Hood Alignnment
Discussion in '1st Gen Tundras (2000-2006)' started by Captain Tenneal, Jan 11, 2021.
  1. Jan 11, 2021 at 12:58 AM
    Captain Tenneal
    Captain Tenneal [OP] New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    I noticed the other day that I had a wide gap on one side of my hood. I don't believe the hood has ever been removed. Has anybody else noticed a gap mismatch on their hood or other panels? Or are the gaps fairly even?
  2. Jan 11, 2021 at 1:03 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    photos don't show up. but i know my hood sits a bit funny.. has since i bought it and it had never had anything damaged up that high... only the bed and a fender in the rollover..
  3. Jan 11, 2021 at 4:01 AM
    Professional Hand Model
    Hand Protectors
    There are black bushings under the hood on each side that can be easily twisted/turned by hand to raise or lower the hood heights. Can’t see your pics either so just guessing. You can check my build page #1 and it shows the bushings as discussed.
    Schcoman likes this.
  4. Jan 11, 2021 at 6:51 AM
    Can't see the pics, but up and down adjustment for the hood is as PHM described. If the gap is side to side, then there are 10mm bolts along the top edge of the fender that hold the fender in position. You could loosen those and adjust the gap.
  5. Jan 11, 2021 at 10:35 AM
    Captain Tenneal
    NNV
    OK, I think I figured out how to post a picture on the original post...let's try again!!!
    It's not the hood height that is the issue (I think).
  6. Jan 11, 2021 at 10:52 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    No expert but it looks to me more like your fenders are a little tweaked.
    Drivers side looks even except where the fender curves over the light and the fender doesn't look like it matches the light curve.
    Passenger side looks even at the front and back but the fender looks bowed out in the center.
    I would expect if the hood was out that the gaps would be a straight angle from front to back.
    Darkness likes this.
