Hot Off The Press
Discussion in 'General Tundra Discussion' started by rons23, May 22, 2019.
  1. May 22, 2019 at 5:50 PM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  2. May 22, 2019 at 8:19 PM
    Brocksw
    Brocksw New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    Highly doubt it will get 30, that lexus motor they talk about that gets 33 is in a car. Besides they're gonna gear it differently and if those numbers are correct they'd be going after best in class power specs and presumably better towing. But even if it was 20 mpg city and 23 hwy that would be a vast improvement. I'm not familiar with the Lexus motor mentioned (V6 twin turbo) ...but my first question is do they act like the Ford ecoboosts and have the mpg shit out after 50k miles?
    This article seems much more legitimate than other things I've heard about the next engine choice.
  3. May 22, 2019 at 8:23 PM
    If true the torque #'s don't suck.
    TheBeast, Watt maker, OR18TRD and 2 others like this.
  4. May 23, 2019 at 1:45 AM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    I’m gonna assume here and say if Toyota is using the motor out of a $100k car it’s a pretty good swap for the current 5.7. I’m hoping this is true might move up to the new model if true
    619Tundra and rons23[OP] like this.
  5. May 23, 2019 at 2:15 AM
    rons23
    Ron
    Kill Devil Hills
    450HP and 500# Torque :militarypress:
    Watt maker likes this.
  6. May 23, 2019 at 2:18 AM
    Grumpy Uncle
    Pat
    CO
    I'm keeping my 16"!
    aperezsh, Tundra_361, Ostrich and 3 others like this.
  7. May 23, 2019 at 4:51 AM
    Stig
    Stig New Member
    The 5.7 is used in a $100k vehicle too.
  8. May 23, 2019 at 4:51 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    450 hp and 500 lb-ft of torque would be great, but I do not want a V6!
    Doomsday, Ps3udonymous and Ostrich like this.
  9. May 23, 2019 at 5:00 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    "The inside source claims that Toyota’s full-size truck will use a version of the company’s 3.5-liter turbocharged V6 engine..."
    In that case, the trucks we have now will be the last great truck Toyota ever made. The two years I spent in my 2016 Tacoma with that garbage motor were utterly miserable. So much so, that I would never, ever buy another Toyota with that engine under the hood ever again. Go ahead and turbo charge it. This "one size fits all" approach Toyota is taking with putting the same engine in every vehicle is a terrible mistake, in my opinion. I really hope this article is incorrect.
  10. May 23, 2019 at 5:09 AM
    motocrossman99
    motocrossman99 New Member
    Josh
    2019 Barcelona Tundra SR5
    Also another thing to consider is how much faster will it wear out because of the constant high pressure due to the turbo in it? no thanks i like my 5.7 that will go for hundreds of thousands of miles :thumbsup:
    Ostrich, 15whtrd and Max Power like this.
  11. May 23, 2019 at 5:19 AM
    socal147
    socal147 None Specified
    Patrick
    Oak Hills Commiefornia
    2019 Tundra Tonka
    Stock is so temporary
    I will take a normally aspirated V8 over any turbo charged anything all day
  12. May 23, 2019 at 5:27 AM
    15whtrd
    15whtrd Mr. Blonde
    Turbo 4.6L would be better. Best of both worlds.
    Darkness and Watt maker like this.
  13. May 23, 2019 at 5:54 AM
    NMTundra
    NMTundra New Member
    Problem is CAFE standards that are basically guaranteed to become more stringent in the next 8 years, the 4.6L is already an inefficient engine. Like it or not, TT'd V6s are going to become a mainstay in 1/2 ton trucks. FWIW, I've got a 2.7L TTV6 in my crew cab F-150 from work and get 21-23 MPG on the highway at 75-80 mph which would translate to probably 25 hwy on the government ratings. I'd bet this engine will be closer to 22-23 mpg rated and get 20-21 in the real world.
  14. May 23, 2019 at 6:11 AM
    15whtrd
    15whtrd Mr. Blonde
    Don’t like it. Mpg is the only thing good about that. I personally feel those V-6 turbo’s are going to get tired early if they are putting in work. I mean real work i.e. towing heavy loads etc. probably creating more waste as owners get rid of those trucks early. Just my opinion obviously.
  15. May 23, 2019 at 6:16 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    The problem with the Tacoma’s isn’t the motor, it’s under geared from the factory. Put new gears in it and they quit hunting around constantly.
  16. May 23, 2019 at 6:17 AM
  17. May 23, 2019 at 6:18 AM
    NMTundra
    NMTundra New Member
    I don't disagree. I'd say it's just going to become even more imperative to jump from a 1/2 ton to a 3/4 ton diesel if you're going to be doing much towing. That being said, a huge percentage of 1/2 ton trucks (and probably 3/4 ton for that matter) on the roads in the US will never pull a trailer or haul anywhere near payload, manufacturers know this and know they can generally get away with these TTV6s because of it.
    I will say, we run 100% F-150s in our company fleet and most are incredibly abused, we've had no engine failures that I've heard about on the TT engines so far but we also didn't with the 5.0L or 5.4L that came before.
    15whtrd[QUOTED] likes this.
  18. May 23, 2019 at 6:19 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've heard people mention this. In your opinion, did Toyota do this for cost reasons or was it just a mistake on their part? What would be the reason for it being under geared?
  19. May 23, 2019 at 6:20 AM
    NMTundra
    NMTundra New Member
    More than likely did it to try and get the truck rated more efficiently. All of this is in response to the CAFE standards.
    15whtrd likes this.
  20. May 23, 2019 at 6:21 AM
    Rex Kramer
    Georgia
    The American "A turbo is God's way of saying there isn't enough cylinders"
  21. May 23, 2019 at 6:21 AM
    TexasTundra27
    Mark
    I’m no engineer by any means, someone said they probably did it because of emissions but that doesn’t make much sense since they do better once they’re regeared. Honestly I’m not sure what they were thinking, but I really hope they don’t make the same mistake with the new Tundras.
    15whtrd likes this.
  22. May 23, 2019 at 6:23 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Aren't those hp/tq numbers less than the 5.7 with the supercharger?
    So those numbers aren't bad as a baseline, but if you're unsatisfied with the aftermarket options to add power on the 5.7 just wait until you've got a engine already using forced induction and a hybrid system.
    There won't be much you can do to increase performance that won't cost you $$$. And you'll have to wait a long time before the aftermarket has time to respond with options.
  23. May 23, 2019 at 6:25 AM
    15whtrd
    15whtrd Mr. Blonde
    Ahh yes. Even better is plenty of cylinders with a turbo! LOL
  24. May 23, 2019 at 6:26 AM
    NMTundra
    NMTundra New Member
    This isn't necessarily true, it just depends on how "hot" the tune is from the factory (it might be pretty hot though to get those numbers), the 3.5L Ecoboost crowd saw some pretty amazing gains just from tuning that engine. That being said, the new Raptor 3.5L is a better analogy and I'm not sure what people have seen out of that or if anything at all.
  25. May 23, 2019 at 6:26 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I’m glad !! Now I can stop thinking about that 3.5 EB..
    sk8142 and Newm like this.
  26. May 23, 2019 at 6:28 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m sure you are correct. Just kind of a bummer I guess. I don’t mind the V-6 for daily use but it would it be nice if they still offer a V-8 as well. I would assume that the 4.6 L, while being inefficient, could be come more efficient with a turbo? If they could get that right, I think it would sell big-time. The only manufacture to offer a V8 turbo in a half ton.
  27. May 23, 2019 at 6:30 AM
    socal147
    Patrick
    2019 Tundra Tonka
    Turbos will be around in numbers until the public figures out they are a maintenance nightmare with a limited life span. Then the lots will be full of used ones. Ford is leading the way.
    M C M likes this.
  28. May 23, 2019 at 6:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I hope those pictures are wrong. It still looks about the same, ugly as sin. It's too round.
  29. May 23, 2019 at 6:35 AM
    Do you have some data to back that up, or are you just winging it?
    I’ve seen a fair share of Turbo charged motors with 2-470k miles on the factory unit.
    Mwray8909 likes this.
  30. May 23, 2019 at 6:36 AM
    NMTundra
    NMTundra New Member
    The 4.6L (and 5.7L for that matter) could probably be quite a bit more efficient if Toyota really wanted to make it so, however you eventually get to a point of diminishing returns especially if you're not going to be using it in any other vehicle unlike the 3.5L which has a more universal application and will automatically always have a fuel efficiency edge.
    The funny thing is, GM has proven for years that you can make a large displacement/high horsepower pushrod V8 that is as fuel efficient, or very nearly so, as the smaller TT V6s. DOHC V8s on the other hand (from any manufacture), while being more powerful for the same displacement, have never really managed to be fuel efficient.
    CMB and 15whtrd[QUOTED] like this.
