Hood scoop questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by dmeneses1983, Mar 27, 2018.
  1. Mar 27, 2018 at 1:42 PM
    dmeneses1983
    dmeneses1983 [OP] New Member
    Dennis
    2016 Silver Tundra
    Does anyone know if you can get the entire hood with the hood scoop already on it? Like the 2018 hood with the scoop? Cause from browsing Roman's OEM thread, looks like you have to buy multiple parts and modifyto install the hood scoop into your original hood? Is that correct?
  2. Mar 27, 2018 at 2:03 PM
    I believe you are correct, have to drill holes in your hood from what I've heard, or you can get the RK Sport hood
  3. Mar 27, 2018 at 2:13 PM
    dmeneses1983
    Dennis
    2016 Silver Tundra
    ahh I see, hoping the dealers already have the hood with the scoop attach
  4. Mar 27, 2018 at 2:44 PM
    Possibly, send PM to @Roman
    Roman likes this.
  5. Mar 27, 2018 at 5:30 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Unless there's a secret part number not yet published, I've not seen the full hood with the scoop on Cool Springs or Sparks.
    IMO either way, its a lot to pay/mod and still be a non-functional hood.
    Like @aramirez73 noted, you can check out RK Sport or Amerihood. Both have to be painted, and you'd need to have an open top CAI (like a S&B, Volant or K&N) to make use of them.
    https://www.lmperformance.com/66002...with-ram-air-scoop-heat-extraction-vents.html
    https://amerihood.com/toyota-tundra-2014-2018-ssk-style-functional-heat-extractor-ram-air-hood.html
  6. Mar 27, 2018 at 5:42 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Unless I am mistaken, the Toyota hood scoop is non-functional. Just say no to fake hood scoops.
  7. Mar 27, 2018 at 5:46 PM
    Functional or not it makes the Tundra look BA! I want one anyways
    Skippy, Boerseun and Coolhardy like this.
  8. Mar 27, 2018 at 7:58 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    If you add a hood scoop, make it different and make it functional. To
    be different, have a Tundra hood modified with a hi-rise area that has an open plenium at the rear. Pull air in from that hi pressure area (like Chevy did on the SS Chevelles, and Ford did on the 64 Thunderbolts). Now that would be very cool, and not look like a 16 yr old kid added a scoop above an already existing fake scoop (the bulge). Two fake hood scoops looks like s**t IMO.
  9. Mar 27, 2018 at 8:07 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    And while your at it add the third scoop, now that's BA! ...jk..;)
  10. Mar 27, 2018 at 8:25 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Why would you want one?
    It's a truck.
    Eclipsed & Floating likes this.
  11. Mar 28, 2018 at 4:02 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Mike.............:smack:
    It’s to vent and cool the engine from all those turns in Monte Carlo
  12. Mar 28, 2018 at 4:13 AM
    Yes... I posted a link here on a different recent scoop thread. I'll have to look it up. Been under the weather. A total hood replacement. Completely functional hood scoop. There is a carbon fiber version. Not cheap but not bling. Hate non functional bling. I believe the info was on Luverne.com
  13. Mar 28, 2018 at 7:06 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    There is a hood with pre drilled holes available from Toyota, but it does not come with the scoop parts. All scoop parts would have to be purchased, along with a new hood if you did not want to drill into your own hood. It all has to be painted as well. We do not ship hoods.
