How hard is it to remove the bed?
Discussion in '1st Gen Tundras (2000-2006)' started by vst, Dec 12, 2023.
  1. Dec 12, 2023 at 6:09 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Hey guys I have pretty good size dent on my driver bed side and had a PDR try to pull it but it started chipping the paint it’s got a pretty good crease in it. So it looks like in the future I need either the bed side replaced or the whole bed. I got quoted $2k just for the bedside being replaced and painted but I’ve seen whole beds available for cheaper. I was wondering how hard is to remove the bed is it just the six bolts in the bed and gas filler neck? Thanks
  2. Dec 12, 2023 at 6:12 AM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    It’s not difficult at all (depending on rust) I’m near Cincinnati. I soaked them in penetrating oil for a couple weeks ahead of time then used a torch to heat them. A good impact socket spun them out with effort and replaced the bolts when I installed the bed.
    With that said, I spent months to find a rust free bed that was under $1,8000. So if you can have it professionally repaired for $2,000 that may be less stressful.
    FirstGenVol, vst[OP] and JakeJake like this.
  3. Dec 12, 2023 at 6:31 AM
    Have to unhook the taillights as well, but yes that’s pretty much it.
    vst[QUOTED][OP] likes this.
  4. Dec 12, 2023 at 6:39 AM
    Worst part is dealing with the fuel filler on most trucks from what I've seen. If you're up north, the bed bolts suck.
    CCE525 likes this.
  5. Dec 12, 2023 at 7:13 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @vst I'm in Knoxville and we're working on a bed swap for @jpink . His truck came from Iowa so the bed bolts are somewhat fcked. Have a few friends there to help you lift but the beds are not that heavy.
    If you're close to Knoxville, let me know if you need a hand.
    Jack McCarthy and vst[OP] like this.
  6. Dec 12, 2023 at 8:32 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Thanks I’m over in Morristown
  7. Dec 12, 2023 at 10:19 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    My 2004 AC is rust free, so it took about 1 minute to remove all 6 bolts. The tank filler screws took another minute or so. Crawling around underneath to unplug the taillight wires took the longest.
    vst[OP] likes this.
  8. Dec 12, 2023 at 12:23 PM
    Richid
    Richid New Member
    I'm in the Northeast - had to lift the bed to repair the rear rockers and cab corners. Soaked the bed bolts for a day, and it took a little work with the impact. Hardest part is that the bed curves under the cab. I pulled the bumper and lights, then lifted each side on to 1" blocks - this gave me enough room to shift the bed back away from the cab without scratching it. Pushed it back off the frame - only about halfway as I didn't need to remove it.
    The frame was replaced ~ 10 years ago, so it was already off at one point.
    My wheel wells are rusty - If I found a decent bed, that would be my choice too.
    whodatschrome and vst[OP] like this.
  9. Dec 12, 2023 at 3:57 PM
    whodatschrome
    lots of dents
    I didn’t remove my bumper when i removed the bed. It was something like another 12(?) bolts or so. I simply wrapped towels around the outer ends of the bumper so that i wouldn’t scrape the lower corners of the bed when lifting it up.
    vst[OP] likes this.
  10. Dec 13, 2023 at 5:18 AM
    Fryphax
    Fryphax Need a bag over your head, Dad.
    Eugene Krabs - The crusty $1,500 V8 4WD 2000
    It's super easy, even on my crusty rust bucket most of you wouldn't touch. All my bed bolts came out though I did have to weld nuts on two of them because the head stripped out. I think that's more the fault of my Harbor Freight non impact Torx sockets. I didn't heat or spray any of them so it was super surprising.
    vst[OP] and whodatschrome like this.
  11. Dec 16, 2023 at 8:48 AM
    Richid
    Richid New Member
    My brackets only have four bolts. Although I think the ends are bent in some, which may be why the bed would hit them before clearing the cab. Thinking back, I could have probably remove the 2 rear bolts and pivoted it down on the hitch to make enough room.
  12. Dec 31, 2023 at 11:45 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Ok just weighing my options here I found a clean bedside on car-parts.com in the same color how hard is it to remove and replace a bedside is possible to do my self? They want $350 for the bedside if I am able to replace myself I could end up saving my self a bunch of money
  13. Dec 31, 2023 at 11:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Unless you have a way of lifting it, you can't do it alone. One member did it by himself by using a kids swing set as a point of leverage. He somehow winched it off then drove out from under it.
    It's doable with 2 people but 3 makes it easier.
  14. Dec 31, 2023 at 11:58 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    I would have to still lift the bed completely off to replace just the bed side still?
  15. Dec 31, 2023 at 12:02 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ah my bad. I didn't catch the fact that you found just the side. I have no idea how that would work. No experience with body work.
  16. Dec 31, 2023 at 3:17 PM
    whodatschrome
    lots of dents
    I’ve replaced bed sides on 3 or 4 different trucks. It was pretty simple for me. It’s really straightforward for a body guy (i used to work in a body shop for a short time). The only downfall is that most likely your spot welds will never, ever, ever going to be as strong, corrosion resistant, or have as tight gaps as it was from the factory. For $350 just a single bed side, i think i would search out for a complete bed in nice shape for around $500.
  17. Dec 31, 2023 at 3:28 PM
    whodatschrome
    lots of dents
    Agreed. It’s doable with two strong people, but it’s REALLY awkward. Reason being is that the center balance for the bed is about 8” towards the rear of the wheel wells (at least on an AC bed). Which makes it VERY difficult to pick up the bed since one elbow would be hooked up at the top of the wheel well arch, and your second hand would be lifting from the very underneath of the bed. It makes it so you’re pretty much lifting the bed with one hand. With three people lifting it’s exponentially easier. So much so that i wouldn’t recommend only two guys. And this advice is coming from a guy who once (in his late 20’s) was carrying around an 8’ long bed off of an old 77 F250 on his back...solo. No i didn’t try to repeat that feat again.
