2.5 gen here is a non exhaustive list of minor things that have been known to occur
    water pump
    starter
    mid engine heat exchanger leak (aluminum manifold under intake)
    timing chain tensioner on driver side (gets a bit loose, not a huge immediate concern. there is some decent correlation to this being caused by high oil change intervals or crappy oil)
    Cam tower oil leak (in grand scheme not a huge deal and your truck will still run)
    Seal leaks on transfer case
    Probably forgetting a few...
    This is on top of the normal wear and tear of most vehicles.
    If you anticipate and even plan for these items it turns them into a fairly minor inconvenience all things considered.
    Cpl_Punishment likes this.
  13. Jun 3, 2022 at 7:53 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Their cars too. The only issue my dad had on his 2003 Matrix in 16 years was a slightly leaky clutch master cylinder due to lots of driving in stop and go traffic.
    WILLINH likes this.
  14. Jun 3, 2022 at 8:01 AM
    blanchard7684
    For sure.
    Matt Farah's Lexus LS stunt to get to 1 million miles was amusing as hell.
    I've known no less than 4 people who had 500,000 mile camry's that were still used as daily drivers. One got taken out in a severe hail storm in Lubbock Texas. Insurance scrapped it but it still ran.
    1.5 million mile tacoma This Toyota Tacoma Has Racked Up 1.52 Million Miles (motor1.com)
    And I've lost count of how many 3rd gen 4runners are verifiably above 700K miles.
  15. Jun 3, 2022 at 9:05 AM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    I had secondary injection air pumps fail and truck went into limp. Had to get it serviced at dealer. It was under a recall. Also had transmission develop rumble strip. Had to flush transmission to get rid of problem.
    Both issues happened before 100k miles. I'm now on 128k and so far nothing else. I do hear some very faint distant whirring somewhere in front when driving around 55. I'm very gentle with my truck. Single owner, never been in crunch accidents.
    Also, minor issues. Rear driver side door lock only opens using power switch or main door key. Lock flipper borked. Also tailgate lock doesn't work. If I lock using the key, I have to take her apart to unlock. Door latches fine though.
