How long do oem rotors last?
Discussion in '2.5 Gen Tundras (2014-2021)' started by prene1794, Oct 10, 2021.
  1. Oct 10, 2021 at 1:43 PM
    prene1794
    prene1794 [OP] New Member
    Just a simple question because my 2018 1794 Tundra has only 25k on it and my steering is shaking like crazy at high speed to slow. I find it weird but it will give an excuse to but new stuff. I saw a video of a guy greasing the caliper blots which i might try. Any other suggestions?
  2. Oct 10, 2021 at 1:45 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I'm currently at 85000 miles and not having any issues with my rotors. I think I'm about to replace the pads, but don't notice any issues with the rotors yet.
  3. Oct 10, 2021 at 1:53 PM
    prene1794
    Thank you bsktball55. I probably have to break one of them open tomorrow to double check. I was think 25k was pretty good low. Im just not sure what se it could be.
    Thanks much!!
  4. Oct 10, 2021 at 1:56 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I have heard of people having issues especially if they are hard brakers. I would say 25000 miles is way to early to have issues but not unheard of.
    prene1794[QUOTED][OP] likes this.
  5. Oct 10, 2021 at 2:15 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    On my 2019 work truck they were vibrating before 20K but I had a trailer hooked up 90% of the time. On my personal truck (2017 CM Limited) I put new rotors and pads at all 4 corners last weekend. I was getting some vibration at 57K miles. I tow with the 2017 pretty regularly too but the trailers are not nearly as heavy. The pads were fine (50%+). And the calipers weren’t hanging up at all. No complaints here in Buffalo weather with that kind of life.
    prene1794[OP] likes this.
  6. Oct 10, 2021 at 2:16 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Mine were shaking around 35k miles they are junk
    Black Wolf and prene1794[OP] like this.
  7. Oct 10, 2021 at 2:20 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Just replaced mine at 45k, I do live in a very hilly area and drive down some steep grades every day on my way to work
  8. Oct 10, 2021 at 2:23 PM
    CMikeB
    CMikeB New Member
    I'm at 86,000 miles on my 2010's brakes but I don't jump on 'em every time I want to slow down either. 'S' mode is your friend!:D Never do I ride my brakes, free reeling in 6th gear, when it's so easy to choose the correct gear to keep a manageable speed.
  9. Oct 10, 2021 at 2:27 PM
    timsp8
    NY
    I replaced my stock ones at around 25k. They were shaking while breaking pretty bad.
  10. Oct 10, 2021 at 4:08 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    If I remember, some people had that issue if the wheels weren’t torqued right. It would warp the rotors. One thing for sure, my trucks isn’t going back to the dealer for the free oil changes or tire rotation. When I went to do my lift kit the wheels had to be torqued to around 120-130. Took a lot of force and when they broke loose, you could hear that clank sound when screw or nut makes when it’s kinda stuck and breaks free. By the way I am at 16k and so far so good.
    gosolo and prene1794[OP] like this.
  11. Oct 10, 2021 at 4:44 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    I changed mine at 95k miles and honestly I could have gone a while longer. It all depends how much you tow and how hard you are on your brakes
    gosolo likes this.
  12. Oct 10, 2021 at 5:15 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    77,000 miles and all is fine. I am a very conscientious braker. :cool:
    AZBoatHauler likes this.
  13. Oct 10, 2021 at 5:29 PM
    prene1794
    Thanks for your comments. I guess it might normal since unbeknownst to me this was the test drive model. If I'd known at the get go i wouldn't have been to easy on the sales man. I am thinking that these miles that were on the truck prior to my purchase 3 or 4 times normal driving.i will buy the kit power stop k36. I think these are great for all around towing a camper and are eazier on the brakes. Once i get those on ill be upgrading my rubber and wheels. I currently have 18s but would like put 20s on the way it was supposed tob humbly
  14. Oct 10, 2021 at 5:44 PM
    AZBoatHauler
    So.Arizona
    I’m at 63k and they are rock solid. Just changed front brake pads at 55k and they still had life left.
    Rob's Inferno likes this.
  15. Oct 10, 2021 at 5:54 PM
    prene1794
    Ill still have my buddy balance and rotate these and check how much meat is left before replacing everything. I will see if this is the culprit and 90% hope this is the case
  16. Oct 10, 2021 at 5:57 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Just had mine turned for the first time @ 120k mi. 3rd set of pads. OEM
  17. Oct 10, 2021 at 5:57 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    mine lasted 190k miles hot pad swaps with 2 turns, and 12 years.... my last set of rotors only lasted a year, I think its a sticky caliper which did them in... so I'm waiting on OEM replacement calipers and rotors.
  18. Oct 10, 2021 at 6:31 PM
    brobert225
    brobert225 Firm grasp of the obvious
    Maybe 1-2 sets of pads. They are so cheap to replace I won’t push them too long. Went with the Powerstop coated drilled and slotted and love them.
    WNY PAT and prene1794[OP] like this.
  19. Oct 12, 2021 at 4:58 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    Living in the salt belt, I too went with the highest quality NAPA coated rotors I could buy and the best quality NAPA pads they sell. 5 years and 50 some thousand miles and Im sure I’ll be doing them again. Honestly, I probably could’ve turned the OEMs but at $56 per corner ($260 total), I figured I’d just pull the old rotors and recycle them. My experience has been crap turning the rotors, even the thicker aftermarket ones, you’re pulling them right off again in less than 20K miles because they’re vibrating even worse. IMO anyway.
  20. Oct 12, 2021 at 6:05 PM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    Have you gotten new tires? Over torqued lugs could warp the rotors
  21. Oct 13, 2021 at 3:54 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    I just had mine turned at about 32k miles because they were shaking badly when braking. But I overheated them badly coming down Teton pass hauling a camper with no trailer brakes, so I'm not sure that's really a failure of the truck.
  22. Oct 13, 2021 at 6:07 AM
    CMikeB
    CMikeB New Member
    My 2010 SR5 has S Mode for situations like that. It allows me to stay in a lower gear, so I don't need to ride the brakes constantly:thumbsup:
  23. Oct 13, 2021 at 6:30 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Several factors go into brake performance and life. Driving habits, towing/hauling, larger wheels/tires, and lug nut torque can all have an effect.
  24. Oct 13, 2021 at 6:31 AM
    I can’t remember the exact mileage on my 2012 CM, but I swapped out the front rotor and pads ~60k miles. Had some life left, but I had a trip to California planned and wasn’t sure if we were towing a trailer back.
  25. Oct 13, 2021 at 11:14 AM
    ddact
    ddact New Member
    The 2019's do as well. I was in S3, turning about 5500 rpm's and hard on the brakes trying to keep it held back! That's a loooong steep downhill!
  26. Oct 13, 2021 at 11:50 AM
    CMikeB
    CMikeB New Member
    Certainly sounds like a torture test for brakes and nerves! We don't have hills like that here in the people's republik of Maryland!
  27. Oct 14, 2021 at 8:58 PM
    mgnchakar
    mgnchakar New Member
    2016 Black Tundra TRD 4x4
    Looks like brake life on these tundras is impressive
