Horn problems
Discussion in '2nd Gen Tundras (2007-2013)' started by Walker, Feb 4, 2017.
  1. Feb 4, 2017 at 2:07 PM
    Walker
    Walker [OP] New Member
    Idaho
    Black 2011 crewmax
    Iron cross bumpers, 3 inch lift, custom made rocker guards, fender flares, lightbar, tow mirrors.
    Alright guys i cant get my horn working. Replaced them with new factory horns hoping for the best and no luck. I now have my steering wheel totally apart i jusy cant get it off to look at wires, clock spring etc. Any ideas how to get the steering wheel off or what,could be causing my problem?
  2. Feb 4, 2017 at 2:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Feb 4, 2017 at 2:22 PM
    Walker
    Idaho
    Black 2011 crewmax
    Didnt give me what i needed thanks though
  4. Feb 4, 2017 at 2:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The few threads I've read of people pulling off their steering wheel used a steering wheel pulling tool.
  5. Feb 4, 2017 at 2:40 PM
    Walker
    Idaho
    Black 2011 crewmax
    Ah figures i have to have a special tool ha. Thanks for the info on that, i mainly just wanted to see if my clock spring had a pinch in it
  6. Feb 4, 2017 at 2:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They're not too expensive. Usually like $15. You can probably rent one for free from Autozone.
  7. Feb 4, 2017 at 2:46 PM
    Walker
    Idaho
    Black 2011 crewmax
    I will definitely have to look into that, if i find anything ill update here. Thanks joon.
    joonbug likes this.
  8. Feb 4, 2017 at 3:35 PM
    The horn mounting surface is free of corrosion or anything else right?
    That is the ground.
  9. Feb 4, 2017 at 3:49 PM
    Walker
    Idaho
    Black 2011 crewmax
    Yes i made sure to scrape he surfaces and make sure their clean.
    ColoradoTJ likes this.
  10. Feb 4, 2017 at 4:17 PM
    Relay good? Not to insult you, I am assuming the 10A fuse was checked.
    NewImprovedRon likes this.
  11. Feb 4, 2017 at 4:27 PM
    Walker
    Idaho
    Black 2011 crewmax
    Haha no your good. Yes i checked both though. My horn would work with the wheel turned 90 degrees left or right but nowhere else and now it doesnt work at all
  12. Feb 4, 2017 at 4:29 PM
    Mike Tread lightly.
    south carolina
    Clock spring is bad.
  13. Feb 4, 2017 at 4:43 PM
    Walker
    Idaho
    Black 2011 crewmax
    I take it you had the same problem?
  14. Feb 4, 2017 at 5:29 PM
    Mike Tread lightly.
    south carolina
    No.. I have diagnosed enough of them.. horn, air bag, steering wheel controls go-to shit.. not just Toyota ,GM ,ford, honda and Mercedes I have worked on.
    I thing I tell people it holds true to my 95 Tacoma still has the original clock spring. Always always when parking the vehicle keep the steering wheel straight. That keeps the spring relaxed.
  15. Feb 4, 2017 at 5:45 PM
    Walker
    Idaho
    Black 2011 crewmax
    Oh gotcha. Well thanks for the input man, looks like ill be tearing into that next weekend.
  16. Feb 4, 2017 at 6:01 PM
    Mike Tread lightly.
    south carolina
    Please disconnect the battery to do the airbag.. it's not hard you can rent a tool for puller for the wheel.
  17. Feb 4, 2017 at 6:17 PM
    Walker
    Idaho
    Black 2011 crewmax
    Ive already had the air bag out twice tryin to look at stuff haha. Just need to get the wheel puller.
