How big is my gas tank?
Discussion in 'General Tundra Discussion' started by Changa22, Mar 14, 2021.
  1. Mar 14, 2021 at 4:55 AM
    Changa22
    Changa22 [OP] New Member
    Eric
    2020 1794 Tundra
    Thanks for all the gas tank info. When I asked my Toyota dealership about the size of my gas tank they referred me to page 111 in the owners manual about the tank average and range. I told them I wasn't buying into their explanation. The math doesn't work, either there is unusable fuel in tank or it's not a 38 gallon tank as they claim. You would think that they would share the fact that they need to have the reserve in the tank. It would explain things better rather than point out to you that you must be some kind of idiot!!! Read the owners manual.... Really!! Thanks Lancaster!
  2. Mar 14, 2021 at 5:06 AM
    Welcome from NY.
    You have a 38 gallon tank.
    szabo101 and GODZILLA like this.
  3. Mar 14, 2021 at 5:08 AM
  4. Mar 14, 2021 at 5:09 AM
    Changa22
    Eric
    2020 1794 Tundra
    I should have a 38 gallon tank. There is apparently about 6 gallins of unusable fuel.
  5. Mar 14, 2021 at 5:09 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    There always reserve when gage say 0 miles to empty.
    szabo101 likes this.
  6. Mar 14, 2021 at 5:09 AM
    Jim is correct. You have a 38 gallon tank with an overly cautious gauge. You can drive past the empty/0 miles. The fuel is not unusable.
    Cpl_Punishment and gosolo like this.
  7. Mar 14, 2021 at 6:17 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    You have a 38 gallon tank and Toyota does that on purpose. When range hits "0" you will still have about 6 gallons left.
    1. The fuel is what cools the fuel pump. Having that safety net of 6 gallons will help keep the pump submerged and cool for those that never even think about getting gas until warning lights go off.
    2. In case somebody is 50 miles away from civilization when the low fuel lights go off, this provides enough range to get you to safety.
    Not a bad thing that Toyota does this, but overly cautious compared to other manufacturers.
    Cpl_Punishment, GODZILLA and szabo101 like this.
  8. Mar 14, 2021 at 6:23 AM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Not just 50 miles away from civilization. Apparently during the snowpocalypse, you can be on I-10 200 miles west of San Antonio with no fuel on the interstate for the next 200 miles as I was. Dropped my travel trailer at an RV Park right off the interstate, drove 50 miles to the closest gas station and filled 34.7 gallons of gas, the most in my 3 years of ownership.
    Thanks Toyota for that guage that reads empty with 6 gallons left.
  9. Mar 14, 2021 at 7:31 AM
    PJR202
    PJR202 New Member
    Why do people keep saying it's unusable? Damage arguments aside, you can definitely "use" a lot of that fuel.
    Cpl_Punishment likes this.
  10. Mar 14, 2021 at 7:48 AM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    Not sure where the pickup is as I haven’t dropped my tank and looked, but it’s such a large tank that if the vehicle was off camber and or on a hill in the correct direction to move the remaining fuel away from the pickup it could be unusable. With only 6 gallons in the tank.
    At the end of the day It is a 38 gallon tank. You get plenty of range. It’s much greater than the standard tank option. The light comes on early enough to make it to a gas station and not leave you stranded. Seems like something people complain about when their trucks run without issue for 700,00 miles
  11. Mar 14, 2021 at 7:57 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Most people don't read the owners manual. That's why they have the built in reserve. Most people are idiots too. :crazy:
    If you don't believe the above responses, your manual, links and your dealers explanation, pay a garage to replace your tank with a 38gallon tank and enjoy your extra tank capacity. :thumbsup:
    DeesCrewMax and Cpl_Punishment like this.
  12. Mar 14, 2021 at 8:03 AM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    I have a 14 and did the tank swap if you had this little one and a heavy foot you would know lol.
    D4x4TRD and BravoDeltaRomeo like this.
  13. Mar 14, 2021 at 8:30 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I've said it before and, unfortunately, I'll probably say it again: if you want to put more fuel in the tank, drive farther before you stop to gas up. It's not rocket surgery.
    BravoDeltaRomeo and DeesCrewMax like this.
