Hotshot Offroad's 2021 Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by memario1214, Jul 5, 2021.
  1. Jul 5, 2021 at 8:21 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Still in its infancy, but I'd best be getting this thing started as there's a lot planned coming soon! Welcome to Hotshot Offroad's '21 Tundra build! The summary will be kept in post #1, but any chatter and "build" can be found throughout. Enjoy!
    Insta: @HotshotOffroad
    Photos as of 5/03/22:
    The Purchase:
    • 2021 Tundra Crewmax
    • Magnetic Grey Metallic
    • Limited Trim
    • Purchased Dec 22, 2020 in Pocatello, ID
    Mod List as of 9/22/22 -
    Exterior:
    • 20% Tint on front windows
    • Diode Dynamics SS3 Max Fog Lights w/Amber Backlight
    • BAKflip MX4 bed cover
    • Line-X'd bed
    • Color Matched MGM door handles
    • HitchPod w/ Custom license plate light delete harness
    • Color Matched MGM mirror caps
    • Diode Dynamics DD42 Stealth Light Bar Kit
    • FN BFD 18" Wheels in Matte Bronze
    • Falken Wildpeak AT3W 295/70/18 - Load E
    • OEM TRD Pro Grille + Color Matched MGM Hood Bulge
    • HotTails Option A - Details HERE
    • Color Matched TRD Pro Grille and Bumper Caps
    • Morimoto XB Headlights - Gen 2 - Amber DRL
    • SDHQ Ditch Brackets - Currently running Morimoto 4Banger HXB Spot Lights
    • CBI Rear Plate Bumper
    Interior:
    • MESO Customs Blackout Bits (Center Console pieces)
    • Toyota OEM center console wireless charger
    • HOTSHOT Center console replacement badge
    Suspension:
    • Elka 2.5 Reservoir Shocks F/R
    • Coachbuilder +2 Shackles
    • SPC UCAs
    Performance:
    • Dirty Deeds 10" Exhaust - Non-resonated currently and loving it
  2. Jul 5, 2021 at 8:21 PM
    memario1214
    Colton
    Missoula, MT
    What's to come aka Pile 'O Shits laying around and ready to be put on:
    • Bunch of color-matched bits from Sparks Parts
    • Dirty Deeds 10" Resonated Exhaust
    • Bushwacker Extend-a-fenders that have been color-matched MGM
    • FN BFD 18" wheels wrapped in 295/70/18 Falken Wildpeak AT3Ws
    • Elka 2" Full Suspension
    • SPC UCAs
    • Coachbuilder bumper shims for clearance
    • SDHQ A-Pillar Light Mounts (Light to go here still not decided 100%)
    • SDHQ Cab Mount filler plates
    • SDHQ Switch Pros 9100 In-Cab Mount
    • SDHQ Hood Bulge Light Mount kit
    That sure seems like plenty enough to keep me busy for quite some time... :spy:
  3. Jul 5, 2021 at 8:32 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  4. Jul 7, 2021 at 8:39 AM
    Taco-Spike
    Two Trucks
  5. Jul 10, 2021 at 5:08 PM
    memario1214
    Colton
    Missoula, MT
    CHROME REMOVAL HAS BEGUN
    Color matched door handle swap - COMPLETE
    @MightyTundraGA & @GatorBodine As promised, I am editing the video now of the swap. I recommend budgeting about 90 minutes in total and probably employ a second set of hands. Other than that... No big deal!
  6. Jul 11, 2021 at 7:56 AM
    GatorBodine
    GatorBodine New Member
    Awesome! Thanks, looking forward to it
  7. Jul 11, 2021 at 9:57 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    What are your thoughts on the DD Max fogs? I feel like they would overpower the stock LEDs.
  8. Jul 11, 2021 at 9:59 AM
    memario1214
    Colton
    Missoula, MT
    You mean the stock LED headlights?
    They absolutely overpower them. Given the intended use case though (lower speeds, maximum width, etc) they are excellent at their job.
    ToyoMafia and French Avocado like this.
  9. Jul 11, 2021 at 2:08 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Yea I meant the LED headlights. Valid points. I have the PROs on my 4Runner, but also have an HID retrofit that's significantly brighter than the Tundra LEDs. Not sure which ones I'll get for the Tundra yet.
    Looking forward to seeing this build come along, looks like you've got good plans already.
  10. Jul 12, 2021 at 7:36 AM
    memario1214
    Colton
    Missoula, MT
    Here's the best I can guide you on selection if you are waffling between pro and max... If you are looking at the white color temp there is a pretty large jump in output between the two, plain and simple. However, if you go yellow (which I and others have) the difference isn't quite as great. The Max emitter only comes in a 6000k emitter so DD had to use a darker yellow lens on the Maxes to bend the light to the proper color temperature. As a result, the bump in output over the Pros isn't as large as it is in the white variant. Don't get me wrong... They're still coconuts.
    Additionally, the Max has a crisper cutoff. It uses a smaller emitter than the pro and as a result ends up with more crisp cutoff lines on the road ahead. I personally prefer the sharp cutoff of the max. If someone is looking for the best option for the money the pro is still best there is IMO. However, if you want the BEST... There is currently nothing that I am aware of that outperforms the Max.
    I could take some pics if you would like of the output to show you how powerful they really are.
    ToyoMafia likes this.
  11. Jul 12, 2021 at 8:08 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Yea I think the yellow is better all around. I’m in Colorado and live in an area where I’m frequently on unpaved and unlit roads. During the winter, which is when I use my fog lights the most, the yellow is perfect. The white light is ok on the snow, but yellow is far superior.
    The Pros were challenging to get right because of that soft cutoff, so that alone may push me to get the Max this time around. No need to make a special trip for output pics, but if the opportunity arises in your day I won’t complain.
  12. Jul 12, 2021 at 8:11 AM
    memario1214
    Colton
    Missoula, MT
    Just take a drive up to good ol' Montana and I can show you! I have them on hand too so I could just send you back with a set :rolleyes::laugh::cool:. You'll definitely want to go Pro or Max though as they're the only ones that will get hot enough to melt all that Colorado snow and they'll remain clear.
    I'll see if I can snag a pic or two next time I'm out though.
  13. Jul 14, 2021 at 11:38 AM
    memario1214
    Colton
    Missoula, MT
  14. Jul 14, 2021 at 4:13 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I don’t get up to MT often enough. Great place!
    Good point on the heat for snow/ice melt too. Didn’t think of that.
  15. Jul 14, 2021 at 4:17 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Can't wait to see the progress. Looking good!
    memario1214[OP] likes this.
  16. Jul 14, 2021 at 5:43 PM
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
  17. Jul 14, 2021 at 6:01 PM
    memario1214
    Colton
    Missoula, MT
    Thank you sir!
    Appreciate it! Certainly plenty of work to do on my skillz, but it should help someone!
    06tacomadc[QUOTED] likes this.
  18. Jul 14, 2021 at 6:10 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    :popcorn:
    So when do the 40s go on?
    ToyoMafia and 06tacomadc like this.
  19. Jul 14, 2021 at 6:21 PM
    MightyTundraGA
    MightyTundraGA New Member
  20. Jul 14, 2021 at 6:24 PM
    memario1214
    Colton
    Missoula, MT
    When you show up with the cutting wheel, the rubber, and the fiberglass fenders.
    ToyoMafia, MTRock and French Avocado like this.
  21. Jul 14, 2021 at 6:26 PM
    Squatting Pigeon
    Holden
    North Texas
    I see how it is o_O
  22. Jul 14, 2021 at 6:28 PM
    memario1214
    Colton
    Missoula, MT
    I feel like my demands are pretty reasonable.
  23. Jul 14, 2021 at 6:29 PM
    Squatting Pigeon
    Holden
    North Texas
    Now you sound like my ex wife :boink:
  24. Jul 14, 2021 at 6:40 PM
    Cfincke
    San Antonio
    Cannot wait to see the progress of your build!
    Not sure if you have read up on the icon tubular UCA issues on tundras, but after dealing with and replacing the tubular ones I wish I would have went with the billet ones.
  25. Jul 14, 2021 at 6:41 PM
    memario1214
    Colton
    Missoula, MT
    To include the Delta Joint variant? EDUCATE ME
    I've heard some mixed thoughts on them from just grumblings, but once the tech came out I had myself convinced I wanted to try it.
  26. Jul 14, 2021 at 6:54 PM
    Cfincke
    San Antonio
    The tubular ones (both uniball and delta-joint) have less caster than stock arms, icon revised their instructions in 2018 adding a note that the tie rods need to be cut shorter. This is to help get in alignment specs. The billet arms are adjustible and can be adjusted after installed. The other UCAs that are adjustible after install are the Element and the SPC brands.
    Photo of the icon tubular on top of MCM UCAs, photo from @831Tun
  27. Jul 14, 2021 at 7:02 PM
    memario1214
    Colton
    Missoula, MT
    Weeeeelllll hell. I'll go read the instructions then. Appreciate the tip, because imma need the adjustability. Surprised I never tumbled to this info, honestly. I had SPC UCAs on my Tacoma and they were good. Nothing to look at, but they did the job.
  28. Jul 16, 2021 at 8:37 AM
    memario1214
    Colton
    Missoula, MT
    Amber DRL Gen 2 Morimoto XB Headlights shall be here Monday. One more thing to add to the pile that I need to put on. :bananadead::bananadead::bananadead:
  29. Jul 17, 2021 at 7:36 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I looked at these briefly too. I’ll be interested to hear what you think about them in comparison to the stock LED headlights.
  30. Jul 17, 2021 at 7:50 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    What about the interior chrome removal?
