How can I convert my manual windows and door locks to power
Discussion in '1st Gen Tundras (2000-2006)' started by Seahorse, Nov 19, 2017.
  1. Nov 19, 2017 at 12:03 PM
    Seahorse
    Seahorse [OP] New Member
    2003 standard cab Tundra
    Just purchased a 2003 tundra. I would like to convert the manual windows and door locks to power. Has anybody done this conversion recently and what is required?
  2. Nov 19, 2017 at 11:27 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Doubt the locks would be a big deal, though the windows would get pricey real fast! Then again, if you don't mind used, you might find the stuff at an auto wrecker to switch the windows. You would need most of the guts from the old doors.....
  3. Nov 28, 2017 at 11:03 AM
    36tacundra
    36tacundra New Member
    2006 Tundra with a facelift
    06 Tundra king cab limited shoe horned into a 03 Tacoma
    I could help you. I wired 2 more doors into the access cab wiring, windows and door locks. I have the 06 electrical wiring diagram manual also.
    Len3_16 likes this.
  4. May 7, 2021 at 5:41 AM
    Len3_16
    Len3_16 New Member
    Len
    2005 Tundra 4x4 Reg Cab long box, bench seat, crank windows, no lift
    ARB front bumper, 3m clear ppf,
    Hey, I'm interested in adding power windows and power door locks to my 2005 regular cab long box.
    I have power windows and door locks actually I have the full doors from a 2000 access cab with the interior panel color that I need to match.
    I also have the full wiring harness from that access cab.
    I'm just wondering if anybody has mixed and matched these parts like I'm about to attempt on some rainy weekend in the future.
  5. May 7, 2021 at 8:56 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    N84434 likes this.
  6. May 7, 2021 at 4:13 PM
    Professional Hand Model
    Hand Protectors
    bmf4069 likes this.
  7. May 7, 2021 at 4:32 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I think I'd rather have manual windows given the chance. There's no need to turn the ignition to open them. Less to go wrong in the long run too.
  8. May 7, 2021 at 4:35 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    I did it about 15 years ago on my first Tundra. 2000 V-6, 2 WD. Was not that hard job. I found a junk yard online. They sold me everything on and in the doors including harness for like 250.00. So great deal.
    They where happy since most calls are for the door shell. Which they still could sell. Doors are high demand. But not the rest of the stuff.
    Been awhile so dont remember everything. But needed to also buy a couple of standard cheap relays and the sockets for those. Then run couple wires from door to door. The relay I just stuffed behind the dash.
    Never had any problems with everything working. Sold that Tundra to my neighbor. He still has it and no problems.
    I remember calling around trying to find a aftermarket shop. or dealer. Everyone said it was not possible. Said it had to be tied in to the computer or would not work.
    I could care less if the computer knew if the doors where locked or the windows where open.
    Looked at some wiring diagrams it out myself. Just wired it like a car would have been before they had computers in them. Bench tested it to make sure it would work before installed. Just to confirm wiring.
    Also from what I remember the door switches controlled the negative. Not positive power like I first expected. And like most other things.
