Hood Bulge question
Discussion in '2.5 Gen Tundras (2014-2021)' started by paradizecityz, May 24, 2020.
  1. May 24, 2020 at 7:43 PM
    paradizecityz
    paradizecityz [OP] New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Can you buy just the mesh part of the hood bulge?
    I'm thinking of doing the raptor lights there and looks like I have to drill a hole bigger. Just seeing how I can reverse it if I change my mind.
  2. May 24, 2020 at 7:45 PM
  3. May 24, 2020 at 7:46 PM
    paradizecityz
    Richmond, TX
    Figured he's off and enjoying the holiday and seeing if another member knew lol
    Thanks though :)
  4. May 24, 2020 at 7:47 PM
    I'm sure it's a separate part
  5. May 26, 2020 at 5:19 AM
    ExcludedTim
    ExcludedTim New Member
    2015 BRM SR5 DC
    Pretty sure that’s incorrect. That looks like the hood scoop insert. I’m almost positive it’s part of the bulge purchase itself.
  6. May 26, 2020 at 5:33 AM
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    Opps my bad. This is the break down of the hood bulge
  7. May 26, 2020 at 7:30 AM
    paradizecityz
    Richmond, TX
    Dang...guess I could always find a cheap chrome hood bulge and swap the mesh insert over...Thanks!
  8. May 26, 2020 at 7:35 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Hey paradizecityz!
    You could always use your original out of your chrome bulge. You maybe even do like I am, take your original chrome set up and color match it so you can “swap” without much fuss if you change your mind about the lights.
    I am doing my chrome grille surround this way with a “limited” insert. I will have the original insert “mesh” inside my bulge just in case I change my mind and do not want to run the NSV bar that sits in my current color matched bulge.
    Of course this is a “work in progress” that does not require any truck down time.
    Cheers, amigo!
  9. May 26, 2020 at 7:59 AM
    paradizecityz
    Richmond, TX
    I already sold my old chrome bulge lol
  10. May 26, 2020 at 8:22 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Or add a light bar....problem solved
    paradizecityz[OP] likes this.
  11. May 26, 2020 at 8:26 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Ahh shucks man!
    Yeah I don’t get rid of my OEM stuff for a while just for this sort of thing. I do have the black insert out of my color matched bulge that I may possible be able to part with...
  12. May 26, 2020 at 8:28 AM
    paradizecityz
    Richmond, TX
    The only reason I'm doing this is because when I switched to the color matching grill, I couldn't put my front camera in same spot and had to move it up above the emblem (which I wanted to anyways) but I have raptor lights and so the camera is not centered. Just will move raptor lights out of grill and do new ones in the hood bulge and center my camera. I like the look now but was just asking ahead of time in case I grew tired of it and wanted to remove the lights so no rush now :)
  13. May 26, 2020 at 9:23 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    The black plastic part of the hood bulge is not sold separately.
  14. May 26, 2020 at 9:26 AM
    paradizecityz
    Richmond, TX
    Thanks Roman!
    Roman[QUOTED] likes this.
  15. May 26, 2020 at 9:38 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  16. May 26, 2020 at 9:56 AM
    TXTundra2722
    2015 Black Tundra
    I prefer the lights in the hood bulge versus the grill....I added a fourth light
  17. Jun 2, 2020 at 12:26 PM
    Lowgybear
    Lowgybear It takes an iron will
    Ysai
    San Antonio Texas
    2018 TSS OFF ROAD Tundra
    Those lights are nice and bright, do you have a link for them?
  18. Jun 2, 2020 at 2:27 PM
    TXTundra2722
    2015 Black Tundra
    https://www.vleds.com/pod-3-hv-a-c.html
    I never went cheap on any of my lights. VLEDS is more, but there customer service is second to none for lights.
  19. Jun 2, 2020 at 4:33 PM
    Lowgybear
    Ysai
    San Antonio Texas
    Yea I'm not one to go cheap on my mods
    Thanks!
    TXTundra2722 likes this.
  20. Jun 2, 2020 at 4:38 PM
    TXTundra2722
    2015 Black Tundra
    I emailed back and forth with them and went with all the "parts" they recommended based off the lights I chose and how I was going to wire it. I had at least 8-10 emails back and forth over a 3 month span before I pulled the trigger. They helped every step of the way without issue
  21. Jun 2, 2020 at 4:47 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    @paradizecityz if you're still looking for the bulge insert, I have mine from my old chrome bulge. If you want to pay shipping it's yours. PM me if you want it.
  22. Jun 2, 2020 at 4:49 PM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    I did 4 lights
  23. Jun 2, 2020 at 5:20 PM
    Lowgybear
    Ysai
    San Antonio Texas
    Do you have a thread of the parts you used and how you installed?
  24. Jun 2, 2020 at 7:54 PM
    paradizecityz
    Richmond, TX
    I ended up doing it...a little mad at myself because I took off the mesh to do the hole and didn't measure correctly LOL
    TRDFerguson likes this.
  25. Jun 2, 2020 at 9:18 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have the mesh part and you can have it free as well. I know somebody already offered but if that falls through LMK
  26. Jun 2, 2020 at 9:19 PM
    paradizecityz
    Richmond, TX
    Appreciate it guys. I wonder how much shipping will cost...
  27. Jun 2, 2020 at 9:20 PM
    Tundyfundy
    Bay Area, CA
    Cheaper than a new hood bulge but I can go tomorrow and get you a quote if you want.
    Ely010606 likes this.
  28. Jun 2, 2020 at 9:21 PM
    paradizecityz
    Richmond, TX
    If you don’t mind! 77406 please! Thanks
    Tundyfundy[QUOTED] likes this.
  29. Jun 3, 2020 at 12:22 AM
    Tundyfundy
    Bay Area, CA
    Will do.
  30. Jun 3, 2020 at 3:19 PM
    Blazing Blue
    Blazing Blue New Member
    I just did mine with VLEDS maxpods in white and they look great!
    atruckowner and Wallygator like this.
