Homer the Tundra Full size Tacoma mod
Discussion in 'New Member Introductions' started by Bates5450, May 19, 2018.
  1. May 19, 2018 at 9:58 PM
    Bates5450
    Bates5450 [OP] Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    7C00942F-63E3-498B-91C1-17DDE6E7C7EF.jpg Had a 2017 Tacoma put 45k miles on in 8 months... just traded in for 2018 CM SR5 Cement. Dealer gave me 32 for taco I paid 35 for it. Paid 41 OTD for the Tundra. Stoked to be apart of the community of a truck I can actually fit in. Night and day in power, comfort, and I’m stoked. Miss the taco though, had 14k worth of plans for it still. Glad to have gotten out before they occurred. Currently in Dickinson, ND. Working the oil fields.998350F8-2F71-48B3-B870-3454447AC90B.jpg
  2. May 19, 2018 at 10:06 PM
    TheBeast The Beach
    nice taco ! nice Tundra too..any plans yet ?
  3. May 20, 2018 at 5:06 AM
    Bates5450
    Jacob Bates
    Dickinson, ND
    MCM M/T kit
    ADS 3.0 front
    2.5 rear triple bypass with U748
    Rear frame support
    Decked bed box
    Front and rear bumpers
    Smittybilt 12k winch
    White Knuckle Sliders
    Some baja designs lights
    Bed Cage....custom..for RTT
    4:88 Gears
    ARB rear/ Harrop ELocker front
    Arb dual compressor
    Budskids
    Switch pros
    Katzkin Leather Black
    ESP under seat safe
    Center counsel safe
    I’m sure there will eventually be more.
    Debating between 35’s and 37’s. I know there’s no MPG to be had with these trucks to begin with so that’s not a factor. Definitely Toyo Open Country MT though and some 18” method NV most likely. I’ve run those tires for quite some time in very sharp rocks, with ruts and supremely washed out roads. I drive over 200 miles a day for work in ND very diverse weather. No flats, no chunks out of tread from scoria rock. Guys without good tires get flats weekly at times.
    Some pieces to the puzzle have begun to show up. Just waiting on MCM Fab UCA’s and it’ll all come together for now until I can afford rear mid travel from MCM as well.
  4. May 20, 2018 at 5:10 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome! Should be a nice build thread in your future with those plans.
    Bates5450[OP] likes this.
  5. May 20, 2018 at 5:11 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!!
    :popcorn::popcorn::popcorn:
  6. May 20, 2018 at 5:46 AM
    Both nice rides! Welcome from CO!
  7. May 20, 2018 at 6:10 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome and congrats from Nevada, sweet looking rides.
  8. May 20, 2018 at 6:59 AM
    Bates5450
    Jacob Bates
    Dickinson, ND
    Thanks guys, I’ll most def have a Build thread and document for DIY threads and videos.
  9. May 20, 2018 at 8:18 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!! My favorite color!
  10. May 20, 2018 at 8:19 AM
    15whtrd
    15whtrd Mr. Blonde
    Welcome! Looking forward to seeing your build.
  11. May 20, 2018 at 8:51 AM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  12. May 20, 2018 at 9:23 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Jacob
  13. May 20, 2018 at 9:26 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado and keep that Dino juice flowing.
  14. May 20, 2018 at 9:55 AM
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    Nice truck! Yes share all your builds and diy and vids, sharing is caring.
  15. May 20, 2018 at 3:21 PM
    Welcome from CO. A man with a plan!
  16. May 20, 2018 at 3:28 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO, and congrats on the buy! Have quite a few buddies who’ve been up in NoDak for oil field work. You’ve gotta be one of the few who doesn’t have a diesel daily driver.
    Looking forward to seeing it!
  17. May 20, 2018 at 3:50 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  18. May 20, 2018 at 5:29 PM
    Welcome from Texas
  19. May 20, 2018 at 6:25 PM
    Blueknights75
    Ron
    Clayton, NC
  20. May 20, 2018 at 6:32 PM
    Welcome from Ohio!
  21. May 20, 2018 at 7:12 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Welcome. Love both trucks.
    Not that my opinion means much but if you are going with aftermarket front bumper and 4.88s just go with 37”s...
  22. Nov 30, 2018 at 2:19 PM
    Bates5450
    Jacob Bates
    Dickinson, ND
    Finally made the time to install the front mid travel kit on Homer. Did the entire job with hand tools and it was quite simple. Used a rathchet strap to pull the lower control arms together to put the new ADS coilovers on.
    Make sure to take your battery out. It’ll make taking the the drivers side uca out much easier.
    Taking everything off is quite easy solo, however having an extra pair of hands to help put the UCA’s on makes doing so a breeze.
    I didn’t adjust the 3.0’s at all and it seems just about perfectly level with the rear OEM. Looking forward to completing the kit with Deavers and Tripple bypass in the rear.
    Be sure to have a higher than normal lifting jack or some blocks to use to lift up higher. Especially if you’re running bigger tires. I needed to make blocks for my jack stands and a block for my jack to lift the truck higher for the 37’s.
    It was late when I finished and I wanted to go test it out. So that’s the reason for lack of photos. I also wanted to video it all and have a step by step however it’s hard to get motivated to do that when it’s freezing out and getting it done fast is important.
    jewsNbrews and 4RunnerKid like this.
  23. Nov 30, 2018 at 2:31 PM
    4RunnerKid
    4RunnerKid New Member
    Oceano, CA
    '19 Cement CM SR5 4x4
    TRD Pro Bilsteins w/ single CB shim, 285/75-17 Falken AT3, Method 701, debadged, ceramic coated, Husky liners
    hot damn that thing looks good on 37s... i'll be watching
  24. Nov 30, 2018 at 2:32 PM
    Bates5450
    Jacob Bates
    Dickinson, ND
    Thanks man, I couldn’t agree more.
  25. Nov 30, 2018 at 2:41 PM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  26. Nov 30, 2018 at 2:42 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Welcome from Maryland :hattip:
    Nice rig!!
  27. Nov 30, 2018 at 3:22 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
