How did this happen?! LCA mount cracked
Discussion in 'Suspension' started by SpeshulED, May 14, 2023.
  1. May 14, 2023 at 12:19 AM
    SpeshulED
    SpeshulED [OP] New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I’ve unfortunately found a crack on one of the driver side lower control arm mount. I’m just wondering how could this have happened. The truck hasn’t seen dirt or hard driving in a long time.
    it’s currently in the process of getting fixed by being welded with adding gussets and other structural reinforcements
    bulldog93 likes this.
  2. May 14, 2023 at 12:21 AM
    blenton
    blenton New Member
    Somebody sent her just a little too hard, eh buddy?
    WalnutWest likes this.
  3. May 14, 2023 at 5:30 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep, sent harder than the kit/truck can handle. That’s one area that should be plated and reinforced. Along with the front frame rails, engine strut braces and rear frame/ trussing
    chugs likes this.
  4. May 14, 2023 at 8:18 AM
    blenton
    blenton New Member
    Technically speaking, a crack could have started a while ago when flogging it with haste, then over time that crack propagates into what you have now.
    chugs likes this.
  5. May 14, 2023 at 10:49 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Stop drill it until you get it replaced, if it is absolutely necessary to drive on it.
    TXBrit and Mr Badwrench like this.
  6. May 14, 2023 at 1:17 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    His issue is the pivot point not the arm
  7. May 14, 2023 at 2:05 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Oops, thats right. My bad.
    reywcms[QUOTED] likes this.
  8. May 15, 2023 at 7:03 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Wow, that blows.
    Looks like you are running aftermarket arms. They may be transferring too much energy through the bushings and into the frame, as opposed to the OEM rubber bushings in the arms which absorb so much more than poly bushings do. It could also be a combination of those arms and a high caster alignment putting stress on that mount, as that kind of "twists" the bushings forward during the alignment process.
    Could have also had some crazy rock or something hit the mount at some point and it cracked over time.
    SpeshulED[QUOTED][OP] likes this.
  9. May 15, 2023 at 7:08 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    It’s definitely dirtking long travel. So I’m absolutely going to say pushing harder than expected. Lol
  10. May 15, 2023 at 7:26 AM
    Vizsla
    Vizsla 2 = 2.5
    Not sure if the alignment cam was loosened for the second pic, if not it’s upside down and is likely responsible for that crack.
    reywcms likes this.
  11. May 15, 2023 at 11:55 PM
    SpeshulED
    The front of the truck is a Dirt King LT setup with triple bypasses.
    You brought up a good suggestion on too much Caster in the alignment. The truck is currently getting fixed along with cam tab gussets so I’ll re-evaluate my caster settings
    crikeymike[QUOTED] and reywcms like this.
  12. May 15, 2023 at 11:56 PM
    SpeshulED
    are you referring to the second picture?
