Hood cowl
Discussion in 'Lighting' started by 14burrito, May 10, 2017.
  1. May 10, 2017 at 6:28 AM
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
    I installed some lights last night and was wanting to run my wiring underneath the hood cowl.
    Ideally what I really wanted to do is just lifted up on the engine side to slightly past the sheet metal so I could just tuck he wiring behind. So I went ahead and popped all the clips out that retained it, and I couldn't get the actual plastic to push up and separate from the front portion of that sheet metal in the engine bay.
    So I was curious if anyone to remove the hood cowl and if they could provide some insight please.
    I'm guessing at this point in order to remove it you have to remove the wipers but for what I'm looking to do just tuck some wiring underneath and behind I don't really want to have to go through all that effort.
    Thanks!
  2. May 10, 2017 at 8:45 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    2014
    Ill give that a look over, thank you
    NewImprovedRon likes this.
