How long can I drive with noisy pinion bearing?
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Feb 6, 2020.
  1. Feb 6, 2020 at 7:41 AM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    My mechanic diagnosed my humming noise at certain throttle positions as a wearing pinion bearing. He says he has seen them go well over a 100k miles while still noisey. He also says that it wont cause any damage to anything other then the pinion bearing if i keep driving it. He says if he was me he would just keep driving it till it gets worse. I am fine with doing that, i just want to hear everyone opinion on that though. Its not too bad and i just dont have the money to spend on it right now. Should i be fine to drive it for a while longer? EDIT:will i be potentially causing more damage to the rest of the diff if i leave it alone? Thanks.
  2. Feb 6, 2020 at 8:03 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    It's 100% ok until it's not.
    Unfortunately there is no telling how long it will last. Could be ten days or ten years.
  3. Feb 6, 2020 at 8:04 AM
    Mr Badwrench
    Mr Badwrench New Member
    If the bearing is going out, I would think the ring and pinion would be the next to suffer damage.
    NewImprovedRon and Rex Kramer like this.
  4. Feb 6, 2020 at 8:26 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I went over 100k after mine was detected, and I finally had it fixed a few years ago.
    Mine was a bomb with a really long, slow burning fuse.
  5. Feb 6, 2020 at 8:32 AM
    Professional Hand Model
    Hand Protectors
    Not sure how the two translate, but I had a bad wheel bearing for 6 years. Drove fine. Made some wha wha noise until it went next level unbearably loud this summer. That was my clue to get it replaced.
    Rex Kramer likes this.
  6. Feb 6, 2020 at 8:41 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Nothing to worry about until the noise gets unbearable. The next stage is grinding. I've dealt with this in my Datsun for 10 years, still the same.
    Pucks18[OP] likes this.
  7. Feb 6, 2020 at 11:33 AM
    Pucks18
    Thank you for all the reassuring replies guys. They all basically sound the same as my mechanic said. As i was saying before as long as it doesnt mess with my other major gears I'm fine with it till it gets unbearable. I dont really think this bearing will have that many shavings in it anyways to damage the other gears until it just completely breaks then obviously ill know to stop driving. Thanks again for the reassurance.
  8. Feb 6, 2020 at 1:06 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    "How far will one engine take us...?"
    "All the way to the scene of the crash."
    bmf4069 likes this.
  9. Feb 6, 2020 at 3:56 PM
    Pucks18
    Everyone saying "until it doesnt work anymore" my other question is will it damage other stuff in the process before it fails?
  10. Feb 6, 2020 at 4:04 PM
    Hand Protectors
    We don’t have Crystal Balls that look into the future. Anything is possible.
    You either fix it now OR take a chance. Pick one. That decision is up you.
  11. Feb 6, 2020 at 4:08 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Even if it seized would probably rip the u-joint apart and that's far fetched. A whine is nothing. If there is no play at the pinion flange, try a fluid change.
  12. Feb 6, 2020 at 4:20 PM
    Zum
    Zum New Member
    NS Canada
    Mine was "whining" between 40-50 mpg. That's my usual around town driving speed so I replaced the whole assembly around 170k. I kept my old assembly, thought I put it back in if I ever hit this one wheeling. Mechanic said the same as yours, probably would of lasted another 170k.
  13. Feb 6, 2020 at 8:26 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    "They call me....tater salad".
    BubbaW likes this.
  14. Feb 7, 2020 at 4:24 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    "Other states are trying to abolish the death penalty... mine's putting in an express lane." :hattip:
    bmf4069[QUOTED] likes this.
  15. Feb 7, 2020 at 4:46 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Stop scaring the kid will ya, it's just a wine not a grind. I drove home once from the NH race way after blowing a pinion in my Datsun. It was still together, but probably about an inch of play. I'm talking real bad and I made it home. Now I trailer it to the track. You some time to fix it. Not sure we're you live but I have a nice rear end with no noise from a 2000. All new brakes as well with new drums. I still have to remove it, so in time. I go by junk yard prices from this yard, https://garysupullit.com/ Now I just gave you one of my big secrets. Located in Binghamton, NY.
  16. Feb 7, 2020 at 6:12 AM
    112690 New Member
    Tony
    2019 Tundra DC
    I would bias my action(s) by first performing a fluid change and inspecting the fluid for signs of metal grit or abnormal metal content. If the fluid has never been changed since 2001, it might be difficult to tell. If that is the case, I would change and then repeat in a few months. If the second change is clean, I'd ignore. If there is abnormal metal content in the second change then parts are disintegrating.
  17. Feb 7, 2020 at 6:17 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    That is exceptional fuel mileage!
  18. Feb 9, 2020 at 7:27 AM
    Zum
    Zum New Member
    NS Canada
    Nice catch, I'm blaming spellcheck...
    coTony likes this.
  19. Feb 17, 2020 at 10:27 AM
    Pucks18
    @zombie thanks. Yea they were scaring the kid. (I'm 19) lol. But yea its all good. Ill save up for a full rebuild in the future before i move out to colorado, but thats not for a while. Im located in chicago illinois, thanks for the offer and the piece of mind.
  20. Feb 17, 2020 at 11:02 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    My 4runner developed a whine and it last several years before I decided to fix it. If the noise is actually a pinion bearing, it will be years before you even need to worry, more than likely. I have a contact in my area that actually rebuilds/regears/repairs rear end chunks and I took it to him. He used factory Toyota parts. The bearing was 240.00 and with labor, grease, etc, the total price to fix it was 450.00. If you can find someone who knows how to do this type of work, that would be your best bet. But its hard to find someone that knows how to set up the clearances correctly.
    FrenchToasty and Pucks18[OP] like this.
  21. Feb 17, 2020 at 11:30 AM
    Pucks18
    @RickC hey rick. Thanks you very much for the reply. Ive been stressing at work all day about it. I called a 4x4 diff repair shop and they said i might aswell rebuild the whole diff since they are already in there and they also said other stuff will be on their way out too. Which i highly doubt. And also i feel like it shouldnt be that labor intensive either. Anyways in less than a year I'm moving to colorado from illinois and i might just do a full rear diff rebuild. But everyone including my mechanic is basically saying I'm good to go for a long time as long as i can deal with the sound. Thanks again
  22. Feb 17, 2020 at 11:30 AM
    Pucks18
    @RickC And why did u end up repairing it? Did you have to or did u decide that it was just finally time? And did u have any other diff problems after only replacing the pinion bearing? Thanks again
  23. Feb 17, 2020 at 11:44 AM
    RickC
    Rick
    Knoxville TN
    I replaced mine because I was planning to give the 4runner to my daughter and son-in-law while they moved to Ohio so they would have the 4WD. Since they will be in Ohio for 3 years, I didn't want it to fail that far from where I knew I could get it fixed and fixed right. I did not have any issues or whine once it was replaced.
  24. Feb 17, 2020 at 11:49 AM
    Pucks18
    @RickC alright thanks. Yea I'm suprised u had a shop quote you that little for it. My mechanic quoted me a little over 1,000:(. 2 mechanics actually. Glad to know i can save up for a year or so and then do it. I can prob just put it off for the next 80,000 miles if i r3ally wanted too to
  25. Feb 17, 2020 at 1:05 PM
    RickC
    Rick
    Knoxville TN
    Yeah, that shouldn't be an issue. I didn't use a shop though, it's an individual who builds race cars and he does this type of work for people as a side gig. He's one of the few around that knows how to get the clearances right when swapping ring/pinion gears or changing to limited slip. He has done 4 different ones for me over the years.
  26. Feb 17, 2020 at 2:34 PM
    Zum
    Zum New Member
    NS Canada
    For the price your getting quoted(over $1000)must be for the whole assembly, fluids etc?
  27. Feb 17, 2020 at 2:41 PM
    Hand Protectors
    Its all good! Your mechanics and plenty here say you’ll be fine with a bad bearing. No need to waste your time worrying about it. :annoyed:
    (Unless the noise is driving you nuts.)
  28. Feb 18, 2020 at 7:15 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    How long it will last isn't relevant. Where it will leave you when it craters and stops your truck in its tracks is what matters...as in 20 miles in the back country with no cell service. Feel the same way about 4WD...it will generally take you about a mile further than the spot/point where you would have turned back with 2WD. How much do you like walking, hitching, or begging someone (family/friend/stranger (axe murder?) for a ride?
    Fix it as soon as you can afford it.
  29. Feb 19, 2020 at 5:07 AM
    Hand Protectors
    Axe murderers? Pucks won’t leave his house now that you’ve brought that subject up.:D
  30. Feb 19, 2020 at 7:19 AM
    Pucks18
    @tmac58star its just a whinning bearing bro, i will fix it once i can afford it though since it is slightly annoying.
