Hood bulge amber light grill (raptor lights too)
Discussion in 'Lighting' started by fundratss, Jul 16, 2019.
  1. Jul 16, 2019 at 2:42 PM
    fundratss
    fundratss [OP] Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    This is my write up for adding the hood buldge amber light grill. Grill is found off eBay. Pic is posted and will do quick write up pics in order. First off the eBay auction says it’s plastic. It arrived and I was happily surprised that the grill is metal! The ambers are basic but the grill is meant for it so it looks solid. It literally bolts in place of the stock grill. The only note on install is I had to add couple of washers for a tight fit (metal is slimmer than the plastic). Do not forget to add silicon to the back of the ambers. On to the wiring.
    I did not want to lose my amber halogen light function. But I didn’t want my new lights to flash while using the blinkers. So I printed out the wiring diagram and found the best bet. It is still located on the flasher connector that’s behind the drivers side kick panel on the left side j29 in pic (right about knee height once panel is removed). Connect your power wire to you ambers to the solid white wire on pin 3. This will make your ambers turn on solid when the key is in the on position. I added a smaller 4 amp fuse for the just in case moments (stock fuse for that circuits relay is 7.5a) once you find that wire just run your power wire up through the firewall and into the hood.
    3EB3B149-A9AB-4BDF-B446-EFA88B59155F.jpg 32F25FB5-7773-474C-8F7A-C682D6D15CE0.jpg 55B50A81-9019-42CB-8057-5DA211EAE362.jpg 8C636A6A-25A0-4503-9C99-DA9927EAEFDC.jpg
    I drilled a small hole on the hood hinge to allow the use of the pushpin zip tie to tidy up the install (I hate seeing aftermarket wires hanging) to give it a nice stock look. I added quick connectors to all the lights in case one needed to be replaced. I also added quick connection so the hood buldge could be removed easily. Not much more detail can be added.
    900E48CA-4645-4579-A98A-C467470D9F84.jpg 968D9053-12A7-4646-9586-47BB6421CA01.jpg 43556E0D-BE12-43AD-961E-41D58EED970B.jpg 5B4BC785-8D61-4946-89C1-3C468A3CEAC0.jpg DA3B174F-1D3B-40DC-AD30-36AED77028B0.jpg 17913EF2-5E3B-4212-8F76-181E142EFCDA.jpg 09C23FDF-3C23-4865-9F57-4CFC0D22E99D.jpg
    -Zip tie push pins I had but can be found in automotive section at Lowe’s or Napa has them.
    -quick connectors bought at Lowe’s along with the wires.
    -Ambers even come on solid when remote start active
    -Ambers DO NOT blink when locking or unlocking
    If you have halogen drl’s and want to keep their stock function, and you are adding the raptor grill. This same write up will work for you just be different of the routing of the wires.
    CaptJim1794 and SK_Tundra like this.
  2. Sep 9, 2019 at 6:30 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    20190909_212452.jpg My $10.00 Raptors.
  3. Oct 4, 2019 at 7:02 PM
    jerbear
    jerbear New Member
    Jerry
    Alden, New York
    2020 Black SR5 CM
    None, yet.
    Hi. Just bought a very similar grill with lights. Like yours, each light has a pigtail on it. How did you bring them all together for one ground connection and one power connection. Did you just jump one to the next or am I missing something?
    Thanks.
  4. Oct 5, 2019 at 6:51 AM
    fundratss
    Joe
    Colorado Springs
    Yea. When I installed it I had tied all together to have one ground wire and one positive wire. I made them have quick connections on each so that if one bulb went out it was easy to take it out and install a new one. I changed the front end look already because I added a light bar for night time use
