Horn stopped working!!!
Discussion in '2nd Gen Tundras (2007-2013)' started by CTB Mike, Aug 1, 2020.
  1. Aug 1, 2020 at 4:32 PM
    CTB Mike
    CTB Mike [OP] It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Not really looking for a fix, I'm just ranting. 2 weeks into trip with my travel trailer, my horn decided to fail me! Fuse is good, I guess it'll have to wait until I get home. Utah is stunning!
  2. Aug 2, 2020 at 4:07 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Reminds me of a bumper sticker..
    "horn broke, watch for finger"
  3. Aug 2, 2020 at 6:19 AM
    BIGUGLY
    Paul
    2018 Limited
    Clock spring. Most likely
    NewImprovedRon likes this.
  4. Aug 2, 2020 at 6:34 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Check the horn connector. My tacoma had a positive only connector. Meaning the horn is grounded through the frame. Essentially the bolt that fastened the horn to the radiator core support.
    Since there are 2 horns (high/low pitch), unplug and test for continuity/ voltage one at a time if you have a multi-meter handy.
    It could just be a bad ground. It's possible only 1 horn has been working and you never noticed.
    EDIT: NVM don't listen to my advice. Keep driving around without a horn. People are oblivious to the braking needs of truck+trailers and now you have no way to warn them. Not trying to fix it immediately shows your willingness to neglect the safety of yourself and others on the road.
  5. Aug 2, 2020 at 6:47 AM
    You must have inadvertently activated Stealth Mode!
    trucksareforgirls2 likes this.
  6. Aug 2, 2020 at 8:54 PM
    CTB Mike
    Southern Arizona
    Thanks for the suggestions!
  7. Aug 3, 2020 at 12:37 AM
    Pnoy_toy
    Pnoy_toy New Member
    Mine failed a month ago, it only worked if I was turning a corner...ended up being the clock spring
  8. Aug 22, 2020 at 6:58 PM
    CTB Mike
    Southern Arizona
    Horn fixed! Replaced clock spring, 30 min, easy!
    NewImprovedRon and Inquiringone like this.
