How do you repair interior scratches on plastic ?
Discussion in 'Detailing' started by TheBeast, Jun 30, 2016.
  1. Jun 30, 2016 at 9:46 AM
    TheBeast [OP] The Beach
    Center console has couple deep gouges and scratches. Should I use very fine sandpaper then touch up paint if any ?
    Not trying to make it disappear but at least clean it up a bit.
  2. Jun 30, 2016 at 9:56 AM
    Mike Tread lightly.
    south carolina
    You can use like a plastic filler (like bondo) to fill in the gouges. If the plastic has texter to it you will lose that. Use like 1000 grit and then 3000 grit sandpaper for smooth it out and then paint.
    TheBeast[OP] likes this.
  3. Jun 30, 2016 at 5:20 PM
    any toyotas interior touch up paint available ?
  4. Jun 30, 2016 at 5:47 PM
    Mike Tread lightly.
    south carolina
    I don't think so.
    There solution is to replace it... have you check junk yards?
  5. Jul 1, 2016 at 9:48 AM
    it's not that bad but was just wondering if I could fix it up myself. Maybe heat it up a bit to push back the gouged plastic ?
    15whtrd likes this.
  6. Jul 18, 2016 at 10:53 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Pictures? There are a few options but I need to see it.
    -Jason
    SouthBoundSteve likes this.
  7. Jul 18, 2016 at 11:38 AM
    I'll try to post pictures.
  8. Jul 18, 2016 at 12:21 PM
    First off, quit screwing girls in your truck and having those 6" stilettos gouge your plastic. Need to find the root cause before you fix anything.
    Yes you can paint the interior. Very easy to do and have done it on several dash swap outs in Dodges (since the factory plastic is crap)
    NewImprovedRon likes this.
  9. Jul 18, 2016 at 12:39 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Black Wolf and TheBeast[OP] like this.
