How long are LBJ good for when replaced?
Discussion in '1st Gen Tundras (2000-2006)' started by reefrash1043, Oct 17, 2023.
  1. Oct 17, 2023 at 4:12 AM
    reefrash1043
    reefrash1043 [OP] New Member
    Nashville
    2005 Limited Tundra
    Was going through my trucks service records on the Toyota website and it turns out I had the LBJ replaced under warranty in 2014. Are these good for the life of the vehicle or do I still need to be concerned about these?
    2/2014
    SSC-70B(2.6)
    SSC-70B(2.6) ~|~REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS AND CHECK & ADJUST THE FRONT END ALIGNMENT. ~|~SSC 70B ~|~PERFORMED A SSC 70B. PERFORMED A FOUR WHEEL ALIGMENT.
  2. Oct 17, 2023 at 4:27 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Just check status with tire rotations. It’s not on my maintenance list but I’m also not a true “gear head”
    GreenMachineDream and shifty` like this.
  3. Oct 17, 2023 at 4:28 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    You should get at least 100,000 miles from new Toyota LBJ.
  4. Oct 17, 2023 at 5:09 PM
    Trox416
    Trox416 New Member
    Western MT
    2002 SR5 Extra cab 4x4
    OEM should be good for 100k.
