Horn relay
Discussion in '2nd Gen Tundras (2007-2013)' started by Hevy767, Dec 13, 2020.
  1. Dec 13, 2020 at 8:41 AM
    Hevy767
    Hevy767 [OP] New Member
    2011 Tundra
    Good morning,
    I have read most of the posts regarding the horn not working. I have followed all of the suggestions. The most confusing thing for me is that my tundra does NOT have a horn relay in the fuse box under the hood! If it is not there, where would it be located?
    All of the controls in the steering wheel work except the horn.
    Thanks,
  2. Nov 13, 2022 at 3:48 PM
    Cowgirl
    Cowgirl New Member
    2011 Toyota Tundra SR5 4WD
    I’m having the exact same issue. Did you ever find a solution?
  3. Nov 13, 2022 at 4:45 PM
  4. Nov 14, 2022 at 2:21 PM
    Cowgirl
    Cowgirl New Member
    Thanks for responding George. It’s not the fuse. I’ve already checked that. I haven’t found a relay location for it. I’m thinking it’s the clock spring but it’s only the horn that’s not working. Cruise control works perfectly fine. I’ll hold off on testing the airbags until I need them (LOL). I’ve run out of ideas outside of replacing the clock spring and hope that’s it. I’d love to hear any ideas, especially ones that are easier than pulling the steering wheel off. :)
  5. May 20, 2023 at 3:07 PM
    CajunClark
    CajunClark New Member
    Clark
    2012 Toyota Tundra SR5
    So what did you figure out?
    My horn quit too, but the panic button activates the relay and horn just fine. Pulled the airbag with the horn switch and it shows continuity and break when pushing the brackets. It's got to be the clock spring/spiral cable right?
  6. May 29, 2023 at 10:45 AM
    jd77
    jd77 New Member
    Any updates here? My horn is out as well. Curious to see the steps you guys took and if a solutions was found.
  7. May 29, 2023 at 11:34 AM
    CajunClark
    Clark
    I fixed mine by changing the clockspring/spiral cable behind the steering wheel. First confirm that your horn and relay are actually working by activating the panic button to make the horn blow. If that's working, it eliminates the horn, relay and fuse.
    Watch this video to get an idea what the part is you are going to replace. https://www.youtube.com/watch?v=8XuqOoMkKv4&t=35s
    I ordered my clockspring from Rock Auto part number 525405 for $47.79 and got a wheel puller from Harbor Freight number 62620 for $17.99 to remove the steering wheel.
    The video shows just about everything to do. However, the two T-25 torx and the 19MM steering wheel nut were real tight and I had to hit them with an impact driver. Also, behind the clockspring is a STEERING SENSOR that must be removed and put on the new closkspring assembly prior to install. Don't rotate the old clockspring too much when you remove it to keep that sensor in line and transfer it to the new part. It just clips to the back.
    Otherwise a very easy changeout. Good luck.
    jd77 likes this.
  8. May 30, 2023 at 12:42 AM
    jd77
    jd77 New Member
    Wow that was a very informative write up. I appreciate all the resources too! thanks!
  9. Oct 14, 2024 at 12:59 PM
    makscoot
    makscoot New Member
    Scott
    2013 White Tundra TRD
    N/A
    great details here. tested relay, panic and fuses, all leads to clock spring on my 2013 tundra. Thanks to all the contributors.
