How DEEP can you GO..?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Echo5Golf, Sep 5, 2024.
  1. Sep 5, 2024 at 4:18 PM
    Echo5Golf
    Echo5Golf [OP] New Member
    Phil
    Tundra Hunter
    I was reading through the forums and found a thread on a “Snorkel” installation. Although fugly, in his application, valuable.
    A questions was asked without answer.
    1) “How deep can a stock Tundra go in water before there is an issue?”
    2) If the read differential breathing tube was extended and the secondary air injection intake relocated (seems like a relatively easy mod), how deep could a stock Tundra do before an issue?
    The point, maybe doing those mods alone would provide enough water clearance if doing stream/river crossings?
  2. Sep 5, 2024 at 4:23 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Keep in mind, all the electrical plugs under the hood are water resistant. Not water proof. The fan clutch would also not be happy trying to turn through water.
  3. Sep 5, 2024 at 4:30 PM
  4. Sep 5, 2024 at 4:39 PM
    The stock intake is up in the passenger wheel well so it won't suck up water for a bit. Thing is, you'll flood the cab and all the electrical stuff in it before you get to the intake.
    The snorkel for the Tundra and Tacoma are for dusty conditions on a trail, not for water crossings. You need an older less electrical vehicle for that, or you need to waterproof shit tons of wiring and connections.
  5. Sep 5, 2024 at 4:45 PM
    timsp8
    NY
    The alternator is on the lower part of the engine.
  6. Sep 5, 2024 at 4:56 PM
    jimmy1794kim
    jimmy1794kim 2021/1794/MGM
    Oregon
    2021/1794/MGM
    don’t do it.
  7. Sep 5, 2024 at 4:57 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    All depends on a lot of factors, such as skill and luck…
    If you are good and doing a quick in and out water crossing, creating a good bow wave, you can be headlight deep. But if you stop or that quick dip is longer than a few seconds, you’re done for.
    as already mentioned water will be quickly rushing in the cab. Water over the hood will come in the hvac system through the cowl and your bed is filling with water adding a lot of drag.
    Echo5Golf[OP] likes this.
  8. Sep 5, 2024 at 5:16 PM
    Mr Badwrench
    Mr Badwrench New Member
    "Snorkel" was a terrible name for these. A land snorkel maybe.
  9. Sep 5, 2024 at 5:16 PM
    Echo5Golf
    Phil
    Tundra Hunter
    This is what I needed. I’m not interested in a “Snorkel.” But a stock truck highest water level. It sounds like the depth just below the bottom door level is doable without danger. Crossing streams and rivers, not always easy as it looks. A soft stream floor or unseen dips are what worry me. How often will I be doing this? Not often. However, understanding one’s equipment limitations can save a lot of cost and headaches.
  10. Sep 5, 2024 at 5:34 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I have a firm believe:
    "Don't cross the river if you can't afford to total the vehicle"
    AgileTundra, 1UP, OldGuy03 and 3 others like this.
  11. Sep 5, 2024 at 5:44 PM
    centex
    centex New Member
  12. Sep 5, 2024 at 5:50 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Send IT!!!!:)
    I have been all up in it!
    Leo's first likes this.
  13. Sep 5, 2024 at 6:17 PM
    NWPirate
    Zach
    WA
    You can go deeper if you have a good buddy stand on your ass with his boot.. probably net you at least an inch :cool:
  14. Sep 5, 2024 at 6:19 PM
    Echo5Golf
    Phil
    Tundra Hunter
    After reading my “title” I may have misspoke….
  15. Sep 5, 2024 at 6:21 PM
    NWPirate
    Zach
    WA
    :laugh::fistbump:
  16. Sep 5, 2024 at 6:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You can submerge it up to the intake. You shouldn’t. But you can. And water won’t come gushing in neither. Just keep moving.
  17. Sep 5, 2024 at 6:35 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  18. Sep 5, 2024 at 7:00 PM
    Mr Badwrench
    Surely there's a fording depth spec for these trucks :confused: I mean, it's a truck!
    Edit: and surely google can't produce it. I just checked :rain:
    OldGuy03 and Echo5Golf[OP] like this.
  19. Sep 5, 2024 at 7:54 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I've had water come over the hood, 35s, 3" lift, no other modifications. I don't know how much of a bow wave effect I was actually getting since I was crossing a street that was flooding and effectively had become a raging river. I was shitting myself hoping it wasn't going to die. Wouldn't recommend doing recreationally, but it lived :rofl:
    Oh I found a photo from that day:
  20. Sep 5, 2024 at 7:59 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    When I saw the title I had to throw my phone in a lake off the bridge. I open this up and see me tagged in it:burp:
    :fistbump:
  21. Sep 5, 2024 at 8:02 PM
    Echo5Golf[OP] and GODZILLA like this.
  22. Sep 5, 2024 at 8:03 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Counterpoint, absolutely do it and report back.
    Echo5Golf[OP] and Tripleconpanna like this.
  23. Sep 5, 2024 at 8:05 PM
  24. Sep 5, 2024 at 8:19 PM
    centex
    centex New Member
  25. Sep 5, 2024 at 11:52 PM
    blenton
    blenton New Member
    27.6” methinks.
  26. Sep 6, 2024 at 5:55 AM
    Echo5Golf
    Phil
    Tundra Hunter
    Impressive..!
  27. Sep 6, 2024 at 5:57 AM
    Echo5Golf
    Phil
    Tundra Hunter
    I’m sensing an inside joke….
  28. Sep 6, 2024 at 6:04 AM
    You're new enough you might not know, but @Fotnot is all about being "inside" whether it's a joke or not. :rofl:
  29. Sep 6, 2024 at 7:37 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    We don’t do those here.
  30. Sep 7, 2024 at 6:41 AM
    WardenTruck
    WardenTruck New Member
    2006 OEM Tundra
    Dangerously Stock
    I’d think depth-wise, probably up to the headlights not counting a bow wave as you’re pushing it.
    At night when your headlights go under water and you suddenly can’t see in the middle of the woods, you start to question if it keeps getting deeper. Kick on the overheads and realize you’re in a river that wasn’t there yesterday.
    It was a F150 in my case, never had an issue. Guessing the Toyota could do better. So, up to the headlights for worry-free!
    Echo5Golf[OP] and bulldog93 like this.
