How can I test an RCA cable for signal or continuity
Discussion in 'Audio & Video' started by IowaGuy, Aug 24, 2023.
  1. Aug 24, 2023 at 6:37 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I ran a yellow RCA connector through my cargo trailer to hook up to my new stereo head unit. I tried to test it for the first time tonight and it didn't work. I had to splice the cable inside the trailer to be able to run it through. I suspect it might not be spliced right as there were two very small wires in the RCA cable. The yellow cable has a male connector on both ends but I have a gender changer. So, I am wondering how I can test the cable for continuity or signal. I have a voltmeter with tone testing on it.
  2. Aug 24, 2023 at 6:43 PM
    Splice is likely the issue
  3. Aug 24, 2023 at 6:48 PM
    IowaGuy
    In Process
    I am guessing so and I think I might have the two wires reversed. I might take a battery and a couple leads to test for continuity between the center post and outer shield of the cable.
