How do you Brake Hold
Discussion in '3rd Gen Tundras (2022+)' started by hudrock, Aug 19, 2025.
  1. Aug 19, 2025 at 6:33 PM
    hudrock
    hudrock [OP] New Members only jacket
    So Cal
    25 MGM Limited
    I’ve been playing around with Brake Hold feature. I assume it’s for use in heavy traffic with long stops and long chick fillet drive through’s lol…..curious if and how you guys use it?
    Tundrastruck91 likes this.
  2. Aug 19, 2025 at 6:49 PM
    CYBERO24
    CYBERO24 New Member
    East Coast
    2023 Tundra Platnium
    SS3 Pods, SS6 Fogs, Talon Skid & Cat, Rays ALAP 07X w/ 285/70 Toyo OC AT3, TRD Pro fenders, beat sonic amp, Peragon Tonneau,
    I only ever use it in drive throughs with long lines or at stop lights that I know lasts for a while.
    mrfreeman and hudrock[OP] like this.
  3. Aug 19, 2025 at 6:53 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    I’ve gotten used to it. I have half city and half highway driving for work and I use it in the city part. I love it. I can just rest some at red light and there’s no lag when I get going from stop.
    SCbuckeye and hudrock[OP] like this.
  4. Aug 19, 2025 at 7:49 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    How does it work? Does it use the hydraulic brakes or the electric parking brake?
    Hill hold is kind of nice on a steep ramp to a parking garage, etc. I'm assuming hill hold works the same as brake hold.
  5. Aug 19, 2025 at 8:00 PM
    hudrock
    So Cal
    25 MGM Limited
    yeah probably same, would work well on hills…uses regular brakes, not parking brake
  6. Aug 19, 2025 at 10:09 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Definite plus in stop and go traffic.
  7. Aug 19, 2025 at 10:50 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    I like also that it works when you are stopped on a downhill. Use mine all the time, allows quick pull outs when entering highway or leaving from stoplights.
  8. Aug 20, 2025 at 4:36 AM
    60centenergy
    Zack
    GVL
    Funny enough I was clueless on how it worked in the beginning. Thought I had to turn it on and off each time I wanted to use it then realized I can just leave it turned on after I press the button and it'll hold anytime I come to a stop. Definitely cool stuff.
    astrength22 and Retroboy1989 like this.
  9. Aug 20, 2025 at 5:23 AM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I had no idea what this feature did, I had to look it up in the owner's manual. I have to yet to use it, I keep forgetting it's there, cool feature though.
    astrength22 likes this.
  10. Aug 20, 2025 at 5:28 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I must have missed that section in the manual too. I still have no idea.
    Anyone care to explain for a guy who is too lazy to dig his manual out?
  11. Aug 20, 2025 at 5:48 AM
    hudrock
    So Cal
    25 MGM Limited
    I hadn't really used it before either, I saw the button above the electronic parking brake and just assumed it was connected to that system which it is not....basically if you turn it on it will keep your brakes applied after you've came to stop and then will disengage the bakes as soon as you push on the gas pedal. My truck is a daily driver and I'm in heavy traffic with long stop lights often so Ive found it pretty conveniant in those situations. As someone else mentioned it would probably be helpful on hills in similar situations.
  12. Aug 20, 2025 at 6:10 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks. Meh..I don't see myself using that feature at all. I do like the auto e-brake, however.
    Retroboy1989 likes this.
  13. Aug 20, 2025 at 6:37 AM
    Retroboy1989
    Northern Utah
    I did the same thing.
    60centenergy[QUOTED] likes this.
  14. Aug 20, 2025 at 6:44 AM
    Retroboy1989
    Northern Utah
    I thought it was part of the e-brake as well, so I ignored it for months.
    I like the e-brake too. It took me a while to get used to it. I really like it when I park on an incline, when I'm towing my trailer, and when I'm trying to hook up my trailer and don't want the truck to roll 3" after I shift into park.
  15. Aug 20, 2025 at 7:05 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Our driveway is on a fairly steep grade. We have horses, so we have to get out to open and close a gate. The auto e-brake is a transmission life-savor for those moments. Absolutely no roll back and no typical "clunk" from the transmission gears engaging.
    Retroboy1989[QUOTED] likes this.
  16. Aug 20, 2025 at 7:56 AM
    SoAzTundy
    SoAzTundy New Member
    2024 WCP Platinum TRD OR
    I just started using this feature. I like it. Just wish I didnt have to turn it on each time I start the truck.
    hudrock[OP] and PGW85706 like this.
  17. Aug 20, 2025 at 9:18 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Next time you’re at a stoplight and the f-150 pulls up beside you looking frisky… apply the brake hold, while the traffic light is still red, put it in sport mode and tow-haul +. When the light turns green just put it to the wood and you’re off….
  18. Aug 20, 2025 at 10:21 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Or, be a responsible driver and pull away from the light like a grownup.
    GoTTi74 likes this.
  19. Aug 20, 2025 at 10:26 AM
    BayAreaTruckin
    BayAreaTruckin New Member
    San Francisco, CA
    I was just about to comment the same thing. I'm sure there is an electronic trickery solution
    SoAzTundy[QUOTED] likes this.
  20. Aug 20, 2025 at 10:58 AM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    .. or just use adaptive cruise (assuming you're ok trusting the tech)?
    raylo likes this.
  21. Aug 20, 2025 at 11:36 AM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    I think you’d be happier driving a Prius…
    Soupbean77 likes this.
  22. Aug 20, 2025 at 11:44 AM
    SDtrueblue
    SDtrueblue New Member
    Marco
    '25 Tundra Limited TRD Midnight Black
    King 2.5's
    I love the brake hold assist and use it multiple times a day around town or in traffic.
    In fact, on my new owner survey, I chose it as the 2nd most useful tech feature for me, right behind CarPlay.
    hudrock[OP] likes this.
  23. Aug 20, 2025 at 2:17 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    I remember one of the early Subarus we had, early 70s I guess, it was manual shift and had the Hill Holder feature. At the stop going up a hill, you pushed the brake hard with the clutch depressed and then your right foot was free to move over to the gas pedal. When learning stick as a kid, that was a dang handy feature. The Tundra Hold feature reminds me of that and days long ago.
  24. Aug 20, 2025 at 6:08 PM
    Matt2015Tundra
    2023 1794 CrewMax
    I lost interest in racing other slow tucks off the line in my early 20's. I guess I grew up.
    raylo and GoTTi74 like this.
  25. Aug 21, 2025 at 1:48 PM
    OrangeBlueOrangeBlue
    OrangeBlueOrangeBlue New Member
    2024 1794 Limited Edition
    Hydraulic brakes, same as the auto braking system that keeps you from running into stuff.
  26. Aug 21, 2025 at 2:10 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Or it is an F-150 with a coyote engine and you get gapped, lol.
  27. Aug 21, 2025 at 3:42 PM
    manofsteele2003
    I was playing with this yesterday, pretty cool, like cruise control for traffic.
  28. Aug 22, 2025 at 5:29 AM
    hudrock
    So Cal
    25 MGM Limited
    Same, I'm actually using all the time now and find it to be a great feature. I would like it to just stay on all the time but at least the on/off button is in a convenient location by the shifter. They should have placed the on/off button for the engine auto off function right to this button. Also I recently noticed the brake hold feature is actually linked to your seatbelt being engaged for it to work as well.
  29. Aug 22, 2025 at 5:50 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Question. Does this feature also work in Reverse? And does it allow you to shift from Reverse to Drive when it's engaged?
    If so, I'm thinking it would be useful for launching, or hauling out, a boat at a ramp.
  30. Aug 22, 2025 at 6:01 AM
    60centenergy
    Zack
    GVL
    I was wondering about this too and meant to try it. Thanks for the reminder, I'll try this soon and let everyone know unless someone beats me to it.
