Horn issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Aug 4, 2021.
  1. Aug 4, 2021 at 2:13 AM
    Jon1979
    Jon1979 [OP] New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    I am worried that I may know the answer to this but here goes.
    I was doing a check over on my 2011 Tundra getting ready for my NY inspection and I found that the horn was not working. Did the usual checking of the fuse and wires to the horns and everything was fine there. When I tried again the horn worked.
    The next morning I tried again and nothing. What I did find is if I turn the wheel a few degrees say 3 o'clock the horn works every time. So I am thinking there is a loose connection in the column. If that is true can I even service that with the air bag?
    Any help will be apricated because would you know it my inspection is up at the end of August.
    Thanks
  2. Aug 4, 2021 at 2:21 AM
    18" TRD Off Road Wheels
    You can work around an airbag. You just want to disconnect your battery. I know that @2020Platinum has a video for a 3rd gen steering wheel tear down, but I'm sure there are others out there for the 2nd gen steering wheels.
    2020Platinum likes this.
  3. Aug 4, 2021 at 8:49 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I have same issue as you. Over the course of a year the horn barely works anymore when spinning the wheel to a certain position. I just ordered a clockspring so when I find time to install it I will check back with you to let you know my results. Good luck in the meantime.
    NewImprovedRon likes this.
  4. Aug 4, 2021 at 9:28 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Can you put one of these in the cup holder?
    Yes, you can replace the clock spring yourself.
    D4x4TRD likes this.
  5. Aug 4, 2021 at 8:06 PM
    OldHilux
    OldHilux New Member
    2012 Toyota Tundra SR5
    I have a non-functional horn, and a clock spring on the way from Olathe Toyota. I'll post up results when I've got it replaced
    D4x4TRD likes this.
  6. Aug 5, 2021 at 10:07 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Just hang one of these in the back window. Much cheaper. :D
    D4x4TRD and Cpl_Punishment like this.
  7. Aug 5, 2021 at 10:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Common on the 2nd gens now that they’re aging, bad clock spring for sure. 15-20 minute job, just disconnect the battery and play it safe around the airbag.
    D4x4TRD and NewImprovedRon like this.
  8. Aug 6, 2021 at 11:19 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    Well today is the day. Got a friend coming over to help assist on an attempt to change this clockspring. I’ll post back later to let OP know the results. Hopefully I don’t fudge this up. Lol
  9. Aug 6, 2021 at 6:13 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    You’re right. Got it done. Issue is gone. Horn works again.
  10. Aug 9, 2021 at 11:28 AM
    OldHilux
    OldHilux New Member
    Got it done. I removed the negative battery cable for 15 minutes prior following the tech thread on here. The new clock spring fixed my horn.
    Either that or it was the honk fluid drain and flush. I'm so happy I got one made before 2019 when Toyota went and deleted the honk fluid cooler :laugh:
    Tundratoofun, bleach, D4x4TRD and 2 others like this.
  11. Aug 10, 2021 at 12:27 PM
    Jon1979
    Jon
    Upstate NY
    Have a new clock spring on order from rockauto. Not a cheap part unfortunately. Thank you all for the help.
    D4x4TRD likes this.
  12. Aug 10, 2021 at 1:07 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I hope you used the correct synthetic ULDT honk fluid.:confused: o_O Everything else just blows.
    Ultra Loud Dual Tone.
    bleach and D4x4TRD like this.
  13. Aug 11, 2021 at 5:19 AM
    Jon1979
    Jon
    Upstate NY
    I ordered a 5 gallon jug of the best synthetic honk fluid I could find. It was cheaper that way and should last me forever. :monocle:
    bleach, D4x4TRD and landphil like this.
  14. Aug 13, 2021 at 12:07 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    GODZILLA and D4x4TRD like this.
  15. Aug 19, 2021 at 8:50 AM
    Jon1979
    Jon
    Upstate NY
    I installed the new clock spring yesterday afternoon and all is well now. I did almost give myself a heart attack though. I did not get the air bag seated correctly and when I hooked the battery terminal back up the horn started blaring. I had to wait another 15 minutes and then reposition it.
    D4x4TRD likes this.
