Horn and dome lights keep blowing fuse
Discussion in '2nd Gen Tundras (2007-2013)' started by Dollfinfan75, Feb 14, 2020.
  1. Feb 14, 2020 at 9:44 AM
    Dollfinfan75
    Dollfinfan75 [OP] New Member
    Bill
    2011 limited tundra
    Trailer brakes
    Recently my horn/ dome lights started only working intermittently one day and it started blowing the 7.5 amp fuse under the hood. Some days it'd last a week some days 1 hour, now it pops immediately. It's only driven on the weekends to pull my boat to the lake, 90,000 miles on the truck, no modifications except trailer brakes 3 years ago, other than that nothing else has been done. In a moment of irrational thinking I put a 25 amp fuse in the slot and it worked for a month but one day I noticed a burning smell from my upper dome lights area. I jumped out and pulled the fuse and haven't touched it since, now the nagging of my wife has forced me to either fix it or trader it in but I'm too cheap to get rid of a great truck for practically no reason. Any ideas or suggestions would be great. Thanks Bil V
  2. Feb 14, 2020 at 10:12 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    It's shorting out somewhere. Got any rodent problems?
  3. Feb 14, 2020 at 10:27 AM
    Dollfinfan75
    Bill
    2011 limited tundra
    Trailer brakes
    None that I know of
  4. Feb 14, 2020 at 10:28 AM
    Dollfinfan75
    Bill
    2011 limited tundra
    Trailer brakes
    None that I know of
  5. Feb 14, 2020 at 10:32 AM
    15whtrd
    15whtrd Mr. Blonde
    I would check all the wiring to your trailer brakes and make sure it’s not grounding out on something. Also, when it blows the fuse, is it when you’re turning the wheel? Possible spiral cable/clock spring. I’m on a roll today, LOL second time I’ve brought that part up.
    NewImprovedRon likes this.
  6. Feb 16, 2020 at 12:12 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Sometimes a bad horn will blow fuses. I've had that happen on a Ford. I'm not sure yet what brand are used on Toyotas but they look similar to the ones on a Ford.
