How did you connect your corner dash speakers?
Discussion in 'Audio & Video' started by ljburns, Mar 18, 2020.
  1. Mar 18, 2020 at 5:07 AM
    ljburns
    ljburns [OP] New Member
    I'm curious. I installed 3.5" speakers in the corner dash location (they sound a little harsh at high volume). I wired them directly using the existing wiring. The new radio has 22w per channel out, and I am wondering if that is enough power. I also have an amp running the rest of the speakers.
    How did you connect your speakers? Like me, or did you run a new line from the amp? Or did you install tweeters instead of something like a 3.5" kicker?
  2. Mar 18, 2020 at 5:18 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    This is still something being debated. I have the JBL system and installed a 5-channel amp. I piggybacked the factory wires via a harness for the front doors and front door tweeters and the result is the Lt/Rt dash speakers are also powered. I do not know if this is coming from the factory wires that went to the door tweeters or if it's from the stock HU. I do not know if there's a difference between how JBL and non-JBL systems power the dash speakers.
  3. Mar 18, 2020 at 5:46 AM
    ljburns
    I forgot to mention that I started with non-JBL. I also added a 5 channel amp and piggybacked the factory wires with a harness under the front seat, but I think the corner dash speakers are powered directly from the radio. I could be wrong.
  4. Mar 19, 2020 at 10:05 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    How did you install 3.5” in the corner? What speaker did you use and how much trimming? I am trying to do it as I type this and there is no way these suckers are fitting - speakers are too deep
  5. Mar 19, 2020 at 11:45 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Mine are not actually 3.5's - I installed Kenwood excelon KCF-X2C which have a diameter of 2-7/16" and depth of 1-5/16". They drop right in...
    Mater likes this.
  6. Mar 19, 2020 at 11:49 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Perfect. Thank you!
    PWMDMD likes this.
  7. Mar 19, 2020 at 11:56 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    I installed new door speakers/tweeters, a sub and an amp before I installed the dash speakers. The stock dash speakers were really very loud compared to the rest of the system. When I added the Kenwood dash speakers they did a better job of blending in. The final touch was I had gains for the door speakers all the way down on the amp - when I increased those a little (because the dash speakers are powered by HU and the door speakers by the amp) the door speakers got louder compared to the dash speakers and now the system sounds very balanced.
    Skew12 likes this.
  8. Mar 19, 2020 at 1:44 PM
    AZBoatHauler
    So.Arizona
    I'm running 3.5" Kenwoods in the corners and used Toyota wiring adapters that plug into the stock speaker wire plug. They are being powered by a Kenwood DMX906s HU that feeds 22w RMS. All speakers except the dash (components front and rear plus subs) are powered by a 5 channel JL amp. Sound staging is good - no issues.
  9. Mar 19, 2020 at 4:02 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Did you have a depth issue with your dash speakers? Mine are bottoming out and hitting the hvac venting
  10. Mar 19, 2020 at 4:36 PM
    AZBoatHauler
    So.Arizona
    I lucked out and had no fitment issues. Its tight, but they cones are not in contact with anything and the mounting bolts both go down.
  11. Mar 20, 2020 at 4:02 AM
    ljburns
    I did have to do some cutting, but they fit fine. I don't remember what model Kickers I purchased from C-field. I logged in to my account and there isn't a way to see previous items ordered. I know that the speakers didn't touch the vents, and with some cutting away of some plastic they fit fine.
    I have my gain turned up, but I think I can go higher. I don't notice anything until I crank up the sound. Then the dash speakers are ear piercing. Maybe I just need a better speaker.
    Mater[QUOTED] likes this.
  12. Mar 20, 2020 at 4:20 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    At least with the JBL HU the volume level is not linear - it weirdly seems exponential. I know these numbers are arbitrary based on equipment and especially gain settings but it seems like 1-35 has little effect on volume, 36-45 is linear and from 46-50 volume almost doubles. Between 46-50 my dash speakers still get annoyingly loud. My sweet spot is 45 just before hitting the large increase in volume for every tick of the dial.
    mountain dweller and Mater like this.
  13. Mar 24, 2020 at 4:27 PM
    ForceV4
    ForceV4 Pull my finger
    Sacramento
    2018 DC TRD 4x4
    @AZBoatHauler Where did you get a harness adapter for the tweeters?
    I'm very reluctant to slice the OEM connections up. I found adapters for the door speakers, but nothing for the tweeters. To be honest, I wouldn't know where to begin connecting the new tweeters if I were to cut the harness. I'd be afraid of crossing wires incorrectly and doing some damage.
    For reference, I'm installing Kenwood XP6902c components up front.
  14. Mar 24, 2020 at 4:47 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    James at Tech12Volts may be able to get you a harness.
    purplenova likes this.
  15. Mar 24, 2020 at 5:22 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I connected my dash corner speakers to my head units rear speaker out, and my center channel tweeters to the head units front speaker outs(did it that way for blue tooth phone calls). Plenty of power and it sounds good. I used an amp for everything else. I have an older kenwood with about 20w per channel. I adjusted the gain on the amp so the dash and door speakers sounded about even at whatever volume.
  16. Mar 24, 2020 at 6:01 PM
    AZBoatHauler
    So.Arizona
    @ForceV4 This is what I did.
  17. Mar 24, 2020 at 7:15 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I left mine as is after installing 5 channel amp and x overs with tweeters in sail panels. I don't hear the dash speakers and that is fine by me
  18. Mar 24, 2020 at 8:11 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I have focal components with tweeters in the dash and they came with adapters for the factory dash plugs that required a little modification to work but they run off the head unit (kenwood DMX905s) with the rest of the door speakers running of an amp.
  19. Mar 24, 2020 at 10:12 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    AZBoatHauler likes this.
  20. Mar 24, 2020 at 11:07 PM
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    I've got the Metra harness for the door speakers. I couldn't find one for the dash. Turns out I don't need one. I forgot that I had to run the tweeters from the door speaker since I've installed some amplifiers. Kenwood included what I need to make this happen. Thanks for the help anyway. As usual, it was a user error.
  21. Mar 25, 2020 at 4:52 AM
    ljburns
    I'll try adjusting the gain and see how that works. I didn't replace the dash center speaker, but I have been thinking about it.
  22. Feb 9, 2022 at 12:46 PM
    Hartgex1
    Hartgex1 New Member
    Can I connect a 4ohms tweeter on the corners of the dash and still using the DVC center speaker without splicing any wire
  23. Feb 9, 2022 at 1:00 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Yes I have Kenwood KFCXC3 in the corners and they are 4 ohm. They make adapters for those factory plugs but if you are doing a tweeter you’ll need to make sure you have a crossover filter installed as well.
  24. Feb 9, 2022 at 1:01 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  25. Feb 9, 2022 at 1:08 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Check out Tech12Volts and he makes plug & play tweeters with adapters already put together.
