How big?
Discussion in 'Other Toyota Vehicles' started by VictorT, Jan 22, 2019.
  1. Jan 22, 2019 at 8:10 AM
    VictorT
    VictorT [OP] New Member
    2002 sequoia
    Hi guys, can anybody in here help me figure out how big offroad tires I can fit on my 2002 sequoia, that car is standard and does not have a lift kit on..
  2. Jan 22, 2019 at 8:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  3. Jan 22, 2019 at 8:19 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  4. Jan 22, 2019 at 8:20 AM
    VictorT
    2002 sequoia
    Thanks I'm in longmont co. My self and this is my first car
  5. Jan 22, 2019 at 8:23 AM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    Welcome from Lone Tree!
    You can fit a 33" tire on your stock sequoia. May take a little massaging of the inner fender liner on the front, but other than that you should have no clearance issues.
  6. Jan 22, 2019 at 8:24 AM
    TXMiamiFan
    Jose
    Nice. I'm in Parker right close to Cabelas.
    VictorT[OP] likes this.
  7. Jan 22, 2019 at 8:29 AM
    VictorT
    2002 sequoia
    Will it ride smooth with does big babies on ? Planing on a 4 month road trip, so I will for sure hit some highway too, and thanks so much for the advise
  8. Jan 22, 2019 at 9:01 AM
    Dirt Dawg
    Connor
    Denver, CO
    Right down the road from me! We should meet up sometime.
    All depends what your definition of "smooth" is, tire choice, and suspension set up.
    Tire choice is a big one, an all terrain with a load range of C will be smoother riding, but not hold up as well to punctures and weight. A load range E tire (BFG AT for example) is going to ride a little rougher but is a more durable tire. What are your plans for the vehicle? A mild AT might be more suitable for you than a true heavy duty AT.
    Suspension I assume will be staying stock? This should help the ride as long as shocks and everything has been maintained. Your handling will decrease with bigger, heavier tires, so also take that into consideration. Most people install an aftermarket lift/performance shocks to help with clearance and handling.
    Let us know the extent of your plans with the vehicle and we can help more.
  9. Jan 22, 2019 at 9:07 AM
    TXMiamiFan
    Jose
    Let's plan it.
    Dirt Dawg[QUOTED] likes this.
  10. Jan 22, 2019 at 10:19 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut
  11. Jan 22, 2019 at 10:38 AM
    Welcome from Aurora.
