How many hours to remove the cab to get to the waste gates?
Discussion in '3rd Gen Tundras (2022+)' started by Doug2000, Jun 25, 2023.
  1. Jun 25, 2023 at 1:27 AM
    Doug2000
    Doug2000 [OP] New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I have a 2017 Tundra and am considering a 23 Tundra. After the initial release we all saw pics of the new truck with its cab off to access the waste gates for the turbos.
    Does anyone know the standard hours a dealership would charge if the truck was out of warranty?
  2. Jun 25, 2023 at 4:50 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    They can be accessed thru the fenderwell, can does not need to come off.
    TundraWorkHorse likes this.
  3. Jun 25, 2023 at 10:57 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Not sure how many hours, but the Car Care Nut did mention on YouTube that lifting the cab isn't all that bad and is a regular procedure nowadays to get to the back of the engine.
    So as long as the mechanic is competent, it shouldn't be a huge deal. A big job? Yes. But not something to freak out about.
    Not sure but I thought I heard that to get to one of the turbos, you do need to lift the cab
  4. Jun 25, 2023 at 11:22 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Doesn't require removing the cab to do Turbo replacement. I've read through the service manual for Turbocharger removal. Toyota procedure is to remove the engine mount and lower the engine about 2-3 inches. How the tech decide to do it is up to them. Remember that techs gets paid flat rate and will take short cuts. Warranty pay less.
