How do you get your pups in/out of the truck?
Discussion in 'General Tundra Discussion' started by Gfgneo, Jun 10, 2021.
  1. Jun 10, 2021 at 2:15 PM
    Gfgneo
    Gfgneo [OP] New Member
    California
    2021 tundra platinum
    Those with lifted trucks especially, how do you get ur pups in and out? Especially for older or heavy dogs as i would imagine jumping in and out might be painful for them.
  2. Jun 10, 2021 at 2:47 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Good topic. I have a DC and a younger nimble dog. I’ve tried a couple of the ramps that are available but they don’t work with the small door opening in the DC. Currently I just let him jump in and out of the back but there’s a concern when he gets older, and some have warned about dogs getting their paws caught in the running boards.
  3. Jun 10, 2021 at 3:01 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    dog ramps and you can always build your own ramp. If the pooch is not too heavy, a little lift from you will help them in. Larger dogs can jump in.
  4. Jun 10, 2021 at 3:07 PM
    70m4h4wk
    70m4h4wk New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    I had a 120lb Presa that I used to lift in and out of my truck. She didn't like jumping or the ramp or the stairs I built. My other dogs just jump for now, but they are good with the stairs I built so I plan on using those when they need them. I just throw the stairs in the bed while driving around.
    If you don't use the back seat, I saw a build on here where someone removed the rear seats and put in a solid flat platform instead, so his dogs could hop in and out more easily.
  5. Jun 10, 2021 at 3:40 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    7" on a crewmax. Old girl is an 11yo 80lb pit. Not nimble enough to jump, door barely opens wide enough for a ramp, but its doable. But she's not coordinated or comfortable enough using a standard pre-made ramp. I just have to pick her up like a bag of sand. Wish there was a better way, but I'd need to build a custom one, and even then I'm not sure if she'd use it. I'd start working on the your deadlift. Good luck.
    I did build a custom platform using mdf and pool noodles that helps her stay stable when in motion, and gives her an extra 4sqft of walking space. Didn't have to remove the seats, and the platform itself was removable. The "air ride" helps with an older less stable dog. She doesn't do well sucked into the seat back because of the bottom seat angle.
    70m4h4wk and e30cabrio like this.
  6. Jun 10, 2021 at 4:02 PM
    2mchfun
    Just need a simple ramp with a coat of paint that has a little sand mixed in it plus a strip of bacon for each entrance or exit.
    wv00097 likes this.
  7. Jun 10, 2021 at 4:08 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    MacGyver. I like it.
    wv00097[QUOTED] likes this.
  8. Jun 10, 2021 at 4:17 PM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    2021 TRD PRO CM MGM 2021 SKM CM Limited
    jdg1982 likes this.
  9. Jun 10, 2021 at 4:45 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    That looks like it would perfect for the crew cab? I have been looking for one for our male Akita getting up in age and he is a big boy. I was hoping with the seats flipped up and the door open all the way the ramp would work.
  10. Jun 10, 2021 at 5:06 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    We have an 80lb WGSD that is old, she has a hard time going up & down the stairs in the house & refuses the ramp. She can get in the Prius so that's her vet taxi but for the trucks, it's pick her up and carry her out.
  11. Jun 10, 2021 at 5:10 PM
    RusPro21
    Don
    Pa.
    Yeah I agree I don’t if we will be able to get our male Akita to walk on it. Just need for when he goes to the Vet.
  12. Jun 10, 2021 at 6:28 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Either get a mastiff and do one end at a time. Or one that fits in a suitcase.
    NewImprovedRon, 70m4h4wk and 2mchfun like this.
  13. Jun 10, 2021 at 6:35 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Getting out: I get ours to jump down to feet level in truck and then jump out to ground.
    Getting in: I either lift her or try and make her jump onto feet area and then onto the rear seat.
    We had to remove our OEM side steps as the gap was unsafe for dog legs getting hung up and breaking. When the time comes, it will be sliders with full top plate and tight to truck body
    As you can see, she doesn't sit still when she's back there by herself on our drive to the forest for our daily trail run.
    50lbs, small, all muscle and energy.
    NewImprovedRon and plumber802 like this.
  14. Jun 10, 2021 at 6:36 PM
    crewmaxlmt
    scott
    Spot on with the step hoops. I have to be very careful with our golden.
  15. Jun 10, 2021 at 6:44 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Yeah, my sliders don’t have a top plate and one of mine already “missed” and slid down on them. He didn’t get hurt, but precautions are needed now. Not sure what yet except supervision.
  16. Jun 10, 2021 at 6:47 PM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    Worked fine in the 4Runner side doors & real door as well as in our Xcab Ram 3/4 ton.
    RusPro21[QUOTED] likes this.
  17. Jun 10, 2021 at 6:49 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I grasp the beastie about the withers and deftly hoist their posterior into yon vehicle. The completion of this maneuver is met with moist schnozz in my face with wiggling nubs on yon beasties rump.
    It is at this pointe that clearance for engine start up is granted and taxi to approved runway for departure.
  18. Jun 10, 2021 at 6:56 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :eek::eek::eek: My OCD runneth over. :)
  19. Jun 10, 2021 at 6:57 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    I just thought they were cool dog print seat covers.
    2mchfun and TILLY[QUOTED] like this.
  20. Jun 10, 2021 at 6:59 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    It's been cleaned since then and a Costo blanket thrown down. I still get the odd dirty or mud paw print if the trails are wet.
    She's too happy and excited to get mad. She's not doing it on purpose, so I live with it.
  21. Jun 10, 2021 at 7:10 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    My back seat is way worse. I have seat covers and pretty much the dogs are the only ones riding back there. The front is pretty spotless and they’re not allowed up there.
  22. Jun 10, 2021 at 7:45 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Ha! When you have Great Danes there is no "You're not allowed to sit there" area.
  23. Jun 10, 2021 at 7:57 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Danes plural? My friend had one, used to take us a 1/2 hour to get him situated in the back of her Mazda. Miss that boy. Hated everyone but me and her, smart boy.
    BravoDeltaRomeo likes this.
  24. Jun 10, 2021 at 7:57 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Three.
    Barrett50 and TILLY like this.
  25. Jun 10, 2021 at 8:01 PM
    TILLY
    Massachusetts
  26. Jun 10, 2021 at 8:05 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I have the Scout’s Mobile Mudroom. One of these will save your interior. Good looking pup by the way.
    https://www.duluthtrading.com/gear/dog-gear/travel/
    As far as how my Lab gets in. First I open the door, she looks at me, then proceeds to go potty, while she’s handling her business, I start the truck. I then tell her to get in the truck and she jumps up on the seat. I am going to look into a ramp though, bc she is 6 and I want to save her hips from jumping up and down all the time. She literally goes everywhere with me.
  27. Jun 10, 2021 at 8:08 PM
    jdg1982
    jdg1982 New Member
  28. Jun 10, 2021 at 8:15 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    plumber802 likes this.
  29. Jun 12, 2021 at 5:33 PM
    Gfgneo
    California
