How do I know if my 2017 Tundra Limited has TPMS sensors
Discussion in 'Wheels & Tires' started by bgbazinet, Nov 18, 2019.
  1. Nov 18, 2019 at 7:37 AM
    bgbazinet
    bgbazinet [OP] New Member
    2017 Silver Tundra Limted
    Stock
    I have a 2017 CrewMax Limited, are all of these trucks equipped with TPMS sensors? My tires have been low before but I haven't seen any warnings?
    Any help is appreciated.
  2. Nov 18, 2019 at 7:38 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal!
  3. Nov 18, 2019 at 7:39 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    You would see this light go off.
  4. Nov 18, 2019 at 7:40 AM
    AZBoatHauler
    So.Arizona
    Tech stream will show you the sensors, their readings, and the threshold for the warning light. There also should be a button on the dash near the driver’s right knee to reset the psi thresholds based upon whatever pressure is in the tires when you hold down the reset.
  5. Nov 18, 2019 at 7:46 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The sensors are Federally mandated (from the factory), whether you have them in your tires or they were removed at some point has been answered in part above. Another way to tell is to look at the valve stems. Sensors are usually metal, non-sensors are normally rubber.
    TreeCat likes this.
